Old 04-04-2008, 10:56 PM   #1
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
Default Let's talk about that AC idler pulley
Since I bought my car in december..5 months ago, I always had that whine
which you can hear very nicely here(dont mind the rumble sound, that was fixed) : http://www.youtube.com/watch?v=Ofz0zqp9rY8
Sounds like a supercharger eh? I learned recently it was not normal...I thought it was just how the engine sounds (From outside the car it's very loud).
I took a screwdriver to my hear and listened around the pulleys..the AC idle pulley is obnoxiously loud compared to the AC condenser, crank and alternator pulleys. So I think I found the problem? Does the sound in my video sound like that tiny pulley bearing screaming?
I'm going to replace it, do I need something else than number 3? (maybe number 4?)
..or I thought maybe it's the alternator? how should I proceed, take out a belt at a time and see what happens?
Thanks for the input
Rayme is offline   Reply With Quote
Old 04-06-2008, 11:23 PM   #2
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
#3 went on mine. It's fairly common since it's exposed to the weather and not really protected. I think I had to replace #5 as well since #3 had completely broken and the belt was wearing away at it.
wobbletop is offline   Reply With Quote
Old 04-07-2008, 09:49 AM   #3
ttatsumi
Member#: 85763
How much do the parts go for? Do I just disassmble and put it back or is there a specific steps to do this? Torque specs? Thanks
ttatsumi is offline   Reply With Quote
Old 04-07-2008, 11:22 AM   #4
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
its about 26$
Old 04-07-2008, 12:46 PM   #5
foch
Member#: 163152
Take the belt off and start the engine. See if the sound is still there.
foch is offline   Reply With Quote
Old 04-11-2008, 09:04 AM   #6
SAINTSOFSPEED
Member#: 40596
03 WRX
MBP
I had a similiar problem with #5. It's an easy fix, but make sure you installed 3/4/5/6 without the belt in place. I had a rough time doing the opposite. I can provide instructions when I leave work this afternoon.
SAINTSOFSPEED is offline   Reply With Quote
Old 04-11-2008, 11:51 AM   #7
my scoop eats babies
Member#: 174894
That's definitely your idler pulley. I replaced the pulley and both belts when I did mine, I think the parts were about 50 bucks and it took less than an hour.
I'm not sure if you can get away with replacing just the pulley or if the belts were contributing to the noise, I just replaced the belts while I was at it cause they looked crappy.
my scoop eats babies is offline   Reply With Quote
Old 05-30-2008, 11:53 AM   #8
strohausii
Member#: 26770
'02 WRX
midnight black
My #3 just impaled itself upon #6.
strohausii is offline   Reply With Quote
Old 06-04-2008, 04:41 PM   #9
Shmeebaru
Member#: 121263
02 WRX
Default #3
I had that same noise a while back, now I dont have a/c lol!
#3 into timing cover
Shmeebaru is offline   Reply With Quote
Old 09-26-2008, 04:48 PM   #10
Rally Punx
Member#: 10285
APS Club Spec - Blue
filing for later use
Rally Punx is offline   Reply With Quote
Old 01-08-2009, 09:46 AM   #11
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Yup, I've got this whining sound on my '05 STi (with 41,000 miles), started maybe a month or two ago. I'll have to try removing the AC belt and see if the noise goes away. I hope it's just the idler pulley and not the AC compressor clutch as I'm assuming that would be a more $$$ repair.
AndyH is offline   Reply With Quote
Old 01-08-2009, 11:30 AM   #12
timmah
Member#: 54203
2011 WRX
I had a very similiar sound on my 04 wrx. I don't need A/C in the winter so I just removed the belt, but my A/C was not coming on so I'm assuming it's the clutch.
timmah is offline   Reply With Quote
Old 01-08-2009, 01:29 PM   #13
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Perhaps...but doesn't the car prevent the AC from coming on below a certain ambient temperature (like say 32F)?
I've tried to turn my AC on recently...the light comes on indicating that it's 'on', but I'm not sensing that the compressor is engaged (usually I can tell via a very slight engagement sound, and a slight dip in the RPM's). Granted it's been below 32F for longer than I can remember so perhaps I have to wait until warmer weather to know for sure.
Old 01-08-2009, 01:47 PM   #14
timmah
Member#: 54203
2011 WRX
BTW, according to my subaru dealership, the clutch and compressor are sold as one, and the list price is right around $650.
Yikes!
Old 01-08-2009, 01:48 PM   #15
timmah
Member#: 54203
2011 WRX
I'm not really sure, I don't think that's been the case for me. I stopped noticing the lack of RPM dip and the periodic cooling fan noise missing when the whirring started, though.
Old 01-08-2009, 04:55 PM   #16
Scav1180
Member#: 56832
2004 STI
Java black
Rcv'ed my idler pulley today, was making noises and what from the original one. installing once I get home. if that dont solve the problem then im stumped.
Scav1180 is offline   Reply With Quote
Old 01-08-2009, 08:53 PM   #17
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Yikes!
Oh man, that's what I was afraid of
Old 01-08-2009, 09:26 PM   #18
WRaholicX
Member#: 147306
Where did you find that pulley for $26, I keep seeing them for $50?
WRaholicX is offline   Reply With Quote
Old 01-08-2009, 09:26 PM   #19
Scav1180
Member#: 56832
2004 STI
Java black
well installed the pulley but broke the adjuster.. LOL
so took a/c belt off until adjuster comes in.
the old pulley was making noises when I spun it manually. The new one was nice and quiet and smooth.
Old 01-08-2009, 09:27 PM   #20
Scav1180
Member#: 56832
2004 STI
Java black
subarugenuineparts.com
https://www.trademotion.com/partloca...04&catalogid=2
Old 01-08-2009, 09:33 PM   #21
WRaholicX
Member#: 147306
Awesome, thanks
Old 01-08-2009, 11:40 PM   #22
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
#3 went on my wagon about a year or so ago. It was an easy job replacing it, but IIRC there were warnings in some threads about overtightening some parts when reinstalling.
Coati is offline   Reply With Quote
Old 01-09-2009, 12:49 AM   #23
DC16A2
Member#: 174357
2002 OBS
My AC idler pulley went too a few months ago..
DC16A2 is offline   Reply With Quote
Old 03-25-2009, 11:25 PM   #24
2Lively
Member#: 73340
2002 Subaru WRX
Default Silly question
How do I remove 4 from 3? just take a mallet to it? Does it unscrew some how?
Thanks guys...I busted 5 (same way as everyone else) and figured i'd replace the pully and the belts at the same time...
Joe
2Lively is offline   Reply With Quote
Old 03-26-2009, 01:32 AM   #25
rick-l
Member#: 33868
2003 wrx
srp
Joe
There is a nut that is not shown in the above picture. Just take it off
http://opposedforces.com/parts/impre...te/compressor/
Tighten it back up to 16.6 ft-lbs
It is just a shielded 6012 (??) bearing with a plastic pulley molded on it. I think its position in the front of the engine with the air forcing dirt and moisture in it doesn't do it any good.
rick-l is offline   Reply With Quote
Now that Mother's Day is over, let's talk about what we got our moms. Teh Legacy Off-Topic 70 04-19-2011 01:13 PM
FS: AC idler pulley and shaft from 02 WRX sedan gopsu Engine/Power/Exhaust 1 08-22-2009 11:15 PM
WTB: OR: AC Idler Pulley ej25power NWIC Private Classifieds 0 04-19-2009 09:07 PM
WTB: AC Idler pulley for 1998 2.5 christianvwcars Private 'Wanted' Classifieds 2 04-07-2008 06:25 PM
AC idler pulley help apsrex Service & Maintenance 8 11-25-2007 02:55 PM
