Old 04-15-2013, 08:25 PM   #326
chimchimm5
Member#: 88501
2011 WRX Hatch
Dark Grey
Originally Posted by Dat8687 View Post
Thanks... Yea it was in the juggernaut mode for the last week because I didn't even check the struts.. I didn't realize they would be set to full stiff stock.. Well one side was the other was one from it.. Now I know why one side felt slightly different than the other.
I at the 5TFFS and I will do what you stated drive it some more on the highway etc gauge the the bumps I normally go over when im on the freeway near me.. And adjust it accordingly.. I will post back in a few days to see where im at on the settings.. In the juggernaut mode I was being vary wary of the bumps I know because I basically remember them all. And would have to slow down crazy to avoid the stiffness of the setup.
Thanks again
BTW adjust all 4 corners at the same time until you hone it down to the window. Then fine tune each end from there.
You don't have to just be on the freeway... 30-50 mph roads will do too.
Since we're not competing at the National level, etc; my philosophy is to get the car to a "working" level. Then it's more about the driver than anything else. WRC drivers would beat us with two blown tires and a busted up car... all about the driver.
chimchimm5 is offline   Reply With Quote
Old 07-10-2013, 05:21 PM   #327
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Ok... I readjusted mine again
RSR Ti2000 springs
17x9 Enkei RPF1s
235/45 17 Goodyear Eagle GTs
I set the front to 6 from full stiff..
It almost rides like stock now completely
Dat8687 is offline   Reply With Quote
Old 07-11-2013, 08:33 PM   #328
soulbazz
Member#: 95916
2004 Impreza WRX
1998 Legacy GT Wagon
2004 wrx sedan 86k miles
4.75 tffs F
5.25 tffs R
STi takeoff springs
Grp N tophats
soulbazz is offline   Reply With Quote
Old 06-09-2016, 01:24 AM   #329
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
I've been searching and thought this might be the best place for my question. I have a MY2005 Legacy GT with tokicos and swift sport springs. The spring rates are 241lb/in F and 370 lb/in R.
Any suggestions on the settings for this combo? Should the rear be stiffer than the front? Thanks.
rhino6303 is offline   Reply With Quote
Old 06-09-2016, 08:57 AM   #330
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
^^^Given your rear springs are considerably stiffer than the fronts, yes, your damping setting needs to be stiffer. I can't tell where to set the adjuster to as you'll have to figure this out by trial and error.
A-man07 is offline   Reply With Quote
Old 06-09-2016, 07:25 PM   #331
rhino6303
Member#: 181314
05 Legacy GT RBP
Ok. Thanks for the reply.
Gauging interest: Tokico D-spec + new Swift R-spec springs Turn in Concepts Vendor 'Group Buy' Classifieds 45 03-09-2008 10:55 PM
ONE SET Tokico D Spec IN STOCK ON SALE. + Koni inserts & Crucial Springs in stock! Crucial Racing Suspension/Brakes/Handling 7 10-26-2007 02:07 PM
what are your tokico d-spec settings? ASpec818 Brakes, Steering & Suspension 7 07-30-2006 06:26 PM
Tokico D-Specs? BAC5.2 Brakes, Steering & Suspension 2 11-02-2004 06:28 PM
Tokico d-spec struts pyropretz Brakes, Steering & Suspension 12 09-22-2004 03:32 PM
