Old 03-25-2008, 10:06 PM   #1
arch4life
Member#: 172588
2005 saab 9-2x sti
Default Tuning my WGDC, is my turbo dead?
Hello all, been lurking and reading and doing a lot of work understanding what im looking at in terms of a log, and what values i should expect to see.
I have a 2004 sti, essentially, and im currently trying to tune for the car to hit boost targets for an open source stage 2 tune.
mods:
SPT intake
gt spec headers
up pipe
TBE 3inch
Turbo XS FMIC
i just recently installed a GM Boost control solenoid, after wondering why i was not hitting stock boost targets, or stage 2 boost targets.
i have had to increase the WGDC (waste gate duty cycle) up near 75% to achieve target boost in the midrange. Despite this high and steady WGDC, the boost seen in the higher rpm's is tapering off down to 12.
boost targets are 18 tapering to 16 after about 5.5k-7.
here is the log: ( if anyone could tell me how to paste this as text in its own little box i'd love it)
is the turbo just unable to maintain the boost? what should i check? thoughts? Also, i do have a lower uppipe leak. working on fixing that soon, i dont think however that it is large enough to create this kind of boost loss. keep in mind this is the GM BCS, so 75% is quite high for 18 psi peak.
arch4life is offline   Reply With Quote
Old 03-25-2008, 10:38 PM   #2
Bullwinkle1983
Member#: 172332
2006 WRX
Use the "code" function to paste into it's own text box.
Well, those WGDC's aren't that high for pushing that much boost. Every car is different, and I've found that most cars like right around 60% WGDC with that GMBCS, but some simply require more and some less.
Second -- it looks like you're maxing out your injectors up top. I'm not sure I would suggest turning up the boost up there in the first place.
Third -- you're right, you should be able to make more boost up top, however, it seems obvious that you need to run more WGDC up there to run more boost, as the VF39 still does taper off quickly up top.
Bullwinkle1983 is offline   Reply With Quote
Old 03-25-2008, 11:02 PM   #3
arch4life
Member#: 172588
2005 saab 9-2x sti
, i havent adjusted the AFR's yet up top, its still very rich, in the 10.5:1 range as registered by my innovate LC-1 wideband.
so there is room to play with in terms of injector duty cycle, but that will be sorted after i make boost. ( i always watch that wideband )
as far as needing more WGDC up top, i am not sure i have seen someone adding more WGDC when boost should taper down up top. I believe i had always seen the wgdc falling as boost targets decreased.
Old 03-25-2008, 11:22 PM   #4
Nuke209
Member#: 108089
2003 WRX
NF Performance
I've seen some cars needing more wgdc more than others, even with the boost solenoid, it required much more than others did.
Nuke209 is offline   Reply With Quote
Old 03-25-2008, 11:56 PM   #5
arch4life
Member#: 172588
2005 saab 9-2x sti
interesting. over on rom raiders someone suggested that the up pipe leak could cause this to occur more noticibly at the higher rpms because of the large backpressure caused by the turbo. thoughts?
Old 03-26-2008, 12:13 AM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
That can be also, check for leaks.
Old 03-26-2008, 12:26 AM   #7
arch4life
Member#: 172588
2005 saab 9-2x sti
well i know the leak exists, i said so in the first post i believe it is leaking at idle. i guess it would be leaking a fair amount more on boost
Old 03-26-2008, 08:59 AM   #8
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Why is the IAM 1?
98EJ20 is offline   Reply With Quote
Old 03-26-2008, 09:12 AM   #9
arch4life
Member#: 172588
2005 saab 9-2x sti
04 sti, 32 bit ecu's have IAM 0-1 while 16 bit ecu's have IAM 0-16 i believe.
Old 03-26-2008, 11:29 AM   #10
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
Yea.. you need more WGDC in the low end, and top end... Start with 80-90 and you'll spool up faster, taper back down in the midrange, then slowly taper up towards redline, again near 80-90.
fujiillin is offline   Reply With Quote
Old 03-26-2008, 11:46 AM   #11
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Thanks arch for the clarification
Old 03-26-2008, 12:13 PM   #12
arch4life
Member#: 172588
2005 saab 9-2x sti
so running 80-90 wgdc on a GM BCS is normal? this confuses me. it goes against everything i'd read about how much more efficient the GM BCS is over the stock bleeder type BCS.
Old 03-26-2008, 12:44 PM   #13
Bullwinkle1983
Member#: 172332
2006 WRX
Exactly.
The point is you're running the turbo at max capacity. You are trying to push the turbo to the limits of what it wants to run up in the high RPM range. Below are my graphs from my 06 WRX w/ GMBCS. The TD04 tapers even more then the VF39.
Old 03-26-2008, 01:45 PM   #14
arch4life
Member#: 172588
2005 saab 9-2x sti
wow, thanks for the graphs! i guess its true that car to car wgdc varies alot, and if i am running the turbo at the upper end of the efficiency range, i need wgdc to keep it up top. i guess i need to make some more changes to my wastegate duty cycle maps. we'll see how that goes.
after looking at the stock boost/ wastegate maps, it looks like im requiring more wastegate than the stock needs up top. AND im not hitting the same #'s as the stock map in terms of boost targets, its only hitting 12 when the stock map is at 14.
is there that much variance between cars that i would need alot more wgdc to hit the stock boost targets up top let alone the stage 2 boost targets?
Old 03-26-2008, 03:43 PM   #15
fujiillin
Member#: 171344
2006 STi Wagon
Black HTA Green
That could be attributed to the uppipe leak.
Boohaahaa - Now that my friends is a turbo! sponaugle Proven Power Bragging 272 09-08-2008 04:35 PM
That is my...that is my wings. I'm a fu--ing flight attendant. rogue Off-Topic 36 08-15-2007 07:55 PM
I think my neighbor is dragging a dead body down the hallway.... The Tree Off-Topic 22 01-07-2007 12:54 AM
my name is...my name is...my name is...rice burner! Jason Temple New England Impreza Club Forum -- NESIC 21 02-08-2005 07:10 PM
('93-'01) TRI Tuning........Ugh....where is my freaking part? ARG Impreza Forum 77 05-08-2001 12:35 AM
