Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-07-2008, 10:22 PM   #1
burm
Member#: 153807
2001 Impreza rs
Aspen white
Default crank sprocket removal
I need to replace the woodruff key, and the crank seal. I need to remove the crank sprocket. Everything I've read says to wiggle it and it will come off, but thats not working for me. Also, the old woodruff key is worn down and out of shape. Could this keep the sprocket from sliding off? And advice ideas of suggestion would be great. Thanks
burm is offline   Reply With Quote
removing crank sprocket? 98tredsvt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-05-2009 06:17 PM
guys - crank sprocket 1993 impreza 1.8 auto fwd jimkelly Normally Aspirated Powertrain 1 09-23-2007 02:25 PM
Crank sprocket differences between 2.0 and 2.5 fastlane Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 04-06-2006 01:58 AM
Crankshaft sprocket removal as part of camshaft removal jblaine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-12-2005 05:27 PM
Crank sprocket for a 93' EJ18 EcksJay Private 'Wanted' Classifieds 0 05-18-2005 07:00 AM
