Old 04-02-2008, 03:18 AM   #1
obsnw
Member#: 174739
I drinka now...
I drinka juice
Default 5zigen zr+ help
So I want the above stated wheels for an 00 legacy gt limited in either an 18x7.5 with +47 offset or a 17x8 also +47. So they work, I know that from the chart floating around, but what size tire is good for the setups?
obsnw is offline   Reply With Quote
Old 04-02-2008, 05:19 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
225/40-18 is the best size for the 18" and 225/45-17 for the 17"
DLC is offline   Reply With Quote
Old 04-03-2008, 04:41 AM   #3
PA-Outback2000
Member#: 161832
2000 Outback Limited
225/50/17 is good. won't throw speedo off too much. i may be getting roms soon and i think that is what i am doing.
PA-Outback2000 is offline   Reply With Quote
Old 04-03-2008, 11:42 AM   #4
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
225/50/17 sounds like rub juice to me.
Kawikid20o2 is offline   Reply With Quote
Old 04-03-2008, 02:10 PM   #5
obsnw
Member#: 174739
I drinka now...
I drinka juice
Ya, every car I have ever had has had rub issues, this one will have to be different, I'm trying to go legit on my legacy, it just isn't the same as some old impreza
Old 04-03-2008, 03:33 PM   #6
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
That is fine for an outback, but not other cars, especially lowered cars. The 225/50/17s would be 1 full inch larger in diameter than the stock 205/55/16 size. Also, the speedometer would read 3.9% too slow.
Not to mention handling wouldn't be as good with the 50 series.
Listen to DLC.
Also, for future reference, if you look at the specs for the tire you are considering, on sites like TireRack, it lists the "ideal" wheel size as well as the acceptable range.
JS
gtwagon941 is offline   Reply With Quote
Old 04-03-2008, 04:43 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Listen to DLC.
JS
On a regular BE/BH, 225/50/17 won't fit. I believe silentracer tried on his car awhile back. On the outbacks with the extra 1-2" of lift, it probably can (I think the stock tire size for the outbacks are taller to begin with, no?)
rougeben83 is offline   Reply With Quote
Old 04-04-2008, 02:56 AM   #8
obsnw
Member#: 174739
I drinka now...
I drinka juice
so if I went with 225/40/18's then would I be able to lower it? I want the h&r wagon springs (on a sedan, haha) which lower it quite a bit. Perhaps smaller tires? Although my options would run thin at that point, right. So I may be better going with a 17x7 wheel, and some slightly smaller tires. But I really want to go all out, I've never had a good wheel and tire setup, just a Frankenstein mixture of stuff on sale that never really worked, but just looked good.
Oh, and I don't really trust tire rack, they are the ones who calculated my last setup to fit, and it didn't do so well. Besides, nothing makes up for good ol' experience, right?
Old 04-04-2008, 03:48 AM   #9
PA-Outback2000
Member#: 161832
my tires are 225/60/16. i talked to a few people. they did the numbers and thoiught 225/50/17 would be the best fit. i will ask more people. gtwagon941, does this change ur opinion? thanx for the info.
Old 04-04-2008, 03:44 PM   #10
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Nope. Math is math. They are too big to fit the OP's car. They will fit on your outback, but again, those are now .7" smaller than your original tires. That means your speedo will be off 3%, which doesn't really hurt anything, but I like to try and keep it close to stock diameter. 225/55/17 would be the size for you to achieve that.
GREAT tool for this topic: http://www.miata.net/garage/tirecalc.html
Of course that tool doesn't really tell if the tire/wheel will fit without rubbing, but is a start.
JS
Old 04-05-2008, 12:46 PM   #11
DOOKWAGON
Member#: 167129
03 Wagon Mafia
Too Low for Nasioc Mb#013
205 55 16 and a 215 45 17 are the closest you can get to each other in size...
DOOKWAGON is offline   Reply With Quote
Old 04-05-2008, 09:16 PM   #12
PA-Outback2000
Member#: 161832
i checked again and my guy said that they(225/50/17) would work on a stock Legacy GT from 2000-2004. speedo would be around 2mph faster than the car is going.
Old 04-07-2008, 12:43 PM   #13
obsnw
Member#: 174739
I drinka now...
I drinka juice
you guys are cool. Thanks for the help.
Old 04-07-2008, 01:27 PM   #14
rougeben83
Member#: 115154
2005 Outback XT
White on grey
JS
Your mechanic is wrong:
http://www.sl-i.net/FORUM/viewtopic....&highlight=225
Math maybe math, but all those tire calculators DO NOT take into account fender and suspension clearance, along with wheel offset.
If you're using stock offset (+55) it WONT fit because the tire will rub the front suspension of a regular Legacy.
On the Outback, the increased ride height WILL allow those tires to fit.
Old 04-07-2008, 01:55 PM   #15
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Umm, you just compared the posts from two different peeps...I've said they wouldn't fit the whole time...and I already said that the tire calcs are just a start, as they don't tell you whether they will rub or not.
JS
New Concave 5ZIGEN ZR+520 Wheel ! VisionaryRacing Wheels/Tires 143 09-04-2011 04:11 PM
WTT/TW: 5Zigen ZR+520 17x8 5x100 +47 berny227 SCIC Private Classifieds 81 06-16-2008 03:12 AM
Pic request: 5Zigen ZR+ gunmetal on black 06-07 WRX/STi silverf0x Tire & Wheel 2 05-09-2008 01:11 PM
New Wheels Tires 5Zigen ZR+520s and FK 452s Mr Nice Guy Tire & Wheel 12 12-11-2007 03:06 PM
5zigen zr+520 S14Swap240sx Tire & Wheel 7 11-07-2007 07:50 PM
