Old 03-28-2008, 07:57 PM   #1
EJ20_lee
Member#: 106799
2004 built 257 tomei
powered ^.^
Default my rear differential filler hole won't open
its all rusted and i tried to use breaker bars too but its not moving!!
do i have to change hole cover with sensor?
help me
EJ20_lee is offline   Reply With Quote
Old 03-28-2008, 08:17 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
use an impact wrench... I've seen bolts that would round out or break off when using a normal wrench, but the sudden shock from an impact wrench breaks the rust off instantly.
Old 03-28-2008, 08:30 PM   #3
mikeythejew
Member#: 141672
Spray PB blaster on it and wait 1/2 an hour and retry. Also try to tighten it 5 degrees and then loosen it.
mikeythejew is offline   Reply With Quote
Old 03-28-2008, 09:55 PM   #4
BillJC
Member#: 31002
Try tightening it a little. Sometimes that allows it to break free. Also, might want to give it a little heat and use an impact gun. After that, remember when you reinstall the plugs, anti-seize is your friend.
BillJC is offline   Reply With Quote
Old 03-28-2008, 11:15 PM   #5
nardvark
Member#: 145108
2002 Impreza TS
It took me many applications of PB blaster, getting the rear wheels up on ramps, and putting my whole body weight onto the end of a 25" breaker bar to get mine to budge.
The car had ~70k and it hadn't ever been removed, so the factory sealant was stuck on pretty good.
nardvark is offline   Reply With Quote
Old 03-28-2008, 11:40 PM   #6
p01ntb1ank
Member#: 134299
i used a breaker bar and a floor jack on the breaker bar and it broke it loose
p01ntb1ank is offline   Reply With Quote
Old 03-29-2008, 12:01 AM   #7
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Yeppers....
Or a variant of the above...insert your breaker bar with the car on a jack. Release jack and let the car's weight do the work!
Old 03-29-2008, 01:22 AM   #8
sigurd
Member#: 128721
2002 impreza WRX
psm
hit it with a hammer and brass punch around the outer edge before the impact.
sigurd is offline   Reply With Quote
Old 03-31-2008, 09:59 PM   #9
EJ20_lee
Member#: 106799
powered ^.^
if i use impact! there is slight chance to break wholediff cover right?
Old 03-31-2008, 10:13 PM   #10
Ryanr1490
Member#: 149267
2002 6-speed wrx
psm
Heat around it untill its red hot, then use the impact. it will come out guarenteed.
Ryanr1490 is offline   Reply With Quote
Old 03-31-2008, 11:52 PM   #11
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
very, very, very unlikely - an impact wrench should make short work of it.
Old 04-01-2008, 12:00 AM   #12
rkramer
Member#: 118209
2015 WRX Limitec
an impact wrench will put ALOT less stress on the entire housing then doing it a slower way. (aka you have a higher chance of breaking the housing by using a jack or the car's weight)
Old 04-01-2008, 04:20 AM   #13
specialev
Member#: 90156
1986 Syncro Vanaru
07 SV650
I had to use the breaker bar with all 4 feet of the jacks handle to get that damn thing off my 2002 WRX with 60k.
specialev is offline   Reply With Quote
Old 04-01-2008, 06:35 AM   #14
mopartodd
Member#: 164929
2014 Impreza Premium
Jasmine Green Metalic
Hey, I heard World Gym is running a special this week.
But seriously, just try the impact.
mopartodd is offline   Reply With Quote
Old 04-01-2008, 11:45 AM   #15
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Only way I could get mine loose. Worked like a charm. I second the "anti-seize is your friend" comment. Last time I took it out without any problems. Also, don't take out the drain plug first. Fill plug first, then drain plug. RP
drivin blind is offline   Reply With Quote
Old 04-03-2008, 02:34 PM   #16
Asinine
Sufficient for Sharky
Member#: 55173
with paddles.
Yeah, I changed my fluid at 30k miles and got it open no sweat with just a breaker bar. Then three weeks ago I tried to change it again, and couldn't get the drain open. We tried breaker bars and an impact wrench set to 120psi. No joy.
Asinine is offline   Reply With Quote
Old 04-03-2008, 04:47 PM   #17
ULTIMATETOOLCO
Member#: 165370
2007 WRX
www.ultimatetoolco.com
We agree most have not seen negative effects by using an impact tool on it, but we highly recommend using the proper socket for those differential plugs with hand tools and a breaker bar. Our customers have found our KTC 13mm differential socket extremely helpful for those diff plugs as opposed to jamming a 1/2" drive end to remove both the filler plugs and the drain plugs.
I understand the OP was specific in having trouble with the filler hole on an STI which has the temp sensor, but strangely we have sold to STI customers who for some reason have no sensor there, just a standard square plug, probably due to second hand vehicle purchase mishaps, so I thought this info would be valuable.
ULTIMATETOOLCO is offline   Reply With Quote
Just got my rear differential swapped out under warranty.... what could this sound be innova Brakes, Steering & Suspension 5 01-12-2007 09:15 PM
My rear differential is starting to tick me off Lachlan Transmission (AT/MT) & Driveline 4 06-17-2006 07:32 PM
Just changed my rear differential oil and noticed it was overfilled volkl23 Transmission (AT/MT) & Driveline 10 04-13-2005 05:09 PM
I think my rear differential is shot taeyax82 Subaru Conversions 16 02-04-2005 11:40 PM
Did i hurt my rear differential? WRX-p1l0t Transmission (AT/MT) & Driveline 4 06-27-2003 11:15 AM
