Old 04-02-2008, 02:01 PM   #1
ezzzey
Member#: 141956
2002 Impreza WRX
Default are subaru lug nuts like tuner lug nuts?
... i have 17" aftermarket rims, and was wondering if subaru's lug nuts will fit. They say they have the regular ones, .... whatever that means....
Normal WRX lug nuts from the dealership might not fit my rims, but dont the BBS Rims require tuner lugs which are a lot thinner then REGULAR lugs and therefore would fit my aftermarket rims?
ezzzey is offline   Reply With Quote
Old 04-02-2008, 02:02 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
BBS takes the same standard lug nut the other subaru alloy rims do. At least 2002-07, I can't speak for 08 models.
Mavrik is offline   Reply With Quote
Old 04-02-2008, 02:34 PM   #3
JuggernautTCW
Member#: 169223
BBS takes the same lugs, I got 04 STI BBS on my WRX w/ the same nuts. Usually you wouldnt need tuner nuts unless stock ones are too short.
JuggernautTCW is offline   Reply With Quote
Old 04-02-2008, 02:35 PM   #4
nixgame22
Member#: 101219
Why don't you just take a lug nut off and see if it fits
nixgame22 is offline   Reply With Quote
Old 04-02-2008, 06:21 PM   #5
kimball
Member#: 144465
2004 STi
black
That's right;the seat design is called "cone". But some wheels use a seat design called "radius"/"spherical"/"ball" which is easy to mistake for "cone". The two can not be mixed. Make sure that those aftermarket rims have cone seats before using your Suby lug nuts.
kimball is offline   Reply With Quote
Old 04-02-2008, 06:36 PM   #6
SimonJ
Member#: 135309
most aftermarket rims require "tuner" lugs, that have a more tapered seat. The stock subaru lugs will not work.
SimonJ is offline   Reply With Quote
Old 04-02-2008, 08:39 PM   #7
law
Member#: 36842
2008 2007 Exige S
AW, Black
You can still use the stock subaru lugs. You will need a thin wall socket and if you torque them properly there shouldn't be a problem. In most cases they will fit.
law is offline   Reply With Quote
Old 04-03-2008, 12:36 PM   #8
kimball
Member#: 144465
2004 STi
black
Last year I bought wheels from Fikse. Fikse doesn't supply lug nuts for Subarus,so I sent them a stock Subaru nut,a Subaru/McGard locknut,and a McGard spline-drive nut for Subaru. Fikse examined them and told me that all three have the same cone seats and would work fine with my new wheels.
Old 04-03-2008, 12:39 PM   #9
BlazinYellow
Member#: 127963
So.. wanna ****?
I have ROTAs and OEM lugs don't work, they'll eat the s*** out of your wheel if you try to put them on all the way.
BlazinYellow is offline   Reply With Quote
Old 04-03-2008, 02:27 PM   #10
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
This is wrong.
Subaru OEM uses conical seats, which is the same as "tuner" lugs.
Other manufacturers, like Honda, use rounded seats, which are not compatible. But Subaru, uses conical.
chimchimm5 is offline   Reply With Quote
Old 04-03-2008, 02:28 PM   #11
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
HuH? Are you referring to the seat of the lug grinding the paint on the seat away? Or the fatness of the OEM lug making you scrap your wheel's lug wells?
Which Rota is this?
Old 04-03-2008, 05:12 PM   #12
law
Member#: 36842
2008 2007 Exige S
AW, Black
Depending on the Rotas perhaps, my Tarmac 2's had no issues. You have to use a thin wall socket and be gentle so you don't start scraping the sides. Other then that no problems.
Old 04-03-2008, 07:23 PM   #13
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Yup... and I highly recommend you get a set of black BBS lug nuts if you get BBS's for your WRX (particularly gold BBS's). They add a nice touch.
flimflamman is offline   Reply With Quote
Old 04-03-2008, 08:38 PM   #14
oRenj9
Member#: 164352
2007 Impreza WRX
I was thinking about STI Pink lugs for my black wheels. Does anyone know of a manufacture that makes them (or alternatively, what I can use to paint them that won't peel off)?
oRenj9 is offline   Reply With Quote
Old 04-04-2008, 12:00 AM   #15
BlazinYellow
Member#: 127963
So.. wanna ****?
Which Rota is this?
I'm referring to the fatness of the OEM lug scraping the wheel lug wells. Even when used with a thin wall socket, I wasn't going to be able to use them.
They are ROTA Boosts.
Old 05-17-2008, 06:38 AM   #16
06PearlWRX
Member#: 171609
2007 WRX
I just bought a gorgeous set of silver bbs for my 07 WRX. Nowtheir both cone seats, but its almost like the cone is not long enough. Its too close to call, but i looks like the head of the lug (name i just made up for the part where it transitions from the cone to the socket shape) is almost in the wheel. it seems like the cone portion should be fitted a little longer. But if everyone else is using their stock lugs with bbs' i'm not too worried. did lugs change in 06/07's?
06PearlWRX is offline   Reply With Quote
Old 04-03-2009, 11:36 PM   #17
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Sol Subaru GC lug nuts WILL fit on Rota Tarmac II Rims?!!?
As long as i use a thin walled socket,
How thin?
will a generic Mastercraft 19mm socket work?
Wrgb is offline   Reply With Quote
Old 11-05-2009, 05:11 AM   #18
TaurusMcRae007
Member#: 209907
9997 LGT 30th&LSi
Glacier Wh.&Spruce Pearl
Question
Did you ever find a manufacturer for these?
TaurusMcRae007 is offline   Reply With Quote
Old 11-06-2009, 03:41 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Quoting an old post, but I think this is what BlazinYellow was referring to... Sorry for the blurry first picture, I took this a few years ago and I'm too lazy to retake the photo now. Here's a stock acorn lugnut next to a Rays lugnut. They use the same, industry standard 60deg taper. However, you can see the Rays lugnut has a larger cone area, much like most aftermarket lugnuts. Between my three cars I have Rays, Gorilla and McGard lugnuts, and they all have that larger cone section.
Some aftermarket wheels have deeper lugnut pockets than the OEM wheels. If you put a stock acorn lugnut into that deeper pocket, the pointed corners of the hex section of the lugnut will hit the wheel and start to damage the wheel as you torque the lugnuts.
It's hard to get a good picture of it, but in that pic you can see how the hex section of the acorn lugnut is resting on the face of the wheel, whereas the larger cone section of the Rays lugnut has good cone-to-pocket contact.
So, it's perfectly acceptable to use aftermarket 60deg taper lugnuts on Subaru OEM wheels, but using Subaru OEM lugnuts on aftermarket wheels might not work out for you.
Pat Olsen
Old 11-08-2009, 10:03 AM   #20
JarrodRex
Member#: 206915
2009 WRX 5dr
Hey thanks for the info. I have been trying to find out about this for awhile now.
JarrodRex is offline   Reply With Quote
nnj wtt my tuner lug nuts for stock sti lug nuts fosingwo Wheels/Tires 0 04-02-2010 02:57 AM
What car/brand of car are Subaru owners most likely to trade their car in for? Rodeoflipper1818 General Community 57 02-11-2010 02:26 PM
fs oem subaru wheel locks and tuner lug nuts racekar Wheels/Tires 14 01-15-2007 03:36 PM
where to get tuner lug nuts? stratos Bay Area Impreza Club Forum -- BAIC 3 10-21-2001 12:23 AM
tuner lug nuts group buy?????(Attn. Chris) subpreza Texas Impreza Club Forum -- TXIC 1 01-27-2001 01:34 AM
