Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 03-27-2008, 05:46 PM   #1
Scooby41
Member#: 165375
2006 Imprezive 2.5i
Steel Gray
Default Stock sti springs on my 2.5i?
Ok i know ive heard rumors about stock STI springs being an upgrade for the forester and rs's so... i found a complete set of 06 sti springs to put on my 06 2.5i on ebay shipped to my door for 30 bucks. my questions are:
1.direct fit or some mods needed?
2.if they fit are they going to harm my stock struts?
3.if any what are my gains going to be?
4.killer deal or go with an aftermarket spring?
lookin for any type of help i can get...i really appreciate it!
Scooby41 is offline   Reply With Quote
Old 03-27-2008, 10:39 PM   #2
kxf169
Member#: 135662
2006 Impreza 2.5i
RBP black shoes
anyone have pictures of the drop
kxf169 is offline   Reply With Quote
Old 03-27-2008, 10:58 PM   #3
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
They bolt on without modification, are a great bargain upgrade, and are fine for your stock struts.
Here's an old pic of my car with '04 STi springs, back in the day
semaj is offline   Reply With Quote
Old 03-28-2008, 02:00 PM   #4
Scooby41
Member#: 165375
2006 Imprezive 2.5i
Steel Gray
aright then im good to go. thanks alot semaj.
Old 04-13-2008, 04:31 PM   #5
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Anybody have an answer to question #3?
iyzmi is offline   Reply With Quote
Old 04-13-2008, 04:39 PM   #6
nhat
Member#: 140163
03 STi
hellaflunctional
the answer to #3 is stiffer spring rates, a slight drop, and huge savings by spending only $50 for a set of sti takeoff springs.
Old 04-13-2008, 04:46 PM   #7
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
How much stiffer? How much drop? Any performance improvements?
Old 04-13-2008, 04:47 PM   #8
QuikWgn
Member#: 108557
2003 PSM WRXWgn STG2
05 OBM LEGACY SDN
increase in rate is more than 50%, drop will be less than 1/2"
QuikWgn is offline   Reply With Quote
Old 04-13-2008, 05:58 PM   #9
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
So it will 50% stiffer? That small of a drop doesn't even seem worth the effort.
Old 04-13-2008, 07:20 PM   #10
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
People don't use STi springs for the drop they use them because the stiffer rates decrease bodyroll and increase handling.
Old 04-13-2008, 07:23 PM   #11
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Drastically improve handling or just a little bit? Is the improvement in handling worth the trade off for less comfortable/stiffer springs in a DD?
Old 04-13-2008, 08:50 PM   #12
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
Well it will handle better, but on stock tires, mushy 2.5I top hats, stocks sways, endlinks etc you will not see as much benefit as if you had good tires, aftermarket endlinks etc, but it will still be ALOT better than the stock springs.
Old 04-13-2008, 08:55 PM   #13
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
I don't have stock tires. I have some Potenza RE960AS. So with just tires and springs, there will be much less body roll and much better handling? How easy is the install?
Old 04-13-2008, 09:36 PM   #14
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
What tire size are you running? For instance a 205/55/16 is going to have a lot more sidewall flex/tire rollover than say my 225/40/18's. I can tell you if you can turn a wrench and have jack stands etc probably 2-4 hrs. Took about 4 to swap struts/springs on my 03 with plenty of bs'ing, smoke breaks, lunch breaks etc. Set aside the afternoon. Having an extra set of hands to get the struts back in will considerably shorten the reinstall time.
Old 04-13-2008, 09:48 PM   #15
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
Stock size. Is there anything particularly difficult during a spring install? Is there a tutorial somewhere I can look at? Thanks for your help man!
Old 04-13-2008, 10:08 PM   #16
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
If you're new to this rent/borrow a spring compressor from your local nationwide autoparts chain. Have a BIG breaker bar handy, and a good torque wrench, airtools helpful.
http://forums.nasioc.com/forums/show....php?t=1471756
Old 04-14-2008, 12:34 AM   #17
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
They will physically fit everything you have now. However, I would place upgraded struts in the "mods needed" column
Due to the fact that the springs are both lower and stiffer than your stock springs, the USDM STi take offs will shorten strut life as compared to strut life with the stock springs. However, considering that they aren't stupidly low and they're not stupidly stiff, it's not like you're going to kill the struts this month.
The primary benefit to any increase in spring rate is the ability to take advantage of stickier tires, which means you'll be faster once you get stickier tires. All the other effects are just things that make you smile.
Killer deal. USDM STi take off springs are the best springs for someone who is looking for performance (not looks) and isn't going to run r-comp or stickier tires.
I own an RS and I have USDM STi springs (and upgraded dampers) on it. I LOVE it. That being said, you're going to be VERY underdamped with the STi springs on RS struts. This will definitely prevent you from seeing the full benefit of the springs and, depending on your personal tastes, may make the ride feel like crap (improper damping bothers me more than high spring rates, some people are the other way around).
Old 04-14-2008, 11:29 AM   #18
Naito
Member#: 114263
2006 Impreza 2.5i
willaty, what struts are you running? Tokico D-Specs?
Naito is offline   Reply With Quote
Old 04-14-2008, 12:46 PM   #19
QuikWgn
Member#: 108557
05 OBM LEGACY SDN
^^^yes...same ones I run, from there our setups differ.
Old 04-14-2008, 12:50 PM   #20
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Originally Posted by ButtDyno
This is the suspension tech forum, where show cars go to die.
2005 Impreza 2.5RS Wagon in Regal Blue Pearl
Basic Suspension: USDM STi Springs, Tokico D-Specs, PolTec Heavy-Duty Endlinks, Whiteline 22mm Adj RSB, Whiteline QR Rear STB, GT-Spec ALK, Whiteline Max-C Motorsport camber plates
Bushings: Full STi Group N Lateral Link, Trailing Link, and Rear Strut Mount Set, Kartboy Tranny Crossmember, TiC Comfort Rear Diff, Whiteline Steering Rack, Interestingly Hacked Outrigger Bushings
Competition: Primitive Racing 3/16ths Front Skidplate and Rear Diff Protector, Alfa Club Rally Odometer/Chronometer
Powertrain: Stromung Stainless Steel 2.25" Midpipe, DIY Ghetto-rific Catch Can, Group A Performance Lightweight Crank Pulley, Hybrid Silentake, Group A Performance Throttle Body Spacer, RomRaided
Electronics: Hawker Odyssey PC-680MJT Battery, Hella Rallye 1000 FF Driving Lights, Hella Micro DE Fog Lights, Rear Deck Light Addition, Map Light Addition, Hella Supertones, Innovate Motorsports LC-1 WBO2, OMGHAX! AFR Gauge
Rolly Bits: Summer-16" OEM wheels in Falken FK452s | Winter-16" OEM Wheels in Hankook Icebear W300s
Body: Front Grille Center Pillar Delete, DIY Big Assed d@mn Serious Rally Style Mudflaps, Obsessive Amounts of RAAMmat and Ensolite, Polyurethane front lip
ICE: Pioneer DEH-3900MP, Pioneer CD-IB100II iPod Controller, Pioneer TS-D161R 6-1/2" Kevlar 2-Ways
Interior: DIY Hypoallergenic Cabin Air Filter, GC-Lock, S204ed Center Console
Easiest way to answer your question.
Old 04-14-2008, 01:29 PM   #21
Naito
Member#: 114263
2006 Impreza 2.5i
great, thanks. I'm currently running JDM STI takeoffs on my stock 2.5i struts, nice and stiff but feels floaty at times, so have been planning getting the Group-N tophats and Tokicos. Good to hear they seem to be approved
AGX struts and STI springs on a 2.5I woods Brakes, Steering & Suspension 19 07-06-2008 05:40 PM
AGX struts and STI springs on a 2.5I woods Brakes, Steering & Suspension 1 07-04-2008 05:17 PM
(07) STi springs on (07) 2.5i stock system? ScubaruImpreza05 Brakes, Steering & Suspension 1 05-04-2008 10:53 AM
V7 STI Springs on 06 2.5i Naito Brakes, Steering & Suspension 12 07-29-2007 06:16 PM
TEIN '06 STi Springs on '06 2.5i? Plutonium2.5i Brakes, Steering & Suspension 1 02-10-2006 09:00 AM
