Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-07-2008, 12:23 PM   #1
foch
Member#: 163152
Default Crankshaft pully question...
Hi,
I'm gearing up to replace my first Subaru timing belt (1995 Legacy, 173,000+ miles, AT).
I've read about the 'bump the starter' method for loosening the crankshaft pully nut. Sounds like a a good trick.
But if I use this method, how would I hold the pully to properly torque the nut?
Thanks.
foch is offline   Reply With Quote
Old 04-07-2008, 12:43 PM   #2
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
Search the forums for the 4EAT inspection hole.
I am not sure of your car has a 4EAT, but I would suspect that the transmission has a similar hole that had a rubber plug covering it where you can look down at the Torque Converter.
You find that hole, Jam something really long and sturdy in it like a crowbar, and tighten/loosen away.
MAKE SURE YOU TORQUE YOUR CRANK PULLEY DOWN TO SPEC
You don't want a wobbler that eventually shears the end of the woodruff key.
Good Luck and use the Force.
birukun is offline   Reply With Quote
Old 04-07-2008, 12:48 PM   #3
burm
Member#: 153807
2001 Impreza rs
Aspen white
I just did it on my AT, just get a breaker bar, theres a why to stick a screw driver to the left of the pulley, so when yo loosen it the pulley will not move. Then your all set.
burm is offline   Reply With Quote
wtb - PA crankshaft pully Scooter Sube Tri-State Area Private Classifieds 2 11-21-2009 05:05 PM
wtb- PA area Crankshaft pully Scooter Sube Private 'Wanted' Classifieds 2 11-20-2009 06:35 PM
new gruppe-s lightweight crankshaft pully toulakid Engine/Power/Exhaust 2 10-02-2008 08:40 AM
Under drive pully question John*G Normally Aspirated Powertrain 3 02-10-2005 10:16 AM
pully question? JP Vancouver Impreza Club Forum -- VIC 4 05-26-2001 04:04 PM
