Old 10-31-2008, 04:41 PM   #151
powerneedy
Member#: 161242
wow great job! im in the process of a 95 with full 04/05 sti motor, dash, and harness... i may have to ask you some questions lol
powerneedy is offline   Reply With Quote
Old 11-01-2008, 12:46 AM   #152
scubydrew414
Member#: 181920
99 RS swapped
black
Thumbs up
i just want to say, Thank you!!!!! this is going to help me a lot!!..
scubydrew414 is offline   Reply With Quote
Old 11-18-2008, 07:11 PM   #153
Patty_McFly
Member#: 169182
2001 Impreza 2.5RSTI
BRP
Post my swap
i have been wanting to do a swap for sometime now with my 97 brighton coupe to an 02 WRX but i dont really want to do the wiring (due to lack of attention span) is there any where that i can get i pre wired harness for a swap
Patty_McFly is offline   Reply With Quote
Old 11-18-2008, 08:05 PM   #154
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
http://www.rs25.com/forums/showthread.php?t=63515
Look through the above link and find which shop is closest to you. From what I've been reading you send them your Brighton harness, you send them the WRX harness and you also send them $1000 and you get back a plug and play harness.
Having said that, your wiring will be near identical to what I have written up here....which is the whole point of this thread. It's easier than you think.
Old 12-03-2008, 08:38 PM   #155
hxcjohnny
Member#: 152380
2004 Wrx Sport Wagon
San Remo Red
this is a wonderful thread, and I love your car haha. You could always sell it to me
hxcjohnny is offline   Reply With Quote
Old 12-23-2008, 08:45 PM   #156
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I have a question...on the firewall next to the windshield wiper motor their is a plug...does it go to the front o2 sensor???
Cbgrandtheftauto is offline   Reply With Quote
Old 12-24-2008, 06:31 PM   #157
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
The big plug is generally for the cruise control. If it's on your 99 then that is most likely it. Post up a picture and we'll be able to tell you for sure.
Old 01-19-2009, 04:48 PM   #158
WagonRXer
Member#: 175505
2004 wrx wagon
red
you guys should pat yourselves on the back. nicely done!
WagonRXer is offline   Reply With Quote
Old 01-20-2009, 12:24 AM   #159
transporter
Member#: 198213
woe good work
transporter is offline   Reply With Quote
Old 02-22-2009, 07:21 PM   #160
2fool1again
Member#: 203662
Just curious because i see a 04 sti steering wheel on, would a full sti dash board with cluster fit on a 99-2001 RS?
2fool1again is offline   Reply With Quote
Old 02-27-2009, 01:08 AM   #161
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
It physically fits but it's definitely NOT a direct bolt in. I don't really recommend it. It never looks right as there are too big of gaps on the sides; you have to hack away at your firewall to fit the heating/AC system and then finally passenger side airbag isn't designed to work with the RS. The airbag will still explode but I'm not sure if Subaru "uses" the windshield to direct the airbag. Overall, I say it's not worth it. Just get an STI steering wheel and a JDM cluster and it will give a nice upgraded feel.
Old 03-16-2009, 07:15 PM   #162
2fool1again
Member#: 203662
The part that confuses me the most is having to label every single wire with tape? Did you splice the rs harness with the wrx harness? Isn't it faster just to take all the wrx's harnesses and ECU and just transfer it to the rs and plug it all in. This way you wont find your car on fire because you got lazy and soilderd a wire half arse at 3am in the moring?
Old 03-22-2009, 11:07 PM   #163
corniok2
Member#: 178448
2006 WRX sedan
no no dobra robota
corniok2 is offline   Reply With Quote
Old 04-16-2009, 11:47 PM   #164
iZach206
Member#: 157522
93 gf8 sti
Blaaack
this is so incredible. thank you so much for taking the time to do this. no joke i am swapping my 98rs with a 02 wrx motor and drivetrain. super good job too
iZach206 is offline   Reply With Quote
Old 04-17-2009, 12:16 AM   #165
venomsti650
Member#: 197620
Brilliant.
venomsti650 is offline   Reply With Quote
Old 04-17-2009, 01:25 AM   #166
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
The part that confuses me the most is having to label every single wire with tape? Did you splice the rs harness with the wrx harness? Isn't it faster just to take all the wrx's harnesses and ECU and just transfer it to the rs and plug it all in. This way you wont find your car on fire because you got lazy and soldered a wire half arse at 3am in the morning?
That is the exact reasoning why people do an interior swap. If you want to keep the proper interior then you'll have to splice. I basically spliced the WRX ecu onto the RS bulk harness. The majority of the wires are right at the ECU. I still recommend splicing instead of interior swap. Nothing fits properly and you have to hack away at your firewall.
Old 04-17-2009, 01:26 AM   #167
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Thanks for the above comments.
Old 05-04-2009, 12:08 PM   #168
Firewarrior333
Member#: 73458
1998 beater forester
05 wrx goodness
this write up is amazing kudos
Firewarrior333 is offline   Reply With Quote
Old 05-23-2009, 02:46 PM   #169
SilverJS
Member#: 205528
2002 TSTi (07)
That's an awesome thread. Sure wish I had something like this when I embarked on my FZR400 -> YZF600 conversion...=)
This is off-topic, but I've started researching - would you happen to know how much of the info in here will apply to a similar swap in a 1998 Outback?
Cheers!
SilverJS is offline   Reply With Quote
Old 06-19-2009, 11:19 PM   #170
europeanwhieboj
Member#: 214631
zajebiscie skont jestes?
europeanwhieboj is offline   Reply With Quote
Old 07-13-2009, 08:40 PM   #171
dppaladino
Member#: 129795
2000 WRSX Sedan
BRP
Any issues thus far with the rear axles? I'm confused as to whether you actually used RS or WRX hubs? I know you said the wrx axles wernt a perfect fit with the RS hubs because of a little rim thing. Please let me know!
dppaladino is offline   Reply With Quote
Old 07-15-2009, 04:39 PM   #172
subiev802t
Member#: 217300
sweeet
subiev802t is offline   Reply With Quote
Old 08-14-2009, 02:47 PM   #173
Scracho
Member#: 220449
2004 WRB WRSTi Stg2
Cobb, Invidia, Fujitsubo
Awesome write-up! You should consider this as a regular job
Scracho is offline   Reply With Quote
Old 10-02-2009, 12:36 AM   #174
MikeStreat
Member#: 205208
I am going to be doing a swap like this one, and i was wondering why you used the 2.5rs diff. and not the wrx, wouldnt that make it alot simpler, and more reliable? great guide btw
MikeStreat is offline   Reply With Quote
Old 10-09-2009, 04:46 AM   #175
iluvdrt
Member#: 46248
82 Brat
Tan
Stupid question, but you basically use the wrx ecu and engine harness than wire the RS (or in my case Legacy) body harness in place of the WRX's body harness. That way the wrx ecu will run the engine, but provide power to the recieptient cars accessories and stuff.
Do I have this right?
iluvdrt is offline   Reply With Quote
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
STi parts needed to complete kit, look inside RiSti05 Private 'Wanted' Classifieds 22 05-12-2009 04:00 PM
4EAT to STi gas pedal wiring guide Lamont Transmission (AT/MT) & Driveline 0 11-28-2008 11:38 PM
GC RS to USDM WRX/STI wiring guide aspect Subaru Conversions 3 06-30-2008 11:12 PM
HELP-Need to find a wire for switched 12V inside the cabin....anyone know? dchou Electrical & Lighting 2 02-07-2007 09:13 PM
