Old 02-17-2002, 11:38 PM   #1
dark knight
Member#: 9927
06 Sti
Default hsk vs cobb vs stock catback weight ?
fianlly decided on one of these 2 sytems, got pretty much only one last question, how much do these systems weigh in comparison to stock, have realized more weight i remove faster car is, leaning torward the hks system but it is 2.95 inches whereas the cobb is 3 inches and slightly worried the hks may be a little low, so anyone out there that can telll me re:weight
TIA
dark knight is offline   Reply With Quote
Old 02-18-2002, 12:02 AM   #2
Fubaru
Member#: 6046
'08 Prius
By my bathroom scale the stock catback weighed about 37 lbs,
and the Cobb catback weighed 27 lbs. Most of the difference seemed to be in the muffler. What's your worry about the HKS exhaust? I think you mean to say it's 2.5" (not 2.95") compared to Cobb's. No big deal.
Fubaru is offline   Reply With Quote
Old 02-18-2002, 01:12 AM   #3
dark knight
Member#: 9927
06 Sti
i think the HKS is 75mm whch they told me was approx 2.95 inches, i guess if I'm spending more money i want it big, and everyone seems to say if you want more power you need a 3 in exhaust. i'm also worried it might hang too low, that it might scrape, it's alot of money for the HKS but it definitely has style, but I just want the most i can get out of this admittedly small hp mod
Old 02-18-2002, 10:17 AM   #4
SlideWRX
Member#: 3803
07 Mustang GT
285 is a wide tire!
Unless you are replacing the turbo with something a lot bigger, a 2.5 could handle anything the stock turbo can throw at it.
and yes, 75mm ~2.95 ~3 inches, the are basically the same diameter. at 600hp, there might be 2 hp difference between the two.
SlideWRX is offline   Reply With Quote
Old 02-18-2002, 10:34 AM   #5
WRBLUEWAGON
Member#: 10745
2006 VW SUV
I have a three in on my car now and a 2.5 would make the same amount of power. As far as flow. You would need at least a PE turbo to see the limits of a 2.5.
Eric
WRBLUEWAGON is offline   Reply With Quote
FL: Cobb Intake, Stock catback, Single 235/45/17 Tire, Audio, more! anarchyburger South East Region Private Classifieds 4 05-19-2009 06:06 PM
'06 Stage2 Cobb TBE vs Cobb DP+Stock cat back...logs Airboy AccessPort 4 09-12-2006 04:36 PM
It had to happen: Rallitek vs. TWE vs. Cobb vs. OBX equal-length headers? Siper2 Normally Aspirated Powertrain 61 01-17-2006 01:19 PM
Cobb headers - stock catback vs aftermarket chrhon Normally Aspirated Powertrain 7 04-03-2004 10:02 AM
Shifter comparo-Kartboy vs. Cobb vs. Larry's racerwad Normally Aspirated Powertrain 25 10-21-2000 05:20 PM
Message Board Statistics All times are GMT -4. The time now is 10:11 PM.
