Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Engine/Power/Exhaust
Closed Thread
Old 04-05-2008, 07:35 PM   #1
Innovative Tuning
Vendor Sales Rating: (43)
Member#: 67958
MY96 Time Attack
and 06 STI daily
Default ***Innovative Tuning crate engines, head work, NEW ARP Head Stud Kits, and MORE!!!***
All pricing is valid until we change it or take the sale down!
Innovative Tuning Shortblocks. No core required!
Innovative Tuning Stage 2+ Shortblock:
This is a complete fully assembled shortblock built from a set of brand new OEM 703 casting 2.5L STi block halves and crank from Subaru with upgraded forged pistons, upgraded rings and pins, upgraded forged rods with ARP hardware, and coated bearings.
After evening the piston and rod weights the rotating assembly is balanced to a quarter of a gram or better at 10,000 rpm to ensure smooth operation.
CNC bore and hone are performed using Subaru specific deck plates.
All clearances are carefully checked and adjusted as necessary to extremely exacting tolerances. The new block halves are checked for true and surfaced to a finish beyond the requirements of MLS gaskets.
When it comes to building an engine we believe you either do it right or don't do it at all. We do NOT drop in stock bore pistons!
This shortblock is recommended for 600 crank HP, 8000 rpm, and 27 psi or less in a street, strip, or road race application. Rally engines are built to order and use different components.
3999+freight
Innovative Tuning Big Boy Shortblock:
Those wishing to surpass 600 crank hp and run 30+ psi of boost require something special and here it is. The Big Boy takes the knowledge we've gleaned from track testing and puts it into practice.
The block is line bored and ARP upgraded case bolts are installed.
Race sleeves are installed.
Severe duty forged rods and rod bolts are used.
The Big Boy gets nothing but the best. We recommend an 8500 rpm rev limit and strongly recommend talking to us about a head/cam/valvetrain package to take full advantage of this monster bottom end.
7325+freight
Again there is no core required for these crate engines! If you are unsure which of our engine options best meets your needs, which supporting components you require, or to inquire about freight, please feel free to contact us. Different compression ratio pistons and clearances can be used for those with special needs. If neither package suits you, don't despair. We can just as easily put together a different setup. Contact us for details.
Innovative Tuning Cylinder Head Service
Stage 2 service shown.
Stage 1 Cylinder Head Service for WRX,LGT,FXT,STi:
This is a complete rebuild including:
pressure and leakdown testing
teardown and inspection
cleaning
intake and exhaust valve job
decking and surfacing (in case of MLS gasket usage)
and rebuilding to exacting tolerances with new valve seals.
Damaged parts are replaced as required at additional charge. Customers are contacted after testing and inspection with details on findings and an updated repair cost before proceeding if parts need replaced aside from valve seals.
749+ship
Stage 2 Cylinder Head Service for WRX,LGT,FXT,STi:
In addition to the rebuild detailed in Stage 1 the following SuperTech parts are installed:
upgraded black nitrided stainless intake and exhaust valves (stock size, .5 mm, or 1 mm oversized depending on usage)
heads are ported to accept the oversized valves if they are requested and seats are cut
dual valve springs
titanium retainers
alloy spring seats
1750+ship (shown above)
Stage 3 Cylinder Head Service for WRX,LGT,FXT,STi:
In addition to the rebuild detailed in Stage 1 and the parts listed in Stage 2, Stage 3 includes porting and upgraded camshafts. Cam options vary depending on usage and whether your heads are non AVCS or single AVCS.
4250+ship
Other engine related components:
Kevlar Reinforced Timing Belt for WRX/STi/LGT/FXT - 119 shipped
This timing belt uses Kevlar technology for added strength/longevity and it's only slightly more expensive than an OEM belt. Frankly it's a no brainer.
CP Pistons with CP ring set - 535 shipped!
Cometic WRX, STi or legacy turbo head gaskets - 97 shipped for the set!
Eagle Rods with ARP hardware - 335 shipped!
Carrillo Rods with WMC hardware - 925 shipped!
Carrillo Rods with Carrillo hardware - 1075 shipped!
New and improved ARP Head Studs for WRX, STi, and more - 175 Shipped!
A great addition to any engine build! Greater clamping force helps resist head lift and head gasket failures.
Supertech Valvetrain Set (compatible with Kelford, OEM, and other aftermarket cams) - 329 shipped!
Includes: Dual Springs, Titanium Retainers, and Alloy Spring Seats!
Supertech Valves also available!
Brian Crower, Kelford, and Cosworth Cams. Call for specs, availability, and pricing!
Ultimate Racing GT35R Turbo Kit
This is a complete 650 hp capable turbo kit for the WRX/STi from Ultimate Racing. It includes:
Garrett dual ball bearing GT35R turbocharger
Tial 44mm Wastegate
Ultimate Racing Uppipe with T3 turbo inlet and tial 44 wastegate inlet (vband)
Ultimate Racing 3" Downpipe
Ultimate Racing Wastgate dump tube for Tial 44 (vband outlet)
Ultimate Racing Cold Air Intake (4 inch at turbo inlet)
Turbo Lines and fittings
(NOW all piping in this kit is STAINLESS!!!! )
3250 SHIPPED!
This kit bolts onto stock and stock fitting exhaust manifolds and cat backs. It also fits many intercooler setups both top mount and front mount, such as the Perrin FMIC shown above. Some require retrofit kits (sold separately). Ultimate Racing has produced a kit for the APS front mount, and another for the TurboXS/XSPower/SSAutochrome/Ebay front mount. Contact us for details.
Tuning, fuel system, intercooler and other upgrades such as a clutch are required to properly utilize any turbo kit designed to make this much power. Please contact us for details so we can help you put together a complete package.
Who is this kit right for? Someone looking to make over 400 whp (Dynojet numbers) on pump gas and considerably more on pump/meth or race gas. Built engine not required! Full boost is typically achieved around 4000 rpm on a stock US STi engine at which point you better be aware of what's going on around you because things start happening quickly. This kit is not targetted at the autox/rallyx crowd, but it performs beautifully on a road course, on the street, and at the strip.
Ultimate Racing GT30R dual ball bearing and t3t04 E & S non ball bearing kits are also available!
T3T04E Kit - 2500 shipped!
T3T04S Kit - 2600 shipped!
GT30R Kit - 3150 shipped!
For those looking for a more conservative setup we offer the full line of Forced Performance bolt on turbos!
Forced Performance Subaru bolt on Evo 3 16g Turbos - 875 shipped!!!
If you're looking to upgrade your turbo without taking a big hit in spoolup this is your turbo!
And last but not least...Innovative Tuning Radiator Shrouds for 02-05 Impreza!
For a limited time only these babies are 55 shipped or you can add one to your $100+ order for just 45 dollars!!!
If you don't see what you're looking for here, PM/E-mail/Call us and we'll hook board members up even if your items aren't on sale!!!
NY state residents add 8.75% sales tax as usual. Shipped pricing applies to ground shipments within the lower 48 states.
There are two easy ways to order:
A) Call us at 716-873-7360
B) Paypal us at [email protected]
Mike McGinnis
Innovative Tuning
Voice/Fax: (716) 873-7360
[email protected]
http://www.InnovativeTuning.com
Innovative Tuning is offline
Old 04-07-2008, 12:03 PM   #2
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Added pics of the new upgraded ARP nuts. Be sure to specify the special stud kit when ordering.
Old 04-15-2008, 08:56 AM   #3
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Price drop on stage 2 cylinder head service!!!
Old 04-16-2008, 04:58 AM   #4
WhiteHotWRX
Member Sales Rating: (1)
Member#: 23535
2015 WRX
Galaxy Blue Pearl
Just curious, how long do the head services take?
WhiteHotWRX is offline
Old 06-11-2008, 02:58 PM   #5
modaddict
Member Sales Rating: (20)
Member#: 95840
sold to a good bud
awaiting next car
Thanks for the order Mike.
customer service was top notch. Good chatting with you.
Will do business again!
modaddict is offline
Old 06-16-2008, 11:30 PM   #6
redrex2002
Member#: 118915
2002 wrx
srp
hod my car in their shop a coupple months ago and they were great highly suggest them for business
redrex2002 is offline
Old 06-17-2008, 11:30 AM   #7
modaddict
Member#: 95840
sold to a good bud
awaiting next car
ordered last wednesday, parts arrived on friday
and im completely across the country from them.
WOW. A+
Old 06-17-2008, 07:36 PM   #8
qban32
Member Sales Rating: (10)
Member#: 91169
04 GT35R STi
white
i need an ultimate racing gt35 turbo kit for an 04 sti. PM me ASAP PLEASE!!!!!!!!
qban32 is offline
Old 06-27-2008, 11:59 AM   #9
methaddict
Member Sales Rating: (27)
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Just Paypaled you for the Supertech valve spring kit, great deal.
methaddict is offline
Old 06-29-2008, 03:27 AM   #10
LeeC
Member Sales Rating: (230)
Member#: 97843
9.87 Supra:14 Tundra
c6 z06:Blaze Yellow 02!
Pics of the radiator shroud installed?!
LeeC is offline
Old 07-01-2008, 08:47 AM   #11
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Thanks everyone!
This shroud has been modded to fit a 2006 STi:
methaddict, you have an e-mail.
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Old 07-08-2008, 12:53 AM   #12
methaddict
Member#: 159738
2004 WRB STi
Do you have the Supertech 751 nickel alloy inconel valves? If not in stock can they be dropped shipped to me from Supertech in CA?
Old 07-08-2008, 01:01 PM   #13
akaGeneyus
Member#: 127247
2015 Impreza
nice pricing, im checking the site out now!
akaGeneyus is offline
Old 07-11-2008, 10:43 AM   #14
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
I don't stock the inconel ones, but our distributor or Supertech USA can drop ship for us.
We're short staffed today as Joe and his wife are having a baby so I will probably miss some calls and Mike Jr's 5 year old BMW POS broke down again. Be sure to leave a message if we miss you.
-Mike
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Old 07-15-2008, 09:04 PM   #15
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Go Ultimate Racing! Now all their rotated kits come with full stainless piping and at no extra charge!
We were putting this GT30R kit on a customer car and I just had to take a picture of the shiny new uppipe. I have two 35R kits in stock at the moment which aren't spoken for.
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Old 07-18-2008, 08:58 PM   #16
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
ARP studs and kevlar belts are both back in stock!!!
The 30R kit is on the car and out the door. He's still deciding whether he's going to sand down and polish the APS pipe or crinkle red the UR pipe.
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Old 07-22-2008, 03:18 PM   #17
WRXShawn
Member Sales Rating: (6)
Member#: 35742
2002 PPG + FPGreen
do you guys sell complete longblocks with no core required?
WRXShawn is offline
Old 07-22-2008, 03:33 PM   #18
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
__________________
Mike McGinnis
Innovative Tuning
(716) 873-7360
Closed Thread
CP Pistons / Eagle / Brian Crower / Wiseco / ARP / ACL / Fuel Systems...and MORE!!! Speed Clinic Engine/Power/Exhaust 44 02-10-2009 11:14 PM
500+hp WRX part out- PPG, Built STi block, V7 heads, AEM EMS,67mm turbo kit, and more kpowell12 Engine/Power/Exhaust 204 10-18-2008 02:02 AM
ALL NEW Gruppe-s STI Flywheel!! CUSCO LSD's!! EXEDY CLUTCH KITS AND MORE!! Gruppe-S Drivetrain 2 01-10-2007 04:54 PM
