Old 03-27-2008, 12:35 PM   #1
claudefrog
Member#: 175764
2003 sti type uk
WR Blue
Default problems connecting to ecu with green connectors and jumper connected
Hi
I have a 2003 STI Type UK with ECU AH990-5512 and when trying to connect to car i get the below message; I am using a tactrix cable and ECU Explorer and ECUflash to try and connect, using ecuexplorer i am able to delete error codes, but when i connect up the jumper and green connectors and try to read the ROM from my ECU i get the below.
[23:12:03.750] Using interface OpenPort 1.3 Universal TX27qQTjd4ecb4d9a1d6ae225e5755d6f5bcfdacbaef2534
[23:12:07.000] denso02_bootloader_cmd_start
[23:12:08.234] denso02_bootloader_cmd_start
[23:12:09.468] denso02_bootloader_cmd_start
[23:12:10.703] denso02_bootloader_cmd_start
[23:12:11.921] denso02_bootloader_cmd_start
[23:12:12.375] kernel get version
[23:12:12.718] interface close
also.. using a different program i get this error
1452 byte kernel read.
kernel checksum is valid (n = 2).
kernel image loaded and verified.
kernel flash disable
rkrv: preamble 1 no response
<< PROCESS COMPLETE >>
any ideas on what the problem can be?
claudefrog is offline   Reply With Quote
Old 03-27-2008, 03:50 PM   #2
arch4life
Member#: 172588
2005 saab 9-2x sti
you can read the rom without the jumpers connected. thats what i did with a 04 sti ecu.
to write, however, you need to connect the green blocks
arch4life is offline   Reply With Quote
Old 03-27-2008, 06:58 PM   #3
claudefrog
Member#: 175764
2003 sti type uk
WR Blue
thanks for that! i will try it in the morning when back out at the car.
Old 05-15-2008, 11:58 AM   #4
rb22b
Member#: 116557
1991 Jetta Coupe
sonic yellow wagon...sold
any word on if this worked?
rb22b is offline   Reply With Quote
problems connecting to ecu alwu Open Source Reflashes 3 06-22-2009 03:46 PM
Problem connecting to ECU emerica459 Open Source Reflashes 15 04-30-2009 09:09 PM
WTB: Wire That Connects to ECU strikers Private 'Wanted' Classifieds 2 02-19-2008 11:17 PM
Aftermarket EGT Connected To ECU hurricane123 Factory 2.0L Turbo Powertrain 36 09-07-2007 10:01 AM
Automatic transmission connected to ECU? lordzappo Newbies & FAQs 1 07-18-2005 01:59 AM
Message Board Statistics All times are GMT -4. The time now is 10:18 PM.
