Old 04-07-2008, 09:53 PM   #1
KW_Scoob
Member#: 173348
World Rally Blue
Smile Misfire after changing plugs? Check this fix!
Hey everyone.
I changed out my plugs on my 2002 WRX wagon yesterday for the first time (new car to me) and man... What a PITA compared to my b-series swapped civic!
Anyways, all was good and the stock temp NGK iridiums I put in made a noticeable difference vs. the old & used up one step hotter NGK-Rs (no surprise). The car was really doing much better until about 30 seconds from work today! Then all of the sudden I lost power, and the CEL started flashing... definitely felt like a misfire. I tried to pull the code with my canobd2.com 3100 C but it couldn't read it (I fixed that too by upgrading the software WOOHOO!) so I was on my own.
I limped the car home at lunch and took the Kawi back in. When I got home after work I went to work pulling all the plugs (waaaaay faster this time!) and when I got to the left hand rear plug I found the problem!
It seems that the tab that clips the coil on plug assembly to the harness snapped off and it had just fallen off!
I called the local dealer... $160 CAD for the part. Then I went to Home Depot - $2.91 for Krazy Glue Gel... GUess which one I picked
So I glued the plug on with a generous amount of Krazy glue and left it for about 5 min- it's on there for good now and the car is running solidly again!
Soooooo long story short: If you just changed your plugs and now you've got a misfire be sure to check all the coil->harness connectors to make sure they're really "clicked" in and secure and not simply "pressed in" with a broken clip!
Cheers!
KW_Scoob is offline   Reply With Quote
Old 04-08-2008, 03:24 PM   #2
AlboWRX
Member#: 37719
2003 WRX
I don`t like to glue anything because if I would like to move something around, I won't be able to!
AlboWRX is offline   Reply With Quote
Old 04-09-2008, 04:50 AM   #3
imprezilization
Member#: 73471
2004 WRX Stg2+some
Blk melon launcher
look at the bright side: at least it wasn't duct-taped!
but I'll have a hard time justifying spending $160 on a little plastic pos too
imprezilization is offline   Reply With Quote
Old 04-09-2008, 03:28 PM   #4
strohausii
Member#: 26770
'02 WRX
midnight black
Keep an eye out if it reoccurs, I've found that crazy glue (cyanoacralate [sp]) to make plastic brittle (kinda like overcooking welds where the weld is ok, but the metal around is fatigued). Maybe a 2 part epoxy might be a good option too.
strohausii is offline   Reply With Quote
Bad misfire after spark plug change ... doesn't start immediately! DHutch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 04-25-2016 09:05 AM
first cylinder 1 misfire, after plugs, 1,3,4 misfire! DieselClown Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 08-26-2008 02:59 PM
misfire/bogging after new plugs... BugeyedMonster Newbies & FAQs 14 08-30-2007 09:10 AM
Misfiring after spark plug change Nuke209 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-29-2007 06:12 PM
throwing misfires after changing spark plugs Pungistik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-08-2006 07:42 AM
