Old 03-31-2008, 04:18 PM   #1
newrexracer
Member#: 97031
Default Freshly Oiled K&N drop in filter
I recently re-oiled my K&N air filter and i was wondering if using too much oil could cause my car to run rich from the Mass air flow sensor becoming oily and reading incorrectly. If so how could i cure this problem? Is it possible to clean the MAF sensor or would it just be best to replace. This is pure curiosity but please only reply with honest answers
Thanks
i have a 2005 Wrx stg2
newrexracer is offline   Reply With Quote
Old 03-31-2008, 04:27 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Go to Autozone, etc. and buy a can of CRC's QD Electronics Cleaner. Spray up inside, let drip dry for 30 minutes and quit oiling the crap out of your filter.
Old 04-01-2008, 09:46 PM   #3
08EJ25
Member#: 174022
2008 WRX
Lightning Red
X2. More is not always better. This is a big mistake people make with reusable filters.
08EJ25 is offline   Reply With Quote
Old 05-07-2008, 03:40 PM   #4
dreamvang
Member#: 164972
2005 STI
Do you mean by spraying the CRC inside the airfilter box? Sorry, I'm confused. I need to clean my MAF also but don't know where to start. The search bar didn't really help it that much also.
dreamvang is offline   Reply With Quote
Old 05-07-2008, 05:12 PM   #5
Arctic Penguin
Member#: 119532
2006 WRX
if you sit the filter on a piece of newspaper and it makes more than a little spot/spots
it is over oiled
Arctic Penguin is offline   Reply With Quote
Old 05-09-2008, 03:57 PM   #6
FastHackem
Member#: 137009
2005 Impreza WRX
WR Blue
Just disconnect the wires going to the MAF and take out the two screws that hold it in. Now take the MAF and put it in a zip lock freezer bag. Now spray about half a can of non-chlorinated brake cleaner in the bag till it covers the MAf. Gently shake the bag and then let it sit for a few minutes. After that shake it a few more times and then take it out and allow to air dry completely. Put it back into the intake track and secure the screws. Plug back in the wires and your good to go. Easy huh? BTW the MAF is the piece of plastic with wires coming out of it right after the air filter box on the intake track. Hope that helps!!
FastHackem is offline   Reply With Quote
Old 05-11-2008, 03:26 PM   #7
GRIP_SPEED
Member#: 141717
2004 Psm stg2 wrx
The K&N instructions state that as long as the filter is oiled and covered with red or pink completely then it is enough. Even if you happen to over spray or over oil it will just soak through on the other side. It doesn't say anything about being harmful on the filter from over oiling. All your really doing is wasting your oil supply. I just cleaned and re-oiled my K&N filter couple weeks ago and my suby runs great again.
GRIP_SPEED is offline   Reply With Quote
Old 05-11-2008, 03:46 PM   #8
ringe
Member#: 49998
2007 WRX CT Stg 2
I see overoiled filters causing problems on a fairly regular basis.
ringe is offline   Reply With Quote
Old 05-11-2008, 03:59 PM   #9
Arctic Penguin
Member#: 119532
2006 WRX
k&n instructions don't have to pay to fix cars that have issues due to overoiling the filter
too much oil on the filter and the oil gets sucked through onto the MAF which causes erronious signal to the ECU which leads to driveability issues and poor overall engine operation
this is easily avoided by not overoiling the filter
so don't
Old 05-11-2008, 04:44 PM   #10
GRIP_SPEED
Member#: 141717
2004 Psm stg2 wrx
so don't
exzactly so follow instructions and everything will be savvy. as long as all the filter gaps are properly coated to the point where it looks red. Then stop. People who over oil obviously didn't read instructions correctly or are ignorant.
Old 05-11-2008, 06:38 PM   #11
ringe
Member#: 49998
2007 WRX CT Stg 2
You yourself don't sound too knowledgeable based on your previous post.
Just to give you all some idea, the word on the street is that from the factory these filters get a very light amount of oil on each pleat. After boxing and shipping the oil migrates throughout the rest of the gauze.
So basically it is not even necessary to darken the entire element on the first shot...just go lightly and let it sit for a while till the oil migrates.
Old 05-11-2008, 07:54 PM   #12
Arctic Penguin
Member#: 119532
2006 WRX
exactly NOT
what YOU describe is OVEROILING and bad news for MAF cars
Old 05-12-2008, 09:04 PM   #13
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
he means spray the electrical cleaner into the MAF (if you remove the MAF sensor and look up into it, you'll see two parallel wires - those are what you are cleaning)
WTB : oem drop in filter / k&n drop in filter JustAnotherSubie SCIC Private Classifieds 0 02-17-2010 08:11 PM
FS in PA: K&N drop-in Filter for 1999 2.2 Impreza L Jaker 1993 - 2001 Impreza Specific Parts 0 10-03-2009 01:31 PM
fs k&n drop in filter w/ cleaner/oil luvinboost Engine/Power/Exhaust 2 11-22-2008 01:19 AM
Cheapest place to get K&N drop in Filter for WRX in Everett? ProdriveRex North West Impreza Club Forum -- NWIC 6 10-16-2006 11:17 PM
Like new K&N drop in filter for 01-3 (maybe 04-05?) w/ complete K&N Recharger kit Scott4DMny Private 'For Sale' Classifieds 1 02-11-2005 11:55 AM
