Old 04-05-2008, 11:27 PM   #1
ornge04gt
Member#: 158779
2008 WRX Stg2Protune
Default new rims and tire pressure light on
Well i put new 17'' OZ rims on my 08 with 225/45 tires. And after about 5 miles of driving my low tire pressure light came on? so i checked the pressure and there all at 35 psi dead nuts. So any suggestions on why this is happening?
ornge04gt is offline   Reply With Quote
Old 04-06-2008, 01:18 AM   #2
Cuppster
Member#: 3043
2008 WRX sedan
Obsidian Black Pearl
Are the sensors in the tires?
Cuppster is offline   Reply With Quote
Old 04-06-2008, 02:03 AM   #3
CynicX
Member#: 48199
06 WRX
The sensors are with the old wheels. There for it thinks you have flat tires....
CynicX is offline   Reply With Quote
Old 04-06-2008, 08:02 AM   #4
ornge04gt
Member#: 158779
anyway to bypass it?
Old 04-06-2008, 09:44 AM   #5
CynicX
Member#: 48199
06 WRX
Yep. The sensors are behind the valve stems. You have to remove the tires, take off the valve stems and install them into the new wheels. This will obviously be a huge pain in the ass for you seen you'll have to dismount, remount and balance 8 tires....
Old 04-06-2008, 10:05 AM   #6
ornge04gt
Member#: 158779
any way to bypass with out the use of the sensors?
And can the wheels be balanced on a regular balancer with the sensors in?
Old 04-06-2008, 10:12 AM   #7
CynicX
Member#: 48199
06 WRX
Not sure of a way to bypass it. The way the system works is when the tire rotates around 10-20 mph it activates the sender which each one has its own ID code that sends a signal to the receiver that either tells the ECU everything is good or you have low pressure.
So its a little difficult to bypass. Looking for a way to just disable the dash light would probably be the easiest thing too do....
The wheel/tire/sensor will balance fine on a normal balancing machine....
Old 04-06-2008, 12:10 PM   #8
jonney_boy
Member#: 28747
06 WRX
you can also buy additional sensors..... I think even tire-rack offers them (about $150 for a set of 4)... the bad part... you need the dealer to "register" the new set of sensors with the car... and the car and only have 4 sensors registered on it at a time..
This means when you swap back to your other set of tires...... you have to go back to the dealer (which might be cheaper than swapping out the sensors and rebalancing 8 tires).
jonney_boy is offline   Reply With Quote
Old 04-06-2008, 01:29 PM   #9
ornge04gt
Member#: 158779
So will driving with light on cause any effects from normal? And there arnt like fuses or relays to fully disable it for temporary? Or how can i get the light to go out? I really dont need this feature. never had it any other car and i know how to keep an eye on my tire pressure
Old 04-06-2008, 03:07 PM   #10
Member#: 67
1999 Outlasting
the competition.
pull the gauge cluster apart and put some black electrical tape on there. or leave the light on.
T
Old 04-06-2008, 03:48 PM   #11
ornge04gt
Member#: 158779
T
will the light effect the ecu in anyway though? like go into any safe modes or something among the lines of that?
Old 04-06-2008, 03:59 PM   #12
CynicX
Member#: 48199
06 WRX
No the light is just and indicator of tire pressure, wont really affect much else....
Old 04-06-2008, 10:33 PM   #13
jonney_boy
Member#: 28747
06 WRX
Not sure how easy this would be... but remove the bulb?
New Rims and Tires... need size advice for Tires LuckyStar Tire & Wheel 4 01-22-2010 07:31 PM
New rims and tires installed on 08 wrx Bobby2008WRX Tire & Wheel 6 06-09-2008 12:41 PM
New rims and tires in! not on :( Jpizzzle Tire & Wheel 1 11-02-2006 05:24 PM
New clunk in back after getting new Rims and tires jedz123 Transmission (AT/MT) & Driveline 1 04-20-2005 07:26 PM
new tires vs. new rims and tires voam Tire & Wheel 7 04-25-2003 07:08 PM
