Old 04-02-2008, 02:12 PM   #1
toneloc12345
Member#: 169636
Default radiator and a/c fans don't work
Well first off the car is a 1993 impreza L with the stock 1.8l. I first found out that the fans don't work when I got the car stuck in the snow. It had the whole engine bay filled with snow and must have got a little hot apparently because the overflow tank was pretty full. Well the fans were packed with snow so I cleared them and turned the a/c on but no fans come on. Hmmmm I did hit a deer with the car and it busted out one of the headlights and pushed back the core support some and poked a whole in the a/c condensor. So the first question is, will the a/c fan come on even if the compressor doesn't kick on? Also I assume the radiator fan doesn't work either because it seemed to over heat some when it was packed full of snow.
I did a little bit of investigating today. I turned the a/c on and checked the connector for the passenger side fan with a test light and got nothing. Then I hooked up the drivers side fan up to the battery with a couple testing wires. The fans have a 3 wire plug, but I thought the fans would run buy hooking up a power and a ground. But I got nothing.
I'd like to figure this out before it gets hot outside.
toneloc12345 is offline   Reply With Quote
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Service & Maintenance 1 03-09-2015 09:55 PM
My STI is overheating when the AC is on and the AC fan doesnt work, why overheating? nicksamba_18 Off-Topic 9 08-21-2009 07:37 PM
impreza 99-01 oem radiator fans and 98 oem fans jicc 1993 - 2001 Impreza Specific Parts 15 08-12-2009 12:38 AM
Factory CD Player, interior and dome lights all don't work. HELP! onedownfiveup Car Audio, Video & Security 1 07-26-2005 09:45 AM
replaced my seats and now the horns don't work Capt Crunch Electrical & Lighting 1 12-29-2004 03:23 PM
