Old 04-07-2008, 08:09 PM   #1
djtmalta
Member#: 93573
Question E-Brake warning light fluttering on and off while car is driving?!?
E-Brake warning light fluttering on and off while car is driving?!? Does anyone have any idea why this would happen? I have made sure that the e-brake is completely all the way down and not engaged. I have no clue why this just happened.
I have a 03 WRX Sedan. Any help would be appreciated!
Thanks,
David
djtmalta is offline   Reply With Quote
Old 04-07-2008, 08:14 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
check to see if you have enough fluid in the brake fluid reservoir. when the fluid is low, the light comes on.
the issue could also be a faulty switch on the handbrake or the ground wire may be coming loose.
jdubya301 is offline   Reply With Quote
Old 04-07-2008, 08:15 PM   #3
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
same thing just started to happen with mine, but i had not driven my car all weekend and i left the handbrake on...i flipped it up and down a few times and it went away. then i took a corner hard and it turned on, then i turned again and it turned off. i figured it was teh fluid level.
SedonaScooby is offline   Reply With Quote
Old 04-07-2008, 08:27 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Yep check your brake fluid. This is a maintenance issue not an electrical issue, so moving to the proper forum.
If you do find the fluid to be low, do NOT just add more. The usual cause for low fluid is worn pads (assuming there is no leak), and filling the reservoir before putting new pads in can cause it to overflow later.
Old 04-07-2008, 11:46 PM   #5
djtmalta
Member#: 93573
I checked the brake fluid levels and they are fine. I even had the car serviced at the dealer 2,000 miles ago. I just can't figure out what it might be....?!?
Old 04-08-2008, 12:05 AM   #6
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
bad connection to the switch?
radio cuts on and off while driving SubaruImpreza_power Car Audio, Video & Security 8 06-22-2009 09:43 AM
My F90BT Navigation Keeps Turning On and Off While Driving wrxgeneration Car Audio, Video & Security 6 12-31-2008 04:12 PM
Brake light comes on and off but not low on brake fluid? IIdiceII Brakes, Steering & Suspension 5 09-13-2007 10:44 PM
Battery and brake lights flickering on and off together. AcquaCow Electrical & Lighting 2 07-04-2004 02:21 PM
A little help, cel flickering on and off while driving!! wrxplaya11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-27-2004 09:05 PM
