Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-25-2008, 07:14 PM   #1
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
Default 15w-40? help me understand
a tuner i was talking to advised me to remove the restrictor pill and use 15w-4o oil .. on my 30 .82 2006 sti , bad info or not too bad what will come of it.? i mean thats a thick ass oil!
STIFLYBY_RANGER is offline   Reply With Quote
Old 03-25-2008, 07:30 PM   #2
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Not really all that "thick". Subaru actually recommends those weights for certain models and applications. Do a search, tons of people using 15w-40 and 15w-50 weights for their cars here.
-JamesW
5w-40 weight, non-turbo.
JamesWilson is offline   Reply With Quote
Old 03-25-2008, 09:01 PM   #3
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
well what bad things can come from going from 5w-30 to the new weight
Old 03-25-2008, 09:20 PM   #4
mikeythejew
Member#: 141672
In very cold weather, it is too thick and will not provide lubrication as fast as any 5W whatever oil. I think there are a few good UOA's from WRX owners using 15W40 here, shell rotellaT?
Your tuner sounds like the kinda guy who has weird ideas stuck in his head.
If you really want info on oil, much better then you will get here, educate yourself on the link. www.bobistheoilguy.com
mikeythejew is offline   Reply With Quote
Old 03-25-2008, 09:23 PM   #5
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
will do , im just not used to making a jump like that, and it not having a negative effect
Old 03-25-2008, 09:43 PM   #6
jays05
Member#: 78165
05 STI 35r + e85
shell rotella-t 15w40 is good oil. A lot of built motor folks use it. Do you have a stock engine or a built motor with looser tolerences?
I don't understand why he recommended to remove the restrictor pill? I assume you mean the one on the turbo oil feed line, why remove that?
jays05 is offline   Reply With Quote
Old 03-25-2008, 10:03 PM   #7
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
stock internals, aftermarket everything else possible ... i guess he was afraid to choke it of oil, but i was just afraid it may cause some issue. i noticed smoke today which has never happened so i think itd be smart to reinstall the pill for the feed line and the oil im using is royal purple
Old 03-25-2008, 10:44 PM   #8
silver-duck
Member#: 130710
I use amsoil 20-50 racing oil year'round[5-112 degrees] in 06, stage 3 which I drive hard.It uses 0 oil between changes. Better safe than sorry.
silver-duck is offline   Reply With Quote
Old 03-25-2008, 11:13 PM   #9
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
so i really dont need to worry about the weight i have in just possibly using the restictor. like i said the internals are stock. but thats all and ive got alot of boost 27 lbs worth.
Old 03-25-2008, 11:19 PM   #10
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
http://store.forcedperformance.net/m...Info_SubaruOil
Everyone in this thread should read that!
Personally im using 5w50 on a stage 2 setup with very good results.
15w40 would be great for a built motor!
moosecakes is offline   Reply With Quote
Old 03-25-2008, 11:28 PM   #11
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
yea well as i stated not built motor yet.. just everything else you can think of and a lot of boost .. no restrictor anymore and that oil weight
Old 03-25-2008, 11:29 PM   #12
rkramer
Member#: 118209
2015 WRX Limitec
your engine doesn't know, care, or remember what the previous batch of oil was compared to your current fill. it is ok to go from 5-30 to 15-50 if you want.
the ONLY exception was waaaay back, 10-15+ years ago, regular oil would cause some seals to swell. if you went to synth after the seals had hit their critical size, the engine would weep oil since the synth wouldn't swell the seals and they returned to their original size. (minus the wear that occurred, aka the new leak)
Old 03-26-2008, 10:10 PM   #13
STIFLYBY_RANGER
Member#: 141994
06 STi
obp
and what about the restrictor pill, does anybody choose not to use it at all, i always had it in, perrin also supplies 2 just in case
help me understand... 235/40/17 lowrider89 Tire & Wheel 6 10-20-2009 07:09 PM
Help me understand valve lash Patrick Olsen Normally Aspirated Powertrain 7 08-15-2002 04:04 PM
Help me understand the finer points of the ECU z28dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-25-2002 07:22 PM
Help me understand the Subaru Mystique... RSKwannabe Legacy Forum 32 05-23-2002 05:36 PM
help me understand. Why does Rally-RS General Community 1 11-09-2001 12:35 AM
