Welcome to the North American Subaru Impreza Owners Club Friday February 5, 2016
Mid Atlantic Impreza Club
Old 03-26-2008, 08:06 PM   #1
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Default Can someone tell me where this hose goes?
Hi Guys,
I recently did a turbo swap and im throwing a p0457. There is no hose connected at the moment to the intake manifold where the green circle is. I covered it with a rubber grommet so nothing gets in, I just don't know what hose is supposed to go on there. I don't see any loose hoses in the engine bay, but somewhere to start would be awesome. I borrowed the engine bay pic from someone else, btw.
Thanks,
Grant
Spike700 is offline   Reply With Quote
Old 03-26-2008, 08:51 PM   #2
the_unknown
Member#: 168211
2013 Cargobob
Looks like its the air bypass hose B. It connects to the intake inlet below it i believe. PM me your e-mail and i can send you a pdf to where it goes.
the_unknown is offline   Reply With Quote
Old 03-26-2008, 08:52 PM   #3
chibich
Member#: 79134
2004 STI
there is a small selenoid below and to the left of that hose. It is attached to the intake manifold by a 12mm bolt. if you undo the two hoses next to that one(the one attached to the intake manifold and the one attached to the turbo inlet) you should be able to see the solenoid and reattach the hose put a small clamp or zip tie on it and it should hold.
chibich is offline   Reply With Quote
Old 03-26-2008, 08:55 PM   #4
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Thanks for the responses, I will check that. Would this be a reason to throw an EVAP p0457 CEl?
Old 03-26-2008, 08:55 PM   #5
Dystinct
Member#: 105759
lack of suprise
KatsSubyRocks!
too late
Dystinct is offline   Reply With Quote
Old 03-26-2008, 08:57 PM   #6
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Lol i read your post, thanks for the info.
Old 03-26-2008, 09:27 PM   #7
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
wait, this thread isnt about hoes at all!
nkx is offline   Reply With Quote
Old 03-26-2008, 09:29 PM   #8
the_unknown
Member#: 168211
2013 Cargobob
how about "the hoes goes to the corner and gets me my money"? No... ok...nm
Old 03-26-2008, 10:49 PM   #9
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Well, I looked under the hood and there are no extra hoses anywhere. So the hose connects from the intake manifold to the solenoid bolted to the manifold?
Old 03-27-2008, 12:28 PM   #10
the_unknown
Member#: 168211
2013 Cargobob
Its actually hard to see where it goes from the top, you may have to remove a couple things to put it in its proper place. Or you may have accidentaly taken the hose off and forgotten it. Let me know if you have any more questions
Old 03-27-2008, 12:38 PM   #11
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
I mean idk whether the hose connects to that valve. The valve is already connected to the intake, the manifold in the location on the photo, and to a hose that goes underneath the intercooler to a metal rail. Idk where the hose is supposed to connect to.
Old 03-27-2008, 12:48 PM   #12
the_unknown
Member#: 168211
2013 Cargobob
If you'd like I could meet you somewhere tonight to help you and we can use my car as a guide to what goes where
Old 03-27-2008, 01:01 PM   #13
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
As of right now, I am taking my car to a shop tonight so they can take a look at it, but if they can't figure it out then I will definitely take you up on that offer. thanks for the offer, i will let you know tonight.
Old 03-27-2008, 10:48 PM   #14
Spike700
Member#: 136282
2002 WRB WRX
2010 Infiniti G37xS
Thanks guys for the responses. The guys at DPS figured out the problem, the valve was broken and no hoses came off of it. DPS replaced the valve for me for free! On a side note I got my car tuned by Pirouz and I am extremely happy with it. Thanks guys, your service is awesome!
Old 03-28-2008, 10:13 AM   #15
DPS
Member#: 109308
Glad we could help out.
DPS is offline   Reply With Quote
can someone tell me where i can get these? wazzupidaug5 Private 'Wanted' Classifieds 26 09-24-2008 04:43 PM
Can someone tell me where this hose goes to? Spike700 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-27-2008 10:46 PM
can someone tell me where this goes? spoolinred Built Motor Discussion 6 09-29-2007 09:38 PM
Can someone tell me where I can buy some gauges. AndyM Interior & Exterior Modification 5 05-14-2001 06:31 PM
