Old 03-27-2008, 08:00 PM   #1
thunder_lizard_1976
Member#: 145642
2007 WRX Ltd
Cuz Chicks Dig The Wagon
Default Hella Supertones install question
Got em all snug mounted in behind the grille on my 07 pignose.. now comes the wiring, and the question..How many of you have simply unhooked your stock horns, and wired the feed directly to the Hellas, making them your main horns, and are there any issues with amperage/ draw/ blowing fuses?
thunder_lizard_1976 is offline   Reply With Quote
Old 03-27-2008, 10:13 PM   #2
1sick07
Member#: 136766
2011 STI Sedan
SSM
You won't get them to full potential without the relay. Do a search for a DIY install. OR you can read the box which is what I did. I have the stock ones PLUS the two Hella's.
1sick07 is offline   Reply With Quote
Old 03-27-2008, 10:58 PM   #3
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
you can just wire in each hella to the factory plugs then run a ground to each horn , no amp drawage probs, if you opt to use the factory horns "plus " the hellas then yes wire the relay set up accordingly
sense of nature is offline   Reply With Quote
Old 03-27-2008, 11:28 PM   #4
LightWerkz
Member#: 125432
2004 E46 M3
http://lightwerkz.net
You can DIY or buy one of our premade custom fitted wiring harnesses.
LightWerkz is offline   Reply With Quote
Old 03-27-2008, 11:41 PM   #5
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
I've had mine hooked to my stock wiring for about four years with no problems. I will probably eventually upgrade the wiring though along with a relay.
Hank3 is offline   Reply With Quote
Old 03-27-2008, 11:52 PM   #6
Matt92530
Member#: 94085
2009 BMW 335i
Cloud Gray
I made my own harness but just plugged into the stock horns.
Matt92530 is offline   Reply With Quote
09 wrx hella supertones install question punjabi408 Newbies & FAQs 21 08-23-2010 01:28 PM
hella supertones install question krambte79 Electrical & Lighting 8 04-17-2007 11:30 AM
HELP....another hella supertone install question wrxsown Electrical & Lighting 6 07-25-2006 01:44 AM
Hella Supertone Install Question USF97J4x4 Interior & Exterior Modification 9 12-31-2005 10:17 AM
Got question about Hella Supertone installation in a GC8 edkwon Mid West Subaru Owners Club Forum -- MWSOC 17 09-10-2002 01:11 AM
