Old 04-06-2008, 11:40 AM   #1
fastlanerex
Member#: 133391
2004 boosted saleen
white
Question Valve spring compressor tool
I need a valve spring compressor tool to get my valves out of a 2.0L wrx. The heads are off the block and i need to get these out so i can send my heads to the machine shop. What tool and where do i buy this at? I got a loaner from autozone but it wont work with the way these heads are setup.
pics/ links would be great thanks.
DREw
fastlanerex is offline   Reply With Quote
Old 04-06-2008, 12:02 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
get one that reaches around the head. such as, one side fits on the valve face, there is a large arm that reaches around with a sort of lever, and the other side fits on the the retainer. I bought a crappy one that fits in your hand and had to mess with it to get it to work. get the reach-around! yes, I'm aware of that connotation...or is it denotation?
Old 04-06-2008, 12:58 PM   #3
fastlanerex
Member#: 133391
2004 boosted saleen
white
nevermind i got them out using my grandpas old method. i remembered. Im not reusing the valvetrain so i put a socket on the top by the keepers on an extension smack the extension with a hammer and voila the keepers pop out releasing the spring.
Old 04-06-2008, 03:14 PM   #4
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
That's good. How do you plan on getting the new stuff back in?
I rented one from Checker that reached around, but I had to take a piece of 3/4" PVC sprinkler pipe, and cut the flared end off (about 2 inches). I then cut through the piece lengthwise and took about 1/4 of the side off. It fit perfecty snug in the tool, and then I had an opening to work with getting the valve keepers in/out.
paintbing is offline   Reply With Quote
Old 04-06-2008, 08:28 PM   #5
fastlanerex
Member#: 133391
2004 boosted saleen
white
not worried about that at the moment the heads are going to be dipped and ported so i wil take care of that later.
Old 04-06-2008, 08:31 PM   #6
9vapors
Member#: 92582
How are they looking?
9vapors is offline   Reply With Quote
Old 04-23-2008, 03:07 PM   #7
charliew
Member#: 125304
I had a reach around tool for working on v8's and used some conduit and made a extension that bolts on the spring tool and it works great. I think it is 1 inch conduit. I cut four small rings (about 3/8 wide) and then cut two of them in half and then welded the halves on the outside of the other two rings with about 1/8 hanging over the edge. That made a cup that fits the retainer real tight. Then I took two straps about 2 1/2 long x 1/2 wide about 1/8 thick, and welded the straps inside the rings on each side, that makes the opening to get to the keepers. Then I welded a washer on the other end of the straps to bolt it to the tool. Look at a factory made tool and copy it.
Whatever you do don't use a tool that will scratch the inside of the bore for the buckets.
charliew is offline   Reply With Quote
Old 04-23-2008, 04:22 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
use to use one of the arm ones...then went to a blue point, rail/fulcrum one....now I usea peterson valve and guide machine with locking press...
basically a drill press that locks into place
Old 04-23-2008, 08:05 PM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
bought one from sears for ~25 bucks.
i use 22mm 1/2 socket to put the valve keeper
back on with hemostats..
Old 04-23-2008, 08:12 PM   #10
bertune
Member#: 107290
OTC tools. Part no. OTC 4572.........ebay
bertune is offline   Reply With Quote
Old 04-23-2008, 10:21 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^ That looks similar to what I made using a bigasz C-clamp and a small length of broomstick with the end hogged out to allow me to place/remove the keepers.
I tried PVC tubing but once I get grease on my fingers or on the retainers....it eventually finds it's way to the bottom of the tool and slides around too much. The wood seems to work pretty good, but isn't the most robust once the end is hogged out.
Jay
Old 04-29-2008, 04:22 AM   #12
col5555
Member#: 142017
Has anyone seen a compressor that uses a gear drive system instead of the more common lever type.
I have seen a picture of one but have never been able to find a manufacturer.
col5555 is offline   Reply With Quote
Pair of cylinder head work stands & 10" valve spring compressor tool methaddict Engine/Power/Exhaust 14 09-08-2009 05:01 PM
valve spring compressor tool Gixxer1K North West Impreza Club Forum -- NWIC 1 06-04-2009 09:18 PM
Self-made SOHC valve spring compressor White 2.5rs Private 'For Sale' Classifieds 5 06-29-2004 02:56 PM
Can anyone recomend a good valve spring compressor roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-12-2004 04:33 PM
Spring compressor tool? gregsatt Texas Impreza Club Forum -- TXIC 6 10-24-2003 09:54 AM
