Old 02-16-2002, 03:25 PM   #1
tailout
Member#: 6152
2005 STi
Question SPO front sway bar question!
I put on the SPO front and rear (adj.) sway bars and WOW,
what a difference!! perfectly balanced with the rear set on the first(softest) hole! But...I could not get the front to mount in the same stock orientation;stock links go up from the suspension, in this configuration the sway bar rubbed the stearing arm/link.I swapped the sway bar around and hooked up with the links going down from the suspension (slightly exposed) seems to work fine...won three scca events...just wondering if this is O.K.
The fine folks at SPO were no help at all on this..Am I the only owner of SPO front and rear sway bars?
tailout
tailout is offline   Reply With Quote
Old 02-16-2002, 04:31 PM   #2
kelley
Visiting NASIOC Timeout
Member#: 5681
94 legacy turbo
04 sti
I have this set up as well. I did not install it though. is the hole closer to the front of the car 22 mm (the softest setting) couldn't remember. thanks,kelley
kelley is offline   Reply With Quote
perrin front sway bar question wrxprowler Brakes, Steering & Suspension 3 08-29-2006 12:45 AM
Front sway bar question Imprezanize Brakes, Steering & Suspension 7 11-21-2005 06:35 PM
Front sway Bar question Cerum Brakes, Steering & Suspension 21 08-15-2003 12:51 PM
Front sway bar question... Bionic Mid West Subaru Owners Club Forum -- MWSOC 5 03-17-2003 10:56 PM
Front sway bar Question (I did a search) Impreza Rider Technical Forum Archive 2 09-18-2000 07:41 AM
