Old 03-30-2008, 03:23 PM   #1
rs2.5-3.0
Member#: 52933
2008 LGCY2.5iSE.5.mt
want to do an STi conv ;)
Question Legacy 2.5i exhaust options
Just curious as to what will work for a 2008 Legacy 2.5i?? Any issues w/ CEL?
Any NA headers out there? i hear that GT exhausts (mufflers) should bolt up to the 2.5i's. Can anyone confirm?
Thx,
Brian
rs2.5-3.0 is offline   Reply With Quote
Old 03-30-2008, 05:08 PM   #2
penguin311magic
Member#: 172953
2007 Impreza 2.5i
Newport blue
go to boxer4racing.com. The Borla headers might work as long as you get the high flow cat and the borla hush catback. But ask them first
penguin311magic is offline   Reply With Quote
Old 03-31-2008, 02:36 AM   #3
PA-Outback2000
Member#: 161832
2000 Outback Limited
also from boxer4racing, check stromung. when u add headers, u may throw a CEL. just doing cat and catback won't. i have a random tech cat and stromung exhaust on mine and love it. see what they have for the 2008's though.
PA-Outback2000 is offline   Reply With Quote
Old 03-31-2008, 02:23 PM   #4
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
installing a HFC won't throw a CEL? are you guessing? New cars are VERY sensitive emissions wise, alot more so than your '00. I believe 07-08 legacy's are PZEV rated and a HFC could easily throw a CEL.
Furthermore these car's can't be open sourced tune yet as they are CAN-BUS (essentially OBD 2.5), although I think the ROMraider guys are working on it as we speak.
LTracer is offline   Reply With Quote
Old 03-31-2008, 05:08 PM   #5
rougeben83
Member#: 115154
2003 Legacy L Turbo
His car has the factory EL header like the other 2.5i's, and he'll need to get his catback midpipe re-bent to fit the older style HFC. Using the catback for an LGT would probably be your best bet if you want something premade (still need to have it modified to fit the HFC).
Also check how many 02 sensors you have. The headers from the older cars don't have 02 sensor bungs on them; I think the new Legacy 2.5i's at least have 2 02 sensors on the headers that you'll need to have bungs welded on for.
Pics from a 2.5i Legacy (actually these are my headers when installed by the previous owner)
rougeben83 is offline   Reply With Quote
Old 03-31-2008, 07:50 PM   #6
penguin311magic
Member#: 172953
2007 Impreza 2.5i
Newport blue
Yea, with the newer models, you need to get the HFC for the whole setup to bolt on. I'm scared to do it now, even though I have the cat-back sitting in my room :-(
Old 04-01-2008, 03:59 AM   #7
PA-Outback2000
Member#: 161832
my bad... thought the 8 was a 0. yes the new ones are more strict.
Old 04-04-2008, 07:40 PM   #8
rs2.5-3.0
Member#: 52933
so i'm screwed as far as just bolting up a header and calling it a day. damnit.
i know power isn't going to be made but i want the rumble back.
Old 04-04-2008, 08:06 PM   #9
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
GT mufflers will bolt on. The centre pipe looked like it would fit, but I was too cheap to buy a new donut gasket so I did not try.
I did bolt on the GT mufflers to the wifes Legacy though. Looks nicer, might be a tiny bit throatier, but that could just be me justifying the ten minutes I took installing it
Old 04-05-2008, 05:12 AM   #10
PA-Outback2000
Member#: 161832
headers should work. try borlas. stromung or any other catback should just bolt up. check boxer4racing.com to make sure they still do exhausts for ur year. i think their's were dual-tip mufflers, but can do single tip if u really wanted to.
Old 04-05-2008, 01:55 PM   #11
rougeben83
Member#: 115154
2003 Legacy L Turbo
Right, you basically need to get the catalytic section from an older car and rework how your catback mates up to it.
The pic I posted, that's pretty much what the guy did.
2007 legacy 2.5i Exhaust? Loopis Tuning Legacy Forum 4 04-01-2010 03:42 PM
2007 legacy 2.5i Exhaust? Loopis Tuning Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-31-2010 03:28 AM
07 2.5i exhaust options bmw50021 Normally Aspirated Powertrain 40 05-13-2008 05:12 AM
Differences between Legacy 2.5i special ed. & Outback 2.5i Limited? left footed whooten Legacy Forum 2 08-03-2006 06:10 PM
Q: which brand or which type exhaust would good for legacy 2.5i? EJ20(GDB) Legacy Forum 1 11-08-2005 12:52 AM
Message Board Statistics All times are GMT -4. The time now is 10:12 AM.
