Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 02-16-2002, 06:20 PM   #1
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Default PE fuel pump dies - POS - need info on supra pump
Went to start up my car to go get some c16 gas this afternoon - it was dead - no fuel prssure
The POS bomb maker PE pump was dead - -
And that dude with the thread on the loose terminals was right - the stock pump connections are tight as can be - but the pe pump connector was loose and shaking about
I can't believe these things only last a few months !
Now I am screwed and cant go racing becuase I put the stock fuel pump back in and it cant hold enough pressure on top to make the right power
I need a supra pump - anyone know a vendor who has one in stock ????
Thanks !
(Welcome to motorsports)!
alfriedesq is offline   Reply With Quote
Old 02-16-2002, 06:35 PM   #2
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
That $ucks. Luckily it didn`t decide to die in the mid of the 1/4 mile. That would have been messy.
Good luck.
Bill
gossamer_monster is offline   Reply With Quote
Old 02-16-2002, 07:55 PM   #3
Bighurt1
Member#: 6952
2002 A sedona Blur..
1FSTBXR4(w/fubared clutch
try a guy on here by the name of bottle.....he has them for about 250 I believe
Bighurt1 is offline   Reply With Quote
Old 02-16-2002, 08:16 PM   #4
IMPREZIV
Member#: 862
Call Adam
Good luck
IMPREZIV is offline   Reply With Quote
Old 02-16-2002, 10:47 PM   #5
Avenger
Member#: 1234
Somone posted the supra pump number a while ago. It was # 23221-46110 just ask goto a toyota dealer for it. This number was for a last gen impreza, not sure if it will fit a wrx. Hope this helps.
Avenger is offline   Reply With Quote
Old 02-16-2002, 11:01 PM   #6
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
Default Re: PE fuel pump dies - POS - need info on supra pump
Thanks !
Al, I am the dude that posted the problem with the PE pumps.
I bet its not blown. To test it hook wires directly from the pump to your battery or power supply... Caution! Dont run the pump for more than a few secs. The fuel cools and lubricates the pump...
If it works redo the connectors and put it back in. MY car did the exact same thing on the F*&^ Highway. I had to have a friend tow me home. Once I had solid connections I had no issues. The PE pump might have the connector problem BUT... It fits and takes the stock pick up tube.. The supra pumps input is at an angle so you will run out of fuel before the light comes on..
Did you do anything about the stock FPR and rails?
CT
AZScoobie is offline   Reply With Quote
Old 02-16-2002, 11:10 PM   #7
nmyeti
Member#: 4980
The Supra pump will take the stock pickup as well... You do have to modify the tube on the pump housing, but with a little work the supra pump will fit like a charm.
We take a dremal tool to the stock sock, just grind off just a little of the lip that keeps the stock sock from fitting the supra pump. Its a simple 2 minute process, and then you have the best of both worlds. Lots of fuel flow (255l/h) and limited surge (just like stock).
My next mod is to get a surge tank anyway though, because id like to have a little better ability to run with low fuel at the track.
the STI surge tank, and the supra pump might be the way to go.
-Nathan
nmyeti is offline   Reply With Quote
Old 02-16-2002, 11:12 PM   #8
AZScoobie
Member#: 8785
02 c_turner@ix.
netcom.com
-Nathan
Nate. Is the input tube to the pump at an angle??? I thought that was the issue. Does the screen rest on the bottom of the tank? I too would like a surge tank as I road race. I am thinking of ideas. I saw a good FAQ on dsm.org about a total system upgrade. Good ideas. I want to ditch those sending unit fittings.
CT
Old 02-16-2002, 11:17 PM   #9
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
same happend to me AL!, remember? We blamed the pcikup, as we fitted the pe pickup and sometime we were getting fuel surge, and it lasted only in 2 months, we got the new one, I did not put the PE conector, we fitted it now to a sti surge tank (just a plastic fancy and expensive device) and no troubles untill the moment`, next week will try to tight those conectors better...
ADAM is the guy to talk, seriour power leads to the BIG denso fuel pump, wich I think is something aorund 500$ and it`s good for like 800-1000HP.. just enough flow.. eh!
See ya! I hope you are doing well...
DJ
DJIMPREZA is offline   Reply With Quote
Old 02-16-2002, 11:26 PM   #10
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Does anyone know if the supra pump fits the stock wiring plug snug ?? OR do you need to sut the wires like the PE pump ??
Old 02-16-2002, 11:39 PM   #11
nmyeti
Member#: 4980
CT
The parts on the pump sits in almost the exact same place as on the stock pump. The issue is that the supra sock comes off at a dead 90 degree angle from the supra pump. This leaves it out of the fuel in an under 1/4 to 1/8th of a tank situation.
When you try to push the stock sock onto the supra pump, if you look close enough you'll notice that the plastic lip on the stock sock keeps it from pushing all the way on.
Trim this lip just a little bit and you have "stock like" fuel pickup, with the larger pump.
You will also have to trim just a little bit of the factory feed tube that the pump mounts to in order to get everthing to fit back nice a tight. But thats pretty easy.
I still think i want a surge tank because i DO not want to ever run out of fuel under boost.
Al,
The supra pump has studs that the wires mount to... Pick up a few nice Male/Femal connectors and cut the stock plug off the pump assmebly.
Use some extra wire and the Male Female connectors to lengthen the stock power wires, then get the right nuts and connectors for the studs on the pump.
Pretty easy stuff... We did it on Max's car in less than an hour start to finish.
-Nathan
Old 02-16-2002, 11:46 PM   #12
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Thanks for the information
Nathan - do you run the supra pump or the pe pump>?????
Looks like the supra pump will be my next pump
Its so frustrating to have something so small as this interfere with my crazy plans on the 1/4 mile dance floor - quess its time to visit my toyota dealership
Old 02-16-2002, 11:54 PM   #13
nmyeti
Member#: 4980
i run the surpa pump... don't bother with the toyota dealer unless you are going to try to get on in the morning. Usually they don't keep these in stock though. You might want to talk to adam, he usually has a few around.
-Nathan
Old 02-17-2002, 12:05 AM   #14
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Thanks for the info again - I'll try adam then and see if he's got one
BTW - does anyone sell the PE pump except for Jan Shim - he is out of stock !
Old 02-17-2002, 12:27 AM   #15
Tuning Factory Inc.
Vendor
Member#: 3600
I do Al. I have some on their way. Should be here in the next few days.
Tuning Factory Inc. is offline   Reply With Quote
Old 02-17-2002, 12:40 AM   #16
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Great news Dan - PLEASE hold on to one for me !
Old 02-17-2002, 12:44 AM   #17
nmyeti
Member#: 4980
You planning to run another PE?
-Nathan
Old 02-17-2002, 01:50 AM   #18
Romanikque
Member#: 7675
Check out the DSM club deal on the pump at partznet.com. I dont think your going to find it for less than that.
-MAX
Romanikque is offline   Reply With Quote
Old 02-17-2002, 02:13 AM   #19
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
-Nathan
Well I love PE stuff
Also seriously thinking of the supra pump
If I get the supra pump then I also have to re-map all my fuel enrichments to incorporate the increased flow - which may not be a bad thing (the extra capacity)
Ah decisions decisions
Old 02-18-2002, 02:14 AM   #20
SKC
Member#: 15250
I have been using a Bosch Motorsport pump designed for an RS4. It supplies 248 ltr / hr and mounts like it was designed for the WRX. Mounted in a block of fuel cell foam, it is not until the needle touches the "E" on the guage that any surge is experienced on the track. Cost was only ~AU$400 installed. I highly recommend it. Even with extreme modifications it does the business. It doesn't come with ricer stickers for the rear doors though!
SKC
SKC is offline   Reply With Quote
Old 02-18-2002, 02:25 AM   #21
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Do you have a Bosch part number?
It's probably even beefier than the pump the S4 gets here...even the S4's pump should be better than what we have.
We get no RS4
Concillian is offline   Reply With Quote
Old 02-18-2002, 10:27 AM   #22
WRC WRX
Member#: 9054
2002 Impreza Wrx
WRC WRX is offline   Reply With Quote
Old 02-18-2002, 03:42 PM   #23
Mike Rose
Member#: 10366
god / Dan:
I remember you a few years back from the H/A board (I sold my Integra Type R b/c I couldn't afford to keep replacing stolen parts). Do you still do H/A work, or have you made a complete switch to Subarus?
Mike Rose is offline   Reply With Quote
Old 02-18-2002, 08:17 PM   #24
shabby
Member#: 2682
93 Eagle Talon AWD
The supra pump flows a lot of fuel 290 lph @43psi @14v, you might need an adjustable fuel pressure regulator(not the b&m crap) because it will over-run the stock one. You'll be wasting a lot of fuel and will wonder why the car runs rich/slow.
shabby is offline   Reply With Quote
Old 02-18-2002, 10:35 PM   #25
Z1 Performance
Member#: 9327
shabby...not true on subaru's..their stock fpr's do a MUCH better job at coping with increased flow than the DSM's units do..it is one of those rare examples where Subaru has surpassed Mitsu (cough)
Granted, at Al, etc. stage of mods, a proper adjustable fpr would do a worlf of good, but only if the ecu is tuned to see it.
adam
Z-1
Z1 Performance is offline   Reply With Quote
OT: I need info on finding some info bunsfleer Off-Topic 11 04-29-2009 06:55 AM
Need info on fuel pressure regulator on 2002 WRX mathroch Factory 2.0L Turbo Powertrain 5 10-26-2007 08:56 PM
Fuel pressure regulator overrun with Walbro or Supra pump? ringmaster Factory 2.5L Turbo Powertrain 22 07-18-2005 06:58 PM
need Info on Ver6 fuel control HeMan1320 Subaru Conversions 7 04-17-2005 11:48 PM
Please,I need info on the 1414 and 1418 PE series turbos sonicowrx03 Factory 2.0L Turbo Powertrain 2 12-09-2003 11:36 PM
Message Board Statistics All times are GMT -4. The time now is 01:19 AM.
