#1 |
Member#: 123767
Vehicle:2009 WRX Stage 2+ Gray |
my AP has always read roughly -8.9 -9.1 vacuum consistantly for a long time. i happen to stubble across a thread with people saying they averaged 20...mods are vf34 P&P, Big TMIC, STi pinks, prodrive solenoid, k&n typhoon etc... even after my protune with a vacuum leak test it read this. just curious if this is normal. if not how do i go about making a vacuum leak test myself? thank you for any answers.
#2 |
Member#: 70395
Your AP doesn't read vacuum (inHg) it reads pressure.Big difference when the people saying 20 are refering to 20 inHg and not psi.
#3 |
Member#: 123767
ohhhh, alrighty thank you, answers my question ha.
#4 |
Member#: 118209
Vehicle:2002 WRX Sedan |
The ap actually reads negative psi? I'd be surprised, technically that doesn't exist and makes zero sense as a measurement. also makes a big difference if it is related to absolute pressure or relative, i know the subaru ecu measures and has outputs for both.
#5 |
Member#: 147610
Vehicle:2007 Stage 2 STi WRB |
On my ap is says relative pressure. How is this different from absolute pressure?
#6 |
Member#: 48199
Vehicle:06 WRX WRB |
Get a boost gauge and you'll see the same numbers everyone else with a boost gauge sees....
#7 | |
Member#: 118209
I know my scangauge shows both, it has manifold absolute pressure as well as relative pressure. The ECU measuring absolute pressure allows the car to compensate for altitude better. |
| Thread Tools | |
| Display Modes | |
| My car shakes at idle, vacuum goes to -25 at rev... leak?? | elitescouter | Newbies & FAQs | 18 | 07-10-2009 02:24 AM |
| idle vacuum | Serkan | Factory 2.0L Turbo Powertrain | 1 | 05-23-2009 06:49 PM |
| Flexible 3" Tubing That Won't Collapse Under Idle Vacuum? | williaty | Normally Aspirated Powertrain | 15 | 01-31-2008 11:06 AM |
| Problems: P0102, Idle, Vacuum | MidRex | Factory 2.0L Turbo Powertrain | 9 | 04-07-2006 04:24 PM |
| normal idle or what? | toolman69 | Factory 2.0L Turbo Powertrain | 2 | 12-09-2003 08:39 PM |
