Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Car Care & Detailing
Closed Thread
Old 04-01-2008, 02:53 AM   #1
ULTIMATETOOLCO
Vendor Sales Rating: (50)
Member#: 165370
2007 WRX
www.ultimatetoolco.com
Default DIY - Maintenance Tools!
Do you perform your own maintenance? We stock the best T70 size Torx bits for that transmission fluid change you've been putting off. We also carry the proper 13mm square socket made by Kyoto Tool Co. to safely loosen/tighten those rear differential plugs. No more rounding and stripping those plugs with your bare 1/2" drive ratchet!
KTC 1/4" Drive and 3/8" Drive Adapters (set of 2)
Brand new item! We are now offering these two ingenious three function adapters made by Kyoto Tool Company. These unique items are made in Japan from cast aluminum, so they will not rust or corrode. Dust off that poor Ό” drive ratchet and make it useful again! Instantly make it a more useful 3/8” drive ratchet! The other included adapter will make your 3/8” drive ratchet into a ½” drive. Not only do these increase the size on your current Ό” and 3/8” driver ratchets, but they have high powered magnets cast into them keep your sockets attached. And finally, the most attractive feature are the “wings” which extend past the ratchet head allowing your index finger and thumb to do the job of a second hand. Whether you're starting the threading process, or finishing the very last turn of a fastener, you can now do it all with the same hand! You will receive two items total: one Ό” drive to 3/8” drive adapter, and one 3/8” drive to ½” drive adapter. These adapters have been so useful to us, they have not been removed from our ratchets since we've received them!
$28.50 w/ Free shipping (contiguous 48 United States only)
For more info and to purchase our KTC Adapters click here
http://ultimatetoolco.com/adapters.aspx
T70 Torx Sockets
Are you looking a T-70 Torx socket to change your own transmission fluid on your 5 speed manual transmission or MY 2007 6MT STI? We have the highest quality T70 Torx sockets available. We even offer then in the ideal and difficult to find 1/2" drive size. These are made by VIM and are precise fitting, 2 piece pressed construction (interference fit) and are manufactured from S2 steel with Lifetime warranty!
*This Torx socket will fit late year 2004 and up WRX (including 2008 WRX) with 5MT, 2003+ 5MT Legacy, 2003+ 5MT Forester, and 2007 6MT STI (clutch side drain bolt). If you are in doubt, please take a look under your car to see if you are in need of a T70 Torx socket. As far as we know the 2007 STI is the only year STI in need of this T70 Torx socket, others 2004-2006 STI models with 6MT will not.
$18.00 w/ Free shipping (contiguous 48 United States only)
For more info and to purchase T-70 Torx sockets click here
http://ultimatetoolco.com/t70torx.aspx
KTC 13mm square Differential Sockets
Is it time for a rear differential fluid change in your Subaru? This is the PROPER socket to remove and tighten those square differential plugs! Made by KTC (Kyoto Tool Co.) from Japan. Most people end up stripping and/or rounding-off the differential plugs by forcing an ill fitting and wobbly 1/2” drive ratchet or 1/2" drive extension in that square rear differential plugs. Anyone who has performed this task before knows the ridiculous amount of effort used when you don't have the right tool. We strongly suggest our KTC 13mm differential socket. It fits right up to those plugs perfectly square so you are able to loosen and tighten with confidence.
There has been a car part review of this item located here:
http://forums.nasioc.com/forums/show....php?t=1435930
$29.50 w/ Free shipping (contiguous 48 United States only)
For more info and to purchase KTC 13mm square sockets click here http://ultimatetoolco.com/drainplugs.aspx
We offer COMBO sets which include our BEST SELLERS to save you money! Don't see a set to your liking? Contact us via email for a custom set or international shipping quotes, we will do our best to accommodate you.
COMBO Sets found here:
http://ultimatetoolco.com/sets.aspx
Much more to come for our Subaru vehicles, be sure to check our website for updates!
Contact us by email, AIM or PM for further information.
AIM: ultimatetoolco
[email protected]
ULTIMATETOOLCO is offline
Old 04-01-2008, 10:30 AM   #2
ULTIMATETOOLCO
Member#: 165370
2007 WRX
KTC Fender Cover
KTC Fender Covers now in stock! After months of waiting for our KTC Japan shipment to arrive, they are finally here! Do you worry about dropping a socket or ratchet therefore chipping your paint or even denting your fender while working under the hood? These KTC Fender Covers are the perfect addition to any tool set. You will find "KTC" printed in white script followed by: "No.1! Select the number one tool of the world." This is a thick, high quality and durable fender cover made from heavy duty vinyl weighing just shy of 2 pounds! On the inside where it meets your vehicles paint, it is lined with soft, non-marring felt. It is the perfect size for import cars with measurements of just under 16" high, by just over 43" long. These dimensions give you the ability and convenience to not only work under the hood, but comfortably work on your front suspension with this fender cover still in position! There are a total of 4 magnets, each 10" inches long which are built into the top band where you can affix them to your fender without damage to your precious Subaru paint. This fender cover is stain resistant, non-absorbant and very easy to clean for many years to come.
$84.00 Shipping is Free and upgraded to USPS Priority mail! (Contiguous 48 United States only) Click here for more info and to purchase: http://ultimatetoolco.com/fendercover.aspx
KTC Professional Hose Pick Sets (set of 3)
Save time and the chance of damaging your larger engine bay hoses. Especially helpful with intercooler hoses and intake couplers, because of how large these picks are! Manufactured and designed in Japan, their substantial size (over 7 inches from tip to to end of handle!) and extreme angled tips on these rugged hose picks really help when your working in tight clearance areas (behind the engine or underneath components.) Sharp, yet beefy ends are extremely strong and perfect for breaking hoses loose and cutting through caked on coolant or debris.
$55.00 w/ Free shipping (contiguous 48 United States only)
For more info and to purchase KTC Professional Hose Pick set click here http://ultimatetoolco.com/hosepicks.aspx
AIM: ultimatetoolco
[email protected]
Old 04-06-2008, 01:12 PM   #4
ULTIMATETOOLCO
Member#: 165370
2007 WRX
Bump!
Old 04-17-2008, 04:50 PM   #7
nxttruck2002
Member Sales Rating: (3)
Member#: 90879
nxttruck2002 is offline
Old 04-30-2008, 07:05 PM   #11
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^Bump!
Old 05-07-2008, 03:13 PM   #13
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ Bump!
Old 05-08-2008, 01:24 AM   #14
Mars_D
Member Sales Rating: (21)
Member#: 90480
2005 9-2x
I'm gonna be in need of those hose picks soon....wish I woulda though about them when I ordered the panel/trim pop kit.
Mars_D is offline
Old 05-11-2008, 06:33 PM   #15
ULTIMATETOOLCO
Member#: 165370
2007 WRX
We have just unpacked our latest Japan shipment. KTC Hose Picks are good in stock. These have quickly become one of our best selling items YOU WILL LOVE them!
Old 05-12-2008, 08:57 PM   #16
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ Bump!
Old 05-20-2008, 05:21 PM   #17
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ Bump!
Old 05-21-2008, 05:31 PM   #18
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ bump!
Old 05-26-2008, 11:38 AM   #19
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ Bump!
Old 05-31-2008, 11:40 AM   #20
ULTIMATETOOLCO
Member#: 165370
2007 WRX
^ Bump!
Old 06-14-2008, 03:16 PM   #23
ULTIMATETOOLCO
Member#: 165370
2007 WRX
Bump!
Closed Thread
FS: maintenance tools, caliper paint 5$ sale on everything ralli-tart VIC Private Classifieds 2 04-08-2009 10:32 AM
DIY Specialized tools from Ultimate Tool Co ULTIMATETOOLCO Drivetrain 0 12-01-2007 01:30 PM
Fall Specials: DIY Maintenance, CryO2, STi, Turbosmart, MUCH MORE! WilkinsSubaru Engine/Power/Exhaust 42 12-22-2005 09:32 AM
DIY Maintenance sticker R_W Service & Maintenance 15 09-21-2005 08:48 PM
where is the maintenance tool bag located? Nok's WRX Tri-State Area Forum 8 03-23-2003 04:22 PM
