Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-02-2008, 11:34 AM   #1
RenickMotorsports
Vendor Sales Rating: (26)
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Default BLOW OUT SALE! Perrin, Avo, Borla, Blitz,
2008 5-DOOR WRX SPT Catback Exhaust IN STOCK!!! $330
The new stainless steel exhaust system replaces the stock WRX center pipe and rear muffler assembly with a smooth flowing, low restriction, better-sounding exhaust note, plus a 10 horsepower increase! The 2008 Impreza SPT Cat-Back Exhaust Systems are covered by the 3-Year, 36,000 mile Genuine Subaru Accessory Parts Warranty, and may be installed by the dealer.
http://www.driveperformance.subaru.c...reza_parts.asp
SPT INTAKE AND HEATSHIELD PACKAGE $230
INTAKE ONLY $164, SHIELD ONLY $70
Carb legal in 50 states. Will not void your warranty. Fits all WRX and STi 02-07 Impreza models.
JDM STI PINK 565CC WRX INJECTORS SET OF 4 $355
BORLA HEADERS WRX/STI $439
T-304 Stainless Steel, an alloy superior to T-400 series knockoffs, to give you the absolute best in performance, sound and durability. Ultra-smooth mandrel bends and precision computer-controlled CNC manufacturing give you maximum flow, and power. Will fit Impreza WRX, STi, Forester XT, Legacy and Baja Turbo.
TITEK UP-PIPE
#SUB-10003 $120
SUS304 stainless and have increased rigidity through the flex joint, which also aids for a much easier install. This piece is precisely tig welded with an EGT sensor bung.
DC UP-PIPE
#STU4301B $109
100% T-304 Stainless steel construction (no mild steel flanges) CNC mandrel bends with robotically-welded fittings
PERRIN FMIC KIT
#PSP-ENG-400 $950
Kit Includes
# Intercooler Core
# Support Beam
# Silicone Couplers
# Polished Aluminum Tubing
# Signature Series Wrinkle Red Boost Tubes (SS models only)
# T-Bolt PERRIN Clamps (produced 12/3/2006+)
# Silicone Expansion Tank
# Mounting Hardware
# Instructions
# Warranty
http://www.renickmotorsports.com/osc...oducts_id=1177
AVO LEGACY TMIC
#LEG-1344-000 SOLD OUT!
FOR THE USDM LEGACY GT
Designed it to fit the standard mounting points, and stock turbo piping without any cutting. The high efficiency bar and plate core design that flows up to 40% more air than stock while drastically improving cooling. A design thats concentrates on efficiency instead of depending on size alone, does not cause throttle lag, or delay turbo spool up.
The core measures 10.4"x 10.3" x 3.5", and will support up to 400 crank horsepower.
RenickMotorsports is offline
Old 04-02-2008, 11:34 AM   #2
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
AVO WRX/STI CATBACK EXHAUST
#WRX-2002-550 $550
3" stainless steel, and designed to bolt up to the stock locations/flanges. The high-flow design is rated of 86 dB, making it a good choice for noise conscious performance-oriented customers. Comes with a 3 1/4" rolled tip.
BLITZ PANEL FILTERS
#59515 $26.50
Utilizing the same filter as the LM Core-type filters, the BLITZ® LM Stock Replacement Filters are designed to reduce intake restriction and provide maximum filtration without sacrificing the stock air-box.
Oil Cap and Tie Down Package Price $60
SPT Oil Cap only $32, Tie Down only $32
STI RAD CAP $40
High pressure radiatior cap increases presure rating of cooling system from 13 lbs to 18.9 lbs. This allows for more efficient cooling under demanding conditions.
SPT TURBO SHIELD $58
The SPT Turbo Heat Shield helps to retain heat within the turbocharger, which helps to keep the heat generated by the turbocharger away from the intercooler. Fits 2006-2007 WRX, 2004-2007 STi and 2004-2007 Forester XT.
SPT RADIATOR SHROUD $70
2002-2007 WRX and STi models
FREE Seat Belt Pads With ANY ORDER! Choose color shown below
[email protected]
Old 04-03-2008, 11:56 AM   #3
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 04-03-2008, 12:33 PM   #4
Rutchard
Member Sales Rating: (3)
Member#: 72354
2005 Impreza WRX STi
CGM
do you have the "JDM 'TGV Delete' Intake Manifold Risers" in stock for STi side feed injectors? If so, how much shipped to 13148? Thanks!
Rutchard is offline
Old 04-03-2008, 12:48 PM   #5
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
pm'd you.
Old 04-03-2008, 01:28 PM   #6
Frisky
Member#: 159639
2008 WRX 5 Door
Do you know if the 2008 WRX SPT Catback Exhaust deal is going on in Canada?
Frisky is offline
Old 04-03-2008, 01:53 PM   #7
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
I'm really not sure, we were first notified April 1st via email from SOA of its availability. You can get one from us though!
Old 04-03-2008, 03:45 PM   #8
Frisky
Member#: 159639
2008 WRX 5 Door
I should have worded my question better, what I meant to ask was will my warrenty still be OK if I install this in Canada?
Frisky is offline
Old 04-03-2008, 04:24 PM   #9
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Thats a very good question. I contacted SOA regarding this question. However contacting your local subaru dealership, and asking them about SPT parts (intake and exhausts) and warranty. My guess is that it wouldn't be an issue considering it is a Subaru product.
BTW 3 have sold today.
Old 04-06-2008, 12:01 AM   #10
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Weekend bump.
Old 04-06-2008, 01:29 AM   #11
racerx66
Member Sales Rating: (17)
Member#: 130617
2003 WRX
Black Midnight Pearl
Borlas still avalible?
racerx66 is offline
Old 04-07-2008, 12:28 PM   #12
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Yes sir.
Old 04-08-2008, 12:15 PM   #13
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump for the cheapest Perrin and Avo intercoolers you will find.
Old 04-09-2008, 11:28 AM   #14
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 04-10-2008, 03:31 PM   #15
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 04-10-2008, 10:44 PM   #16
LTselect
Member#: 177137
Default 2008 WRX SPT Cat-back exhaust and CAI
When are the coming out? Where can I buy them?
LTselect is offline
Old 04-13-2008, 02:06 AM   #17
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Late night weekend bump.
Old 04-14-2008, 05:27 PM   #18
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 04-14-2008, 08:22 PM   #19
thatg
Member Sales Rating: (1)
Member#: 108060
does anyone have pics of the spt on an 08 sedan, and im curious is the intake the same for older model wrx, someone had told me that lgt parts are the same as the 08 wrx, is this true for 06+? thanks
thatg is offline
Old 04-15-2008, 11:51 AM   #20
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
It looks a lot like the 5 door version.
Old 04-15-2008, 12:30 PM   #21
ozzy370
Member Sales Rating: (5)
Member#: 162469
2003 WRX wagon
special sauce
why is the borla manifold $439 on here and $499 on the website?
is there a way to get that $439 price?
http://www.renickmotorsports.com/osc...roducts_id=495
ozzy370 is offline
Old 04-15-2008, 12:34 PM   #22
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Because they're on a NASIOC BLOW-OUT SALE!!! Price is $439. Order through our website and note nasioc in the comment box and your price will be reduced to $439 manually.
Old 04-15-2008, 12:36 PM   #23
ozzy370
Member#: 162469
2003 WRX wagon
special sauce
i c thank you, i might of missed that
ozzy370 is offline
Old 04-16-2008, 01:39 AM   #24
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Old 04-18-2008, 11:19 AM   #25
RenickMotorsports
Member#: 6474
. 18G'd Bugeye
331whp/310wtq 50/50
Bump.
Closed Thread
Blitz Wheel Blow Out Sale! Must Check It Out !! Edo Performance Wheels/Tires 6 11-03-2009 12:09 PM
ImportMuscle Blow Out Sale! All Parts In Stock! APS, Greddy, Perrin, Samco. Japtrix Engine/Power/Exhaust 10 08-15-2007 06:18 AM
All in stock PERRIN = Blow Out Sale!!! SpeedElement Engine/Power/Exhaust 4 02-09-2007 05:25 PM
Tanabe Concep G Blue Full Turbo Back/Borla Hush Clearance! BLOW OUT SALE! SpeedElement Engine/Power/Exhaust 4 05-02-2006 04:56 PM
Perrin Intake Blow Out Sale till 2/26/2005!! WRX EVOlution Engine/Power/Exhaust 3 02-23-2005 06:10 PM
