Old 03-27-2008, 10:37 PM   #1
04blckwrx
Member#: 141556
2004 wrx
java black pearl
Default closing IWG on 16g?
Hi, I was wondering if anyone knew how to close the internal wastegate for a standard size 16g? I tried asking grimmspeed about if they had a bracket but, they siad they didnt, and the closest one would probly be the DB 20g bracket.... My questions are..
1) Would the 20g bracket fit?
2) If it doesn't, What is another way to close up the wastegate. please post any link/tutorials.
04blckwrx is offline   Reply With Quote
Old 03-27-2008, 11:08 PM   #2
hypoxvi
Member#: 173002
like permanently?
hypoxvi is offline   Reply With Quote
Old 03-27-2008, 11:10 PM   #3
04blckwrx
Member#: 141556
2004 wrx
java black pearl
yes, is there any other way instead of wielding? for example block the holes with bolts?
Old 03-27-2008, 11:11 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
Originally Posted by hypoxvi View Post
like permanently?
bad
unnecessary
idea
a bracket is easy to make
there are seveal ways to go about it that have been posted
Arctic Penguin is offline   Reply With Quote
Old 03-27-2008, 11:12 PM   #5
hypoxvi
Member#: 173002
i was going to suggest welding it. i don't know of any other way.
Old 03-27-2008, 11:15 PM   #6
04blckwrx
Member#: 141556
2004 wrx
java black pearl
b/c looking at grimmspeed brackets, it seems all they did was bolt a bracket to the open holes, with no wielding at anything so i was just wondering if i would be able to do the same thing without wielding or the bracket... =/
Old 03-28-2008, 09:38 AM   #7
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
a6n6d6y is offline   Reply With Quote
Old 03-28-2008, 09:51 AM   #8
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
You can simply have the arm tacked in place on the flapper's external housing where the actuator arm connects. This way you can just remove the tiny tack weld and its a functioning IWG again. If you don't want that then you can clip it.
Or that bracket Andy has looks pretty good as well.
4ST-AIR is offline   Reply With Quote
Old 03-28-2008, 10:01 AM   #9
2.5rsDOHC
Member#: 54820
1998 2.4 RS-T
hybrid\stroker
Im wanting to do the same to by big 16g but from what Im hearing th smartest thing to do is just weld the flapper shut and with a large enough bead to work the first time
for some reason my turbo is only boostin 14lbs no more no less so Im kinda stuck with having to do it this way
but from what other threads have said that if you use just the bracket (in certain cases) that you will get a metal on metal clanking noise and its your flapper moving around
2.5rsDOHC is offline   Reply With Quote
Old 03-28-2008, 10:17 AM   #10
a6n6d6y
Member#: 123347
1993 POS
burgandy legacy
are you referring to this
http://forums.nasioc.com/forums/show....php?t=1479547
When I went EWG on my setup, we welded the IWG arm in place like most do and thought that would be enough. Started the car and heard a loud clanking noise, definitely metal on metal, and tried to think what it could be
So word of advice to those going EWG and thinking about using a bracket or just tack welding the arm in place, or if you hear loud metal on metal sound after locking the IWG--- it is probably this iwg flap coming loose.
Old 03-28-2008, 12:23 PM   #11
Arctic Penguin
Member#: 119532
2006 WRX
if you do something dumb like welding the wg
you have destroyed the possibility of reversing yor decesion
a bracket is bloody bleeding simple
if you can not think your way through making a bog simple bracket for the wg
you shouldnt be modding in the first place as fabrication
even this kind of stupid simple fabrication
is the heart of REAL modding anything
Old 03-28-2008, 01:19 PM   #12
Nuke209
Member#: 108089
2003 WRX
NF Performance
have someone fab up a bracket
Nuke209 is offline   Reply With Quote
Old 03-28-2008, 01:53 PM   #13
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
do like testes did in this thread:
and put a bolt through the flange on the HKS DP to hold the flapper shut. That's what I'll do when I go EWG
quadtard is offline   Reply With Quote
Old 03-28-2008, 01:59 PM   #14
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
There are hundreds, if not thousands of people who weld the wg closed including myself....Obviosuly once you weld it you cant go back, but its also a great way of making sure nothing will go wrong with it...
If you want to make sure everything works the first time just get it welded, If for some reason you would want to go backwards on your 16g set up, tons of people will trade plus cash for an ewg set up.
Cards2323 is offline   Reply With Quote
Old 03-28-2008, 03:17 PM   #15
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Thats not true at all. Yes if you have the IWG flapper welded on the exhaust port yes theres pretty much no turning back.
If you tack the arm on the housing then you can reverse that with a little chisel and heat.
^^^Links dead
Old 03-28-2008, 04:49 PM   #16
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
^^^ I just think if you do it, you should do it right, there are many methods but as far as im concerned welding will be the "best" as you can be assured it will work 100% all the time
Old 03-28-2008, 04:58 PM   #17
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
^^^Links dead
Fixored!
And here it is again
Old 03-28-2008, 05:51 PM   #18
Arctic Penguin
Member#: 119532
2006 WRX
i guess this is why this is the noob forum
so lots of bad ideas can be spread around
Old 03-28-2008, 05:55 PM   #19
quadtard
Member#: 104206
2004 WRX
Tunnel Ram Gray
you calling the idea I linked to a bad idea?
Old 03-28-2008, 06:17 PM   #20
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
Sorry, but..........
welding FTW
and YES it can be reversed, if its done RIGHT
v8eaterWRX is offline   Reply With Quote
Old 03-28-2008, 06:22 PM   #21
Cards2323
Member#: 142868
2014 BRZ LIMITED
Satin White Pearl
So bad ideas can be spread around?? Its a matter of opinion first of all, one way isnt "better" than the other but you cant say welding is a DUMB idea just because it cant be reversed.....So is it now a bad idea to bore a motor because it "cannot be reversed"
Old 03-28-2008, 06:33 PM   #22
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
HORRIBLE IDEA
How To: Close IWG SpoolinPA Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 01-13-2007 02:01 PM
Close Call on the Savage River (pinned my kayak on a log sieve) Mike Wevrick Off-Topic 14 05-31-2006 09:46 AM
More info needed on 16G AlboWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-18-2005 02:49 PM
Bolt-on 16G Turbo nicd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-06-2003 09:04 AM
bolt on 16g?? scoobin' Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-28-2002 02:52 PM
