Old 04-03-2008, 07:20 PM   #1
WhiteH2O
Member#: 452
'06 GX470
Default Keyless entry system going crazy...
My car has been tweeking out lately. It will refuse to start and make a strange clicking sound (parking and guage lights flashing to the clicking). This happened for the third time today, and I found where the clicking is coming from, from the "keyless entry system" box under the dash. Locking and unlocking the car seems to "reset" the problem, although it normaly takes about 5 minutes or so for it to work.
So the question is: how do I fix this?
I have had thoughts of getting an alarm, will an alarm replace this box? Better yet, is the box really the problem, or just a symptom of a bigger problem?
This is on a '98 Legacy with a swap ('02 WRX harness), but the origional keyless system. Problems have just started happening, so I don't really think the problem is with the swap. My guess is that the keyless entry system just went crazy. What do you think?
WhiteH2O is offline   Reply With Quote
Old 04-03-2008, 08:23 PM   #2
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
03 2.5ts BRP long gone
well in 98, the keyless modules were a dealer aftermarket part manufactured by code alarm for subaru.
If it has it's alarm feature turned on and connected, it will activate a starter kill relay which physically cuts the starter wire preventing the car from starting. It sounds like the alarm itself is being triggered. Hence the flashing parking lights. It is usually accompanied by a honking horn or siren but that might not be connected anymore.
Look up a search on the wiring diagrams for those puppies and you should be able to remove it yourself. All you will need is some wire cutters and electrical tape. Just make sure you only cut one wire at a time and then tape it up to avoid blowing fuses and other damage.
If you aren't too comfortable doing it yourself and plan on getting an aftermarket alarm installed. Most shops only charge a nominal fee to remove the existing system.
thedaddyb is offline   Reply With Quote
Old 04-04-2008, 03:11 AM   #3
WhiteH2O
Member#: 452
'06 GX470
Hmm...
I don't think the car had an alarm feature on it (unless the box does, but the remote only has lock/unlock). The box just says keyless entry, and I don't really want to loose my keyless entry feature. I was buying the alarm going off theory for a while, but the keychain remote won't change what it is doing. Trying to lock or unlock it will just attempt to do just that, lock or unlock the car, but it doesn't work (you can hear it trying, though).
Are other people thinking that the box died? Does that sound like the most probable theory?
Old 04-04-2008, 02:19 PM   #4
thedaddyb
Member#: 64374
07 WRX SWP *SOLD
the company I work for does the factory Ford alarms and remote starts.
They are also made by code alarm. (and actually the new subaru remote start modules are identical to the ones we install in fords. Just a different sticker)
Anyways, most of them use a master brain module that is used by all of their systems. For instance, the brain module is identical on the keyless units and the units that also offer alarm features. The only difference being what remotes are included and programming. So it is possible that somehow your keyless module had security features turned on which could be causing the problem.
If you aren't too concerned with an alarm system, a new keyless system can be had very cheaply. Figure units start at less than $50 from reputable brands.
Old 04-04-2008, 04:05 PM   #5
WhiteH2O
Member#: 452
'06 GX470
Very informative, that answered a lot of questions, thanks for the reply.
I have been thinking about an alarm for a little while now, maybe this is my chance to get one. Or, maybe I will go the cheap route and just get a new keyless system.
Keyless entry system problem!!! Leonardo Car Audio, Video & Security 4 03-17-2003 12:53 PM
How easy would it be to remove the keyless entry system? Corn-Picker Car Audio, Video & Security 1 08-15-2002 06:19 PM
FS: Keyless entry system Jgrahn555 Forester Forum 0 05-09-2001 08:38 PM
Keyless Entry System BOB YOUNG Car Audio, Video & Security 1 12-28-2000 12:56 AM
Factory keyless entry system jman2222 Car Audio, Video & Security 4 11-14-2000 05:09 PM
