Old 10-31-2009, 12:34 PM   #176
tiger20002
Member#: 227802
1998 legacy outback
blue and tan
how lomg did all this take?
tiger20002 is offline   Reply With Quote
Old 03-30-2010, 04:00 AM   #177
Kahlil
Member#: 242648
05 2.5RS
SRR
This was just....incredible. I am considering doing a swap myself and seeing this only makes me want to do it more. Kudo's and happy driving!
Kahlil is offline   Reply With Quote
Old 04-27-2010, 07:45 AM   #178
Stoned_Llama
Member#: 205049
2008 WRX
I just stayed up until almost 4 in the morning reading this entire thread start to finish. I have never attempted a full swap yet, and after reading and seeing all of that, I am not sure that I ever want to! You are my long lost brother when it comes to OCD, and being meticulous. Everything takes 40% longer when it has to be perfect!
Monster Kudos to you sir for the amazing writeup, and the detailed pictures! Great work! Sad to see that you are selling her.
Stoned_Llama is offline   Reply With Quote
Old 06-20-2010, 04:09 AM   #179
alive1388
Member#: 246650
very nice ride...... very clean
alive1388 is offline   Reply With Quote
Old 07-20-2010, 09:58 AM   #180
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
question...im doing the same thing but the rs i bought came with an auto tranny. I Just mounted the engine and tranny and noticed that where i didnt have a 5 speed shifter, there arent any bolts holes for a rear stay bushing on the body. Should i drill holes into the body to accomodate for this? what exactly did you do?
subbiedoobie08 is offline   Reply With Quote
Old 07-20-2010, 11:39 AM   #181
iluvdrt
Member#: 46248
82 Brat
Tan
The holes are there but they are plugged with rubber plugs and probably coated with undercoating. Dig around a little and I bet you find them. In evey Subaru I have ever swapped, I have never had to drill holes for anything. The only exception is the old GL wagons.
iluvdrt is offline   Reply With Quote
Old 07-20-2010, 12:18 PM   #182
subbiedoobie08
Member#: 216595
2000 2.5RS SWAP
white
oh nice, yea its probably under the coating. I was shocked when i didnt see them, good call. Thanks
Old 08-07-2010, 12:25 PM   #183
2.5rsCT
Member#: 254141
wow alot of work!
2.5rsCT is offline   Reply With Quote
Old 08-07-2010, 12:25 PM   #184
2.5rsCT
Member#: 254141
how much did it cost you?
Old 08-23-2010, 11:43 PM   #185
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Good to see people are still benefiting from this swap.
There are numerous people who PM me and I'm sorry for not replying. Please remember that I did this swap over 3 years ago now. I did the write up because I knew I wouldn't remember. If you have a question please post it up in the forum below or in this thread; either way works. I will try to help where I can but there are definitely more seasoned people than me on this forum.
Sadly I have sold the car but still see it around every so often. I have moved on to the NSX world. Hopefully I keep it for 10 years like I did the Subaru.
Old 08-26-2010, 12:09 AM   #186
Kowitz
Member#: 210102
1998 Impreza RS
Never mind!
Kowitz is offline   Reply With Quote
Old 09-19-2010, 06:24 PM   #187
subyrail
Member#: 257700
this thread is VERY helpful, I just wish I could read what some of the plugs are better haha that would help me tons
subyrail is offline   Reply With Quote
Old 09-24-2010, 07:41 AM   #188
perez8608
Member#: 249852
1998 2.5rs
blue ridge pearl
hey do you know what sensors run off the brown and black connectors running off the main engine harness. I' doing a 98 2.5rs to 05 wrx swap and the 05 doesn't have that big gray connector that runs off those black and brown connectors. so I kinda ran into a speed bump. I want to solder them into the wires coming out of the ecu plug but cant find out what sensors run off that side of the harness.
perez8608 is offline   Reply With Quote
Old 10-17-2010, 10:12 PM   #189
ImprezaZRoss11
Member#: 173324
2006 VF'd WRX
JBP
dont know if this was already answered, but where can i get those wiring books? i am doing a EJ20G swap into my 99 rs.
ImprezaZRoss11 is offline   Reply With Quote
Old 11-11-2010, 05:45 PM   #190
bluemk3
Member#: 263694
World Rally Blue
to the OP i am seriously concidering this swap. but if i were to get a jdm gc8 front clip could i sumply replace the whole dash harness and motor harness? or are you not familiar. thank you and fantastic write up
bluemk3 is offline   Reply With Quote
Old 12-04-2010, 03:08 AM   #191
ditto151
Member#: 261850
1994 RS
Red
Default Heeelp
i was wondering if anyone could answer why am i getting an electrical back feeding current on my dash the break light is on and i have a cel that is on but the lights are really low kinda like a glow and all this stuff is lit with no key in the ignition
ditto151 is offline   Reply With Quote
Old 12-04-2010, 05:49 AM   #192
ilikewrx10
Member#: 188122
1998 OBSTi
Green
This is amazing! My life just became 100x easier so thank you. I'm in the middle of doing an 06 WRX swap with a built ej257 motor into my 98 OBS and it's the first time I've ever done this... I noticed someone was asking about the fitment of the WRX axles. My donor car is a sedan (I believe it has 99.4" wheelbase) and I have read various things about this causing binding and wear on the CV joints when installed on the older Imprezas with smaller wheelbase. Have you had any issues with the entire WRX setup (crossmember/lateral links/axles/etc.) Thanks!
ilikewrx10 is offline   Reply With Quote
Old 02-07-2011, 02:59 AM   #193
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
In the front if you use the WRX control arms then you will have no problem (that's what I did on the Subaru). Using the WRX rears would give you too much camber so I would stick with your current links.
Old 02-07-2011, 03:04 AM   #194
99 rs
Member#: 100994
2005 Acura NSX-T
2007 Outback 2.5i
Also if anyone needs the wiring diagrams for the 98-01 Impreza (should be all models) then PM me your e-mail address and I'll get back to you. Put a subject line in otherwise it will probably go to spam.
Old 02-17-2011, 07:25 PM   #195
LegacSTI
Member#: 273730
'98 LegNasty
White ass white
Wow, im in the process of swapping an '04 STi motor into my 98 legacy 2.5gt- even though they are different cars and motors altogether- this has been an invaluable help for me. your explainations and photos are going a long way in helping me feel a bit more comfortable when i get stuck. it really is a lot simpler than it seems- i tend to overcomplicate things which leads to throwing wrenches, but i have found that a 20 minute session of reading and staring at your photos is much more therapeutic way of dealing with electrical confusion. my walls are better off too. thanks again man, have fun with your acura- but we all know you'll be back into subatroopin' someday. mid engine is no replacement for awd boxer power!
LegacSTI is offline   Reply With Quote
Old 03-14-2011, 04:41 PM   #196
jtmccoy15
Member#: 276783
buy my 98rs/02 swap.
~40k motor
<90k chassis
solid car, but has minor issues. Mainly in line (failed bubble test terribly)
dont have time (in college)
PM is interested, Located in eastern KY
jtmccoy15 is offline   Reply With Quote
Old 04-06-2011, 08:32 AM   #197
weirdpuffy
Member#: 171262
2001 2.2 WRXRS
Silver Thorn Metallic
god damn.. great info. 3 years later and the pics all still work. this should have been posted at rs25! oh well. hopefully i can still keep in touch with you, 99 rs, just in case i have any ?'s on my swap
weirdpuffy is offline   Reply With Quote
Old 08-10-2011, 09:04 AM   #198
thecrash91
Member#: 284571
props on the hard work man!
thecrash91 is offline   Reply With Quote
Old 09-19-2011, 03:39 AM   #199
dustyroads13
Member#: 274449
2002 wrx
well documented!!
dustyroads13 is offline   Reply With Quote
Old 09-22-2011, 08:48 PM   #200
Asianjimmy
Member#: 295386
2003 Impreza wrx
Rally blue
Default 2005rs swapping the motor for an 96-00 ej20t
I was wondering what all I have to do to complete this swap. Help please?
Asianjimmy is offline   Reply With Quote
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 02:17 AM
STi parts needed to complete kit, look inside RiSti05 Private 'Wanted' Classifieds 22 05-12-2009 05:00 PM
4EAT to STi gas pedal wiring guide Lamont Transmission (AT/MT) & Driveline 0 11-29-2008 12:38 AM
GC RS to USDM WRX/STI wiring guide aspect Subaru Conversions 3 07-01-2008 12:12 AM
HELP-Need to find a wire for switched 12V inside the cabin....anyone know? dchou Electrical & Lighting 2 02-07-2007 10:13 PM
