Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 03-30-2008, 05:50 PM   #1
IIdiceII
Member#: 90438
Default Perrin EBCS CEL problems, help?
I recently got rid of the stock bcs when I upgraded my turbo again. right now im running a limp map from dave brown and I threw the ebcs on. I plan'd on having it on and just disconnecting it till I get tuned and run wastegate boost. Im running an avo450 turbo with a 15psi spring.
anyways, I installed the ebcs following instructions from perrin. installed it in intterupt mode (spelling?)
connected the wires to the stock wiring, cap'd the solenoid hose on the turbo inlet and no matter what i do...I keep getting the p0246 code...question, is this something that he can change when hes tuning it? I emailed dave but havent gotten a reply because hes super busy and its not a huge deal right now.
also, when i disconnect the ebcs, i instantly get the p0245 code and i tested the solenoid on the battery and it clicked so it def works.
IIdiceII is offline   Reply With Quote
Old 03-31-2008, 03:07 AM   #2
IIdiceII
Member#: 90438
bumppp
Old 03-31-2008, 10:07 PM   #3
IIdiceII
Member#: 90438
bump it again...why not
Old 04-01-2008, 02:52 PM   #4
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
I thought you were only supposed to install an EBCS right before a tune, so the tuner can set it up properly. I haven't gotten a pro-tune yet, but have a Perrin EBCS...I was specifically told to NOT install it before I am at the tuner shop.
Sorry I can't provide any advice, hopefully someone can.
REXtard04 is offline   Reply With Quote
Old 04-01-2008, 03:36 PM   #5
IIdiceII
Member#: 90438
i know that...this isnt why youre not supposed to install it though...it throws everything outta wack and its dangerous to run cause you'll see a lot more boost sooner and will hurt your motor. mines not doing that lol
Old 04-02-2008, 08:20 AM   #6
REXtard04
Member#: 112928
2004 WRX Sedan
WR Blue
oOOh, ok....sorry, I'm new to the EBCS, this will be the first time I've even messed with it. Have you tried calling Perrin or just a local tuner to find out what's up with it? Maybe something faulty internal?
Old 04-02-2008, 10:32 AM   #7
IIdiceII
Member#: 90438
im waiting on a reply from perrin and my tuner
Old 04-02-2008, 01:52 PM   #8
IIdiceII
Member#: 90438
oh and today, somehow i threw the p0246 CEL again but the solenoid isnt hooked up. does that make sense?
Old 04-02-2008, 06:33 PM   #9
Chino Bling
Member#: 129743
2009 335i
Jet Black
what's the code for?
Chino Bling is offline   Reply With Quote
Flashing CEL problem.. help! LuckyStar Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 06-18-2010 07:37 PM
CEL problems help (searched already) samuraiRS Normally Aspirated Powertrain 14 02-15-2010 09:11 PM
Perrin BIGMAF CEL problem weggy Newbies & FAQs 6 07-15-2009 12:41 AM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
CEL Problems........... HELP!! brokemypiston Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-02-2006 10:39 PM
