Old 03-31-2008, 01:18 PM   #1
stiboss
Member#: 111811
98 Impreza RSTi
Default calling out all of rsti owner w full swap which suspension will fit
hi guys, i have a suspensions problem, the swap is almost done, 04 sti into 98rs, im doing the full swap, which mean 04 sti wheel hubs was used....problem now is which suspension will fit with the gc8 tophat and 04 sti wheel hubs?
need some advices
thanks in advance
stiboss is offline   Reply With Quote
Old 03-31-2008, 02:17 PM   #2
ArcticWolf
Member#: 146732
2006 Impreza 2.5i
Obsidian Black Swirl
04 is 5x100... just like the GC's are
ArcticWolf is offline   Reply With Quote
Old 04-01-2008, 10:12 PM   #3
stiboss
Member#: 111811
98 Impreza RSTi
but the Knuckles are differ
Old 04-01-2008, 10:58 PM   #4
jamesfacts
Member#: 51282
98 RS
black & blue from parking
Nope. You can use any 98 suspension you like.
jamesfacts is offline   Reply With Quote
Old 04-10-2008, 10:30 AM   #5
mr2lickit
Member#: 128888
2001 impreza rs
black
I'm interested in the same question? I've been wondering if you can use the sti shocks and springs to fit a gc8? Do you need the sti top hats as well? I found one link thats says no (link), but I've read of people who say they have made it work or maybe they didn't use everything.
mr2lickit is offline   Reply With Quote
Old 04-10-2008, 11:03 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
I run a JDM STi driveline from tranny to the Brembos.
I just my GC/GF/GM BC Racing coilovers on my spindles/knuckles. This is a JDM STi setup so it has the balljoint for steel control arms. The Spec C / USDM STi has the different ball joint for the aluminum ball joint.
FuJi K is offline   Reply With Quote
Old 04-10-2008, 11:03 AM   #7
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
don't use GD shocks on GC
yes they work, but why?? you are getting different shock travel, dampening and spring rates...
either way, you can mate GD suspension to GC using GC rear strut tops (there are some exceptions for the OEM WRX/STI shocks/springs, I don't remember exactly but they changed rear spring/top design and you can't use it no more after certain year)
Hyper is offline   Reply With Quote
Old 04-10-2008, 06:20 PM   #8
mr2lickit
Member#: 128888
2001 impreza rs
black
Wouldn't you get different shock travel, dampening, and spring rates if you went with an after market set up? Does the sti setup not work well on the gc's? I figured sti shocks would be an upgrade, but maybe thats not the case.
Old 04-11-2008, 04:17 AM   #9
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
of course you will, this is why you do research before you buy any suspension to understand what travel/bump/rates etc you need.... but do that for YOUR car, not another one
FYI I've been running GD rally suspension for a long time, and it isn't optimized for the car (less travel up front, way too long in the rear, overdampened due to GD weight etc.)
I am on full GD lower suspension bits (arms, sways) but I am going back to GC specific shocks/springs now
Old 04-11-2008, 12:31 PM   #10
bfreeskier
Member#: 104808
1998 RSTi
Hey I had full 05 sti suspension in my RSTi swap. (I swapped the whole car) the front worked well for me, however you would need to replace the top hats or in my case I just drilled new holes for the rear struts to line up in. I had some chamber issuses initially but that was easy to fix. I recently upgraded to a set of Cusco Zero-2r's and that came off a 05 Sti and they work fricking sick. good Luck w/ your swap.
bfreeskier is offline   Reply With Quote
which suspensions will fit rsti stiboss Brakes, Steering & Suspension 15 04-02-2008 02:06 AM
i need a set of motor mounts for my '05. which years will fit? MrSaabaru Normally Aspirated Powertrain 1 08-11-2005 07:12 PM
Which rotors will fit sti rear 2-pots? hairband Brakes, Steering & Suspension 2 03-31-2003 10:58 PM
Calling on all Tein coilover owners. BHONE78 Brakes, Steering & Suspension 0 10-22-2002 09:50 PM
Which downpipe will fit blitz cat back? wReXeRw Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-15-2002 12:29 AM
