Old 08-28-2008, 10:13 PM   #1
gopsu
Member#: 96448
02 WRX VF34
Default Brembo calipers with WRX rotors?
I would love to get Brembo calipers, but prefer to stay with WRX rotors since Brembo rotor is about 10 lbs heavier. Is it possible to use Brembo calipers with WRX rotors? Obviously rotor is significantly smaller, but I wonder if it can be made fit with a minor tweaking or fabrication.
I know it is a crazy idea, but thought I would try.
gopsu is offline   Reply With Quote
Old 08-28-2008, 10:57 PM   #2
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
no, bad idea. the main reasion to do this is for the added mass of the rotor to cool more. get a set of two pc rotors and thre is your weight difference.
Shane
PARANOID56 is offline   Reply With Quote
Old 08-29-2008, 06:28 AM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
no. the brembos are one (well, two halves) cast pieces that attach directly to the spindle, and the spacing is made to work with the brembo rotor. So there's no way to use a smaller rotor with that caliper.
If you want save weight go two piece. A little pricey though.
jamal is offline   Reply With Quote
Old 08-30-2008, 02:07 AM   #4
neko
Member#: 46500
Now with 200% more
room 4 girl-on-girl fun.
yes, other than the outward location being off, the brembo calipers were made to use thicker rotors. If you want brembo looks, just spring for the full brembo brake setup.
If you want to keep the weight down, stick with the wrx rotor, and all the smaller wheel sizes that entails, then get oem 4pots. bolt on, and you don't need any other rotors. Plus oem 4pots are lighter than the brembo calipers. Even lighter than your oem sliding piston calipers.
neko is offline   Reply With Quote
04 STI Brembo Calipers, Pads and Rotors snowcrzy Suspension/Brakes/Handling 6 06-24-2009 10:17 PM
FS: Full set 04 STi brembos, calipers, pads and rotors Stiguy04 NWIC Private Classifieds 11 04-02-2009 08:44 PM
FS- Used black STI Brembo calipers, 05 sti rotors, 05-07 sti hubs (5x114) 2005 Suspension/Brakes/Handling 25 09-29-2008 08:47 AM
FS: Front Brembo caliper + DBA 5000 Rotors with 5x114.3 mug23 Suspension/Brakes/Handling 8 07-10-2008 04:10 PM
FS: Front Brembo caliper + DBA 5000 rotors mug23 RMIC Private Classifieds 7 07-02-2008 04:39 PM
