Old 04-06-2008, 12:23 AM   #1
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Default CP drop in pistons with 07 sti heads????
so what`s the final compresion ratio on a sti MY07 using off the shelf drop in cp pistons made for the older stis??
The 07 head is different with egr provision and smaller ports...
My static compression is 105 psi with stock 07 sti heads and cams
Any insight ideas regarding this????
Thanks
DJ
DJIMPREZA is offline   Reply With Quote
Old 04-06-2008, 12:41 AM   #2
n2oiroc
Member#: 141952
03 emo 8/2011 wrx
i really wish someone would cc a set of 07 heads!
n2oiroc is offline   Reply With Quote
Old 04-06-2008, 01:13 AM   #3
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
I just pulled my CP drop in pistons. They were loud as hell and would let oil blow by like crazy. I dropped the stock STI pistons back in and the engine is back to running perfectly.
Valhakar is offline   Reply With Quote
Old 04-06-2008, 01:21 AM   #4
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Mine are perfect and zero blow by, just a though on a possible lower CR than previous years...
Cossworht offers a different head set combo for 07 stis... maybe just provision for egr..
Old 04-07-2008, 01:01 AM   #5
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
anyone???
Old 04-07-2008, 01:13 PM   #6
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
what`s the static compression test results on a 07 sti? around 140 right?
Old 04-07-2008, 03:01 PM   #7
jays05
Member#: 78165
05 STI 35r + e85
With off-the-shelf CP 100mm pistons, OEM head gaskets, and .003" off the cylinder heads, I had 120 compression. 135 on the stock motor with the same gauge. MY05 heads.
jays05 is offline   Reply With Quote
Old 04-07-2008, 06:10 PM   #8
MartinSTi05
Member#: 145145
2006 wrx STi
I have the equipment to CC heads if anyone near N illinois has a set of heads they want CC'ed
MartinSTi05 is offline   Reply With Quote
Old 04-08-2008, 04:45 PM   #9
cdigerlando
Member#: 6070
9202 SVX, WRX
92 Sil/Blk, 02 Sil
Default Your CP pistons
What bore clearances were you running?
cdigerlando is offline   Reply With Quote
Old 04-08-2008, 08:39 PM   #10
ronzogonzo
Member#: 136671
WRX HTA GT3076R
9cm2 eWG'd It's ALIVE!!
I'm running CP'S haven't done a comp test yet, but I'm having issues with rogue smoke at start up once in a while I'm kinda concerned I guess. I mean I kinda figured that there would be alittle blow by, but it seems kinda odd that there is no pattern its just random.
ronzogonzo is offline   Reply With Quote
Old 04-09-2008, 02:52 AM   #11
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Seems like and error on rings posture on pistons or either cyl wall premature wear or something.. I have done many drop in cps with no smoke at all
Check your pcv system?
2.5 CP drop in pistons std bore 8.2:1 BoostInc Engine/Power/Exhaust 4 06-01-2010 02:24 PM
WTB: EJ257 with drop in pistons tjphillips36 Private 'Wanted' Classifieds 2 03-02-2009 02:13 PM
CP drop in piston installment Q`s?? DJIMPREZA Built Motor Discussion 4 04-11-2008 03:12 AM
FS: K&N Drop-in Filter 02-07 WRX/STi kennyvb SCIC Private Classifieds 5 01-03-2008 11:43 AM
What`s the CR from sti 07 USDM heads and CP drop in pistons? DJIMPREZA Built Motor Discussion 5 10-10-2007 11:58 AM
Message Board Statistics All times are GMT -4. The time now is 03:48 AM.
