Old 03-27-2008, 06:19 PM   #1
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
Default Mix your own Syn Blend!
I've been running Pennzoil Platinum 10-40 with great mpg (30+ hwy) and zero consumption. I used PP 10-30 for the last change, and had some consumption under some hard drivings.
Now, for whatever reason, PP 10-40 isn't available at walmart anymore. Since the weather is getting warmer, I really don't feel like running 10-30....
So I was thinking of mixing PP 5 or 10-30 with conventional Pennzoil 20-50, 50:50 mix, for 4k drain interval. I'll also send in sample for uoa.
Has anyone done this? what kind of weight am I looking at? something like a 15-40 or so?
imprezilization is offline   Reply With Quote
Old 03-27-2008, 08:21 PM   #2
jays05
Member#: 78165
05 STI 35r + e85
Didn't some european car owners have to mix different grades to get factory spec, years ago?
jays05 is offline   Reply With Quote
Old 03-27-2008, 08:22 PM   #3
mikeythejew
Member#: 141672
I bet they do not stock PP 10W40 because it's a slow seller. 10W40 as a whole has gone way down in percentage of use.
You could use a 5W40 oil. I have a valvoline synpower 5W40 UOA in this forum that did rather well. Good luck finding that particular oil.
mikeythejew is offline   Reply With Quote
Old 03-27-2008, 10:45 PM   #4
bluesubie
Member#: 767
04 FXT
Old 03-28-2008, 02:26 AM   #5
Arctic Penguin
Member#: 119532
2006 WRX
5w40 rotella T is pure syn and cheap at walmart
Arctic Penguin is offline   Reply With Quote
Old 03-28-2008, 02:28 AM   #6
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
yup, saw the thread about the mobil 1 blends.
Dennis, actualy I posted the same question on Bitog as well. are you a regular on there too?
Old 03-28-2008, 11:17 AM   #7
bluesubie
Member#: 767
04 FXT
Yep.
-Dennis
Old 07-06-2008, 04:02 PM   #8
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Does it matter that it didn't have the "SM" rating? I was just there today looking at oil and I wanted a 5or10W-40 synthetic. Rotella was the only one, but it didn;t have the same ratings as the gas-engine oils.
Thanks
mmiller2002 is offline   Reply With Quote
Old 07-06-2008, 08:50 PM   #9
gpshumway
Member#: 43950
07 WRX LTD Wagon
Satin White Pearl
Thanks
The short answer is no, many believe the older SL oils have generally better additive packages than the newer SM oils. That said, the most recent formulation of Rotella T meets the SM requirements for gasoline engines. The Rotella I purchased recently at Wal-Mart was the newer SM stuff.
Rotella Website HERE
gpshumway is offline   Reply With Quote
Old 07-06-2008, 11:04 PM   #10
sky44
Member#: 178333
2005 OBS 5MT
green
i used to make my own synthetic/dino blend when i had my corolla.
2 bottles of mobil 1 5w30 and 2 bottles of Mobil "clean 5000" 5w30.
the guy at advance auto parts told me it was a bad idea
probably was...
i got 153k out of that car before i sold it though. no oil consumption issues. still going i believe.
sky44 is offline   Reply With Quote
The ultimate tax shelter: Owning your own business fuzzycuffs Off-Topic 78 02-19-2007 10:59 AM
Make your own tool to hold your cams in place (DOHC EJ) lag Legacy Forum 8 03-05-2005 08:42 PM
own your own repair shop credit xtc Tri-State Area Forum 16 02-13-2002 09:54 PM
('93-'01) Do not have your own brain? Get one for your battery then. 25psi Impreza Forum 3 04-16-2001 11:38 AM
