Old 03-29-2008, 12:15 PM   #1
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
Default gas light comes on early
lately my gas light has been coming on early. like i mean real early. 3/4s of a tank half tank. it will eventually shut off but i still dont think it should be happening. it started to do it at about 1/4 tank of gas and has progressively started to come on earlier. i did get rear ended on my gas tank side a few weeks ago. it came on early before that but after the accident is when it started to come one at like 3/4s of a tank. any ideas?
hockeygm is offline   Reply With Quote
Old 03-29-2008, 01:33 PM   #2
dcpatters
Member#: 125278
2011 X MR
AS
Possibly the fuel float on the assembly. Perhaps got whacked when the rear was impacted? Are you handy with a wrench? Could remove the fuel pump assembly and check.
dcpatters is offline   Reply With Quote
Old 03-29-2008, 07:58 PM   #3
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
yea i am pretty handy with a wrench. i installed the fuel pump so it shouldnt be a big deal.
Old 04-01-2008, 01:10 AM   #4
plode
Member#: 116910
I have determined mine comes on with about 4 gallons left in the tank. I hit the gas station a few miles after it came on(2 miles or so) and it took 11.7 gallons. 15.9 gallon tank, 11.7 gallons to fill,=4.2 left in tank.
That seems like a bit much to me, at just over a third of a tank.
Then again, when I do fill it, it goes up past "F".
plode is offline   Reply With Quote
Old 04-01-2008, 09:36 PM   #5
08EJ25
Member#: 174022
2008 WRX
Lightning Red
Mine comes on at about the same point. Takes just about 13 gallons to fill it up on a 16.9 gallon tank. AT this point I just know that I still have plenty of gas once the light comes on.
08EJ25 is offline   Reply With Quote
Old 04-02-2008, 08:41 AM   #6
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
mine used to come on with like 1.5 gallons left. and it was that way for a while and its gottne worse.
Old 04-02-2008, 09:36 AM   #7
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
Mine is kind of weird. I'm not sure if my fuel sending unit is bad, but if i'm driving long distance and run low on gas, the light will come on when the needle is about a needle's width above the E line. However, if I'm driving under 20 miles, the gauge will run all the way down BELOW the E line and the light will not come on, but then next time I start the car it will be on.
And it pisses me off how long the needle takes to respond to a full tank. Takes 60+ seconds for it to go from E to F upon startup after filling the tank.
anickode is offline   Reply With Quote
Old 04-07-2008, 01:05 PM   #8
ALB03WRXwagon
Member#: 172668
03 WRX wagon
Sedona Red pearl
This doesn't answer your question, but my 03 wrx wagon's fuel light comes on the second the needle touches the e, and I'll have about 3 gals. left. Just FYI
ALB03WRXwagon is offline   Reply With Quote
Old 12-03-2008, 04:49 PM   #9
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
Bump for an early low fuel warning light at 1/2 a tank. It went off again within maybe a minute of the engine running. This was one of the colder mornings we've had so far this winter, and I've been in warmer climes for the past several years. Could the cold have caused the light?
flyboymike is offline   Reply With Quote
Old 12-03-2008, 10:47 PM   #10
rick-l
Member#: 33868
2003 wrx
srp
From the car information manual
The low fuel warning light operates as follows:
The combination meter CPU continually monitors the resistance signal from the fuel level sensor. It turns on the low fuel warning light if a resistance value corresponding to the critical fuel level (approx. 78 ohms) is detected successively for about 10 minutes or the period spent for driving a distance of 10 km.
The main sensor is 0 ohms full and 51 ohms empty.
The sub sensor is also 0 ohms full and 43 ohms empty.
They are connected in series so the value presented to the meter is the sum.
Does your guage vary linearly from full to empty?
rick-l is offline   Reply With Quote
Old 12-09-2008, 07:08 PM   #11
flyboymike
Member#: 83765
2005 WRX wagon
WR Blue
It's pretty linear, yeah. Hasn't happened again in the past week.
Gas light comes on early Cakesniffer Service & Maintenance 2 01-08-2009 01:38 AM
Gas light comes on too soon 06AWD Service & Maintenance 22 03-20-2008 08:51 AM
when does your gas light come on? Horten Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-18-2004 10:49 PM
How much gas is left when the low gas light comes on? catass STi Forum Archive 11 06-30-2003 06:21 PM
check engine light comes on at low gas? halftendril General Community 1 11-28-2002 02:49 AM
