Old 05-31-2008, 05:20 PM   #126
sleepwalker_gsr
Member#: 179647
2006 STI
steel Grey Metallic
nice post thanks.it really helped me out.
sleepwalker_gsr is offline   Reply With Quote
Old 05-31-2008, 10:54 PM   #127
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
You're crazy man
I'm finishing up my swap right now (I hope). When I was wiring, I was really pissed off the entire time, no way would I have stopped to take pics.
I'm still completely lost on the fuel pump controller wiring. I haven't looked at it since I looked at your pics and caption, hopefully those will help me out because right now I only know what to do with 2/6 wires.
mannac is offline   Reply With Quote
Old 06-05-2008, 09:32 PM   #128
scoobylong
Member#: 127087
1999 2.5 RS(swapped)
Default wow
wow nicely done i had a similar situation i have a blue 99rs and one of my buddies barely totaled his blue 99rs with a full 2002 wrx drivetrain plus a little more so the harness was already converged so it was easier i also had some help and if you did that work on the ground i know it sucks i wish i had taken more photos though; good luck with your car
scoobylong is offline   Reply With Quote
Old 06-07-2008, 01:16 AM   #129
mannac
Member#: 161038
2005 LGT
'72 Datsun 240Z
Going to start up my swap tomorrow! I'm excited but afraid that I wired something wrong too If all works well, I'll post up some nice tips but I need to see if I did it right myself
Old 06-07-2008, 01:39 AM   #130
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
amazing pics and write ups... the most comprehensive guide I've ever seen.
Old 07-21-2008, 11:59 PM   #131
Joelo_00
Member#: 175095
Chapter/Region: PRSIC
2000 RS
Excellent job! Cleanly done, when should I drop my car at your place for the swap?? LOL Please dont kill me.
Cool work!
Joelo_00 is offline   Reply With Quote
Old 07-22-2008, 12:40 AM   #132
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
^^Thanks.
I'll pass for the swap offer though. That's the whole reason I posted this thread....so people can do this themselves lol.
If you have questions just let me know. I get several PM's a week from various people. If I know the answer I'll tell you it; if I don't then I won't.
Old 08-20-2008, 10:20 PM   #133
xhyperxshogunx
Member#: 153949
2005 Saab 9-2x
Thanks for the write up!! i think everybody will appreciate this!!
xhyperxshogunx is offline   Reply With Quote
Old 08-30-2008, 12:47 PM   #134
Ricky_bobby
Member#: 185154
05 Subaru WRX STI
wow good work man
Ricky_bobby is offline   Reply With Quote
Old 09-01-2008, 03:46 PM   #135
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Just a general note on removing your brake rotors. A few weeks ago I saw someone trying to take off their rotors by beating the crap out of them with a metal hammer. The excuse “I’m getting them turned” doesn’t mean you can create imperfections in your rotor. To properly take them off do the following:
Take off your wheel/calliper and get it down to this stage. Notice there are two 10mm bolt holes there.
Screw two long 10mm bolts in those holes
Use the $10 puller device and start screwing it in. The rotor will just come right off. No hammering or beating required.
Freshly turned rotors
Old 09-01-2008, 03:47 PM   #136
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
I also swapped out the GeNOME axle back exhaust for a full exhaust system. It’s a COBB 3” OD pipe. No complaints about it. COBB sounds better idling but the GeNOME sounds better at WOT.
Make sure to use a new gasket
Old 09-01-2008, 03:49 PM   #137
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Headlight washer sprayers
I went around some local junkyards and found these nozzles. They are from a 1999 Lexus LS400. You can see them on the front bumper here:
I got them for $4 so canít really complain about the price. The main reason why I opted to not go the pop-up washer route is because the fog lights get in the way of the mechanism. I acquired some Lexus IS300 nozzles and the whole assembly was maybe 6Ē high. So it was either pop-up washers or fog lights; I decided on fog lights and the LS washers.
Some general pictures when I first got the nozzles.
Here I just placed them on loosely
Old 09-01-2008, 03:50 PM   #138
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
To install them you have to take off your front bumper. Start by taking off the rebar bolts
More rebar bolts (One is underneath of the power steering reservoir).
Two 10mm bolts on the bottom, one in the middle and two clips on the side and the bumper slides right off (one of the bolts on the bottom wasn’t cooperating which is why the fog light is out)
Here is how I left the pump. Everything was already wired up to the pump as mentioned before; I just had to run the fluid lines.
Here is the “T” that goes to the driver side sprayer
Old 09-01-2008, 03:51 PM   #139
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
It was very hard to photograph this but make sure you put check valves in which prevent fluid from flowing backwards. This will ensure constant pressure the moment you push the switch. There is a ball and spring inside the valve. I’m trying to show the spring.
Next you have to drill out two small holes. Get some painters tape and mark the locations. Conveniently the GC fog light bulbs are directly underneath of the headlight bulbs. So it’s quite easy to mark the locations.
Here is the rough hole. You must sand this later on to get a smooth hole
Old 09-01-2008, 03:53 PM   #140
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
After that the nozzles just slip right in and get held in place with a c-clip underneath. Similar to brake lines. Note: the backside of the bumper is blue because this is a JDM bumper.
The "T"
And here you see the finished product. They don’t spray as hard as BMW or Lexus OEM systems but they have enough give to them that they will spray off the fine sandy road film. Mainly these will be useful in the season between Winter/Spring where you go through your entire washer fluid reservoir in one day; otherwise they are strictly more for show and to fill out the blank spots on the interior of the car.
Old 09-01-2008, 03:55 PM   #141
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
It has also been brought to my attention that some of the pictures don't show up. They all work but if you're getting red X's then right click on the X and choose "show picture". It will appear.
Old 09-01-2008, 07:42 PM   #142
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
A few more pictures during the day.
…and because I just Armor All’d it some of the interior.
Old 09-15-2008, 03:07 AM   #143
dccd
Member#: 189375
looks like you like slurpee alot.. hehe
clean swap tho' always loved the GC style
dccd is offline   Reply With Quote
Old 09-15-2008, 10:37 PM   #144
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
^^Thanks. And yes, I do like slurpees.
Old 10-12-2008, 04:28 PM   #145
Andrew Bacon
Member#: 2267
00RS
rutherforddesign.com
Just wondering if you kept the RS and pitched the Lexus.
Thanks for all the extra work you put into the writeup & photos; I'd love to do the same though mine is a '00 and I'm not nearly as brave as you. My clutch and flywheel change was quite enough excitement for me.
Besides the MAF/MAP change, don't know how much other wiring would be different between '99 and '00.
Andrew Bacon is offline   Reply With Quote
Old 10-12-2008, 08:47 PM   #146
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
The wiring is actually easier on the 00/01's. There are more wires that you need already pre-existing in your bulk harness. The MAF/MAP is not an issue because you don't actually wiring anything around there. Those wires go straight to the ECU so no need to splice. Otherwise identical to what I wrote up here.
I'm not sure what you mean by "pitched the Lexus"???
Old 10-12-2008, 10:48 PM   #147
Andrew Bacon
Member#: 2267
00RS
Originally Posted by 99 rs View Post
...*snip*...
Earlier in the thread you said one car had to go, and friends voted Lexus:10 and RS:1 or some such thing? Not sure if that was 10 votes to keep or "pitch" the Lexus.
EDIT: Did I read "Lexus" even though it plainly says "Acura?" Got plugs 1 & 4 reversed again.
Thanks for the additional info!
Last edited by Andrew Bacon; 10-12-2008 at 11:51 PM. Reason: 42 YO w/ Drain Bamage
Old 10-12-2008, 11:26 PM   #148
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Ah yes, I know what you mean now. The red car is actually an Acura NSX though. The following link will explain my decision:
http://westernsubaruclub.com/smf/index.php?topic=3252.0
Old 10-18-2008, 12:52 AM   #149
lazyjai123
Member#: 178538
excellent wirte up
is there a jdm swap write up as good as this one here?
lazyjai123 is offline   Reply With Quote
Old 10-18-2008, 05:58 PM   #150
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
None that I have found. Most swaps are essentially the same though. Swap mechanical, do some wiring to make it run, start it up and that's that. Depending on what you're swapping there is more than enough info on rs25.com and here to get you started.
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
STi parts needed to complete kit, look inside RiSti05 Private 'Wanted' Classifieds 22 05-12-2009 04:00 PM
4EAT to STi gas pedal wiring guide Lamont Transmission (AT/MT) & Driveline 0 11-28-2008 11:38 PM
GC RS to USDM WRX/STI wiring guide aspect Subaru Conversions 3 06-30-2008 11:12 PM
HELP-Need to find a wire for switched 12V inside the cabin....anyone know? dchou Electrical & Lighting 2 02-07-2007 09:13 PM
