Old 03-26-2008, 06:13 PM   #1
plode
Member#: 116910
Default Oil filter leakage issues
On my 06 wrx every oil filter I have put on the car has leaked. Not much, but enough to have some oil on the filter and around that general area. Im sure the rubber o-ring has been removed every time, and I always lube the new one before installing it. Any idea as to why every single one(probably about 8-10 now) have leaked?
plode is offline   Reply With Quote
Old 03-26-2008, 06:22 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
You need to turn the filter 1/8 of a turn more to tighten it properly.?
wrxdrvr is offline   Reply With Quote
Old 03-27-2008, 02:41 AM   #3
plode
Member#: 116910
I do, Ive done oil changes on 3 of my own vehicles, my parents cars, and numerous family relatives cars and have never had this problem before. ever. I clean the o-ring mating surface and all, and still leaks. Could the block not be machined correctly?
Old 03-27-2008, 07:23 PM   #4
jays05
Member#: 78165
05 STI 35r + e85
Are you using OEM filters?
jays05 is offline   Reply With Quote
Old 03-28-2008, 02:18 AM   #5
plode
Member#: 116910
ive tried purolator, pureone, fram, it doesn't seem to be brand specific. Hell, I remember the first oil change I did- it was leaking a little bit(first OEM oil filter)
Old 03-28-2008, 04:01 AM   #6
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
Could be the oil cooler just right above.
GDR is offline   Reply With Quote
Old 03-28-2008, 04:30 AM   #7
GRIP_SPEED
Member#: 141717
2004 Psm stg2 wrx
I say either the oil filter is not tight all the way enough or it is over tighten.
why not save yourself the trouble and time and get a fumoto valve installed on your suby? I have one installed and makes oil changes easy
GRIP_SPEED is offline   Reply With Quote
Old 03-28-2008, 04:41 AM   #8
magnum2066
Member#: 158586
2009 WRX
Pearl White
He is talking about the oil filter, not the oil drain plug silly.
magnum2066 is offline   Reply With Quote
Old 03-28-2008, 11:01 AM   #9
bluesubie
Member#: 767
04 FXT
Does it leak just a little and drip to the bottom of the filter?
The only time I've had a leak is overtightening, undertightening or getting a little bit into the channel on the top of the filter when pre-filling. Was the OEM filter that you used a white one? I've never had a leak when following the exact instructions on a black OEM filter. And that's with three Subaru's.
I would get an opinion from another Subaru owner. I would take a look but you're too freakin far away. I'm in northern Middlesex county.
-Dennis
Old 03-28-2008, 11:12 AM   #10
blackfang
Member#: 131347
2007 Legacy 2.5i SE
98 Z/28, VN 900 custom
OT- Damn you live near my folks up in NJ. My dad is a Seaville Fireman.
blackfang is offline   Reply With Quote
Old 03-28-2008, 12:43 PM   #11
bluesubie
Member#: 767
04 FXT
Is he familiar with changing oil in Subaru's?
-Dennis
Old 03-28-2008, 12:59 PM   #12
blackfang
Member#: 131347
2007 Legacy 2.5i SE
-Dennis
Naa just Muscle cars and his Impala SS. He has no idea what a foreign car is.
Old 03-28-2008, 01:04 PM   #13
magnum2066
Member#: 158586
2009 WRX
Pearl White
To the OP: Are you the original owner and has anyone else touched your filter?
If it leaks with any filter you use then it obviously isn't the filters... Double check the surface the O-ring mates to on the block for an O-ring left behind or scratching on the mating surface. Also, if you can try to check and see if the threads you screw the filter on to aren't damaged or bent. My guess would be that the threads are possibly bent either from road debris or possibly Uncle Scotty's toitle.
Maybe try taking a few good pics just to see if there are any give-aways?
Old 03-28-2008, 01:33 PM   #14
sigurd
Member#: 128721
2002 impreza WRX
psm
Are you dabbing your finger in oil and running it around the new filters o-ring before installing it? If your putting it on dry its possible its sticking and creating gaps.
sigurd is offline   Reply With Quote
Old 03-28-2008, 06:17 PM   #15
plode
Member#: 116910
Im the original owner, I'm the only one who has done oil changes, and I do lube the filter o-ring before install. I only hand tighten it(never had a problem doing that before on any other car).
I doubt any of it is bent, it wouldn't thread on properly if that was the case.
And to the person who recommended the Fumoto valve, your about a year and a half too late with that suggestion
And to the person who's dad is a Seaville fireman, check your PM box. Ive been a member there for ....hmm going on 4 years now.
Old 03-28-2008, 07:03 PM   #16
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
tight it good!!
EJ20_lee is offline   Reply With Quote
Old 03-28-2008, 07:59 PM   #17
blackfang
Member#: 131347
2007 Legacy 2.5i SE
Ah be damn!!!
Anybody having issues with a leaking oil filter? shesky Forester Forum 1 07-14-2007 04:47 PM
Coolant and Fuel Leakage Issue silversilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-05-2006 01:53 PM
OEM Oil Filters, OEM Turbo oil filters, fuel filters, spark plugs, air filters LangstonSubaru Vendor 'For Sale' Classifieds 125 03-29-2004 08:25 AM
need to know oil filter threads for remote oil filter Gravel-Fun Normally Aspirated Powertrain 2 07-22-2002 05:23 PM
Oil and oil filter? Spark plugs and air filter? TimCat General Forum Archive 5 01-18-2001 11:27 PM
