Old 03-27-2008, 02:45 PM   #1
suren27
Member#: 67464
05 Stock what?
Too Low #009
Default CEL, flashing cruise, no code?
Hey guys...
Not sure what this could be so I figured Id post up for whoever may know to possibly help me out...
This is the second time this has happened, both time it occurred when warming my car up in the morning... started it up, went back inside to do a few things before i left, come back and there it was, went to read it, the first time it showed no code, yet it said that there was an error of communication of sorts, i dont remember it but thought nothing of it then, it wasnt a Pxxxx code either - this was a month ago or so? Then this morning same thing, went to read the code, it said 0 codes yet I still had a solid CEL and a flashing cruise... cleared it, let it idle, and now its "normal" but i have a feeling if it did it twice... it should happen again
any ideas? any clue what to check? i don't even know where to start
suren27 is offline   Reply With Quote
Old 08-10-2008, 09:11 PM   #2
suren27
Member#: 67464
05 Stock what?
Too Low #009
bump... anyone?
Old 08-10-2008, 10:13 PM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
What are you using to read the code?
Old 08-10-2008, 10:22 PM   #4
suren27
Member#: 67464
05 Stock what?
Too Low #009
First with ECUExplorer, then to autozone... both with negative results... still a solid cel, flashing cruise, and no code when read.
Old 08-10-2008, 10:57 PM   #5
Cocoa Beach Bum
Member#: 17355
I'll bet you use an AccessPort.
Cocoa Beach Bum is offline   Reply With Quote
Old 08-10-2008, 11:20 PM   #6
suren27
Member#: 67464
05 Stock what?
Too Low #009
Enginuity.
Old 08-11-2008, 04:55 PM   #7
b7sharp
Member#: 136731
2005 wrx sti
Do u have an aftermarket tune? Some tuners disable certain codes, but for some reasons u will still get a cel, but when u go to read the code it will say "no code found" or have a bunch of question marks
b7sharp is offline   Reply With Quote
Old 08-11-2008, 11:22 PM   #8
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Hmm... there isn't much to work with, but I would inspect all your cruise control components just in case.
GentlemenStylez is offline   Reply With Quote
Old 08-11-2008, 11:27 PM   #9
suren27
Member#: 67464
05 Stock what?
Too Low #009
Yeah its tuned but it shouldn't be doing this...
On top of not having much to work with, check this out, after driving around a bit, it completely went off and disappeared... completely beats me so far, this is about the 3rd time in like 6 months. Minor and annoying, could it be a front o2 sensor or MAF on its way out?
Old 08-12-2008, 07:23 AM   #10
GentlemenStylez
Member#: 146626
2001 Impreza GC8
Panda on rails!
Hmm, I doubt it's engine related. Try pulling your cruise control fuse when you get your warning/caution lights again, then watch to see if those lights go out. For some reason I strongly think it's cruise control related. Just a gut feeling. Sorry, I can't really help you anymore than that; we have nothing to work with! haha
Old 08-25-2008, 10:18 AM   #11
HOLLYW00D
Member#: 44954
2004 FXT
any update on this?
HOLLYW00D is offline   Reply With Quote
Old 09-23-2008, 01:17 PM   #12
suren27
Member#: 67464
05 Stock what?
Too Low #009
Well to update... happens after idling the car for the most part, read the code with a laptop that had ecutek and it threw p02b0 apparenltly, no other code reader caught anything... been really busy recently, anyone got ideas?
Old 09-23-2008, 04:08 PM   #13
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
You can have.
sure that isnt vallet mode?
udelslayer is offline   Reply With Quote
Old 09-23-2008, 04:55 PM   #14
Cocoa Beach Bum
Member#: 17355
P20b0 is because of EcuTeK reflash glitch and means your ECU is trying to set some misfire trouble code. Well known problem.
http://forum.ecutek.com/topic.asp?TOPIC_ID=635
Old 10-22-2008, 01:48 AM   #15
anthony27
Member#: 192291
Exclamation
it sounds elec. problem check your fuses and and pull disconnect battery and check for faults with the circuts. have you done any wiring in the car i.e like boost controller, radio install or etc. if so go back and check your wires and make sure you did not cut any wire that was not supposed to get cut or pitched.
anthony27 is offline   Reply With Quote
Old 09-17-2012, 07:35 PM   #16
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
I have started to get a hard code with the cruise flashing. It comes on at idle. It has not cleared after many starts. Seems like it is there for good!! I do have an aftermarket open source tune. I went to advanced auto part to pull the code and it read no code?? Has anyone figured out what this problem was?? This thread is 4 years old!
Coop1103 is offline   Reply With Quote
Randomly threw CEL, flashing cruise light... Falkon Service & Maintenance 3 04-19-2010 01:48 AM
cel flashes but no code..HELP red05wrx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-25-2010 11:08 AM
Emergency: CEL, Flashing Cruise, no throttle. GregsblueRex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 04-09-2007 11:15 PM
CEL Flashing but No Code ejh25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-30-2006 11:35 AM
CEL/flashing cruise question Pre-diddy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-03-2004 12:17 PM
