Welcome to the North American Subaru Impreza Owners Club Tuesday September 1, 2015
Old 02-19-2010, 10:48 AM   #176
bzbuzz
Member#: 116052
2011 STI ( Sold )
RCE yellow,
4 TFFS front and 4 1/4 TFFS rear
pefect for DD
bzbuzz is offline   Reply With Quote
Old 02-19-2010, 11:01 AM   #177
trick3d
Member#: 202146
2010 evoru
GG
Default Re: Compiling Tokico D-Specs settings
Seems like guys running the rce springs like around 4-4.5 tffs for dd.
trick3d is offline   Reply With Quote
Old 02-22-2010, 02:52 AM   #178
trini_suby
Member#: 174931
2005 Impreza WRX
CGM
2005 wrx
tanabe GF
2 turns from full stiff front
2 1/2 turns from full stiff rear
front strut brace
subframe H-brace
stock sway bars
17 x 8 ROTAs w/ 245 falken fk452s
Handles decently
I definitely need to make adjustments for best performance.
I dont really care for a comfortable ride since i barely do 6000 miles a year and i drive it fairly aggressively all the time. Its stripped of back seat, back rest, rear mats, spare tire, jack, trunk carpet, everything back there is out.
Im not sure how impressed i am with these shocks, although i know it might be me my lack of fine tuning and not buying a rear sway bar. Ive got a front cusco sway that isnt installed.
My old 99 Audi A4 on Bilsteins and Tein S techs was far more sure footed than the wrx is now. The Audi was heavier and much slower, and also had crappy wheels and tires.
I hope the thicker sway bars, some fender braces and some rear T-braces pull it all together.
trini_suby is offline   Reply With Quote
Old 02-22-2010, 10:33 AM   #179
bzbuzz
Member#: 116052
2011 STI ( Sold )
Originally Posted by trini_suby View Post
2005 wrx
tanabe GF
front strut brace
subframe H-brace
stock sway bars
Handles decently
try softer, too stiff..
stiffer =! better handling
Old 03-03-2010, 06:47 PM   #180
trick3d
Member#: 202146
2010 evoru
GG
Shouldn't you adjust your struts to complement the spring rate? Not sure about the 2tffs sounds pretty agressive.
Old 03-03-2010, 07:30 PM   #181
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
The damping of the struts should be set with spring rates and road/track surface in mind.
SubySal is offline   Reply With Quote
Old 03-03-2010, 07:38 PM   #182
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
2 tffs is WAY too stiff. We find that for most stiff springs (swift spec r, RCE) the optimal range is 4-5 tffs. No more is needed.
Tony
Old 03-03-2010, 08:43 PM   #183
trick3d
Member#: 202146
2010 evoru
GG
Tony
+ 1 great performance at those settings.
Old 03-09-2010, 12:32 PM   #184
viper74656
Member#: 84758
'04 WRB WRX
2004 WRX Sedan
4.25 TFFS front, 4.75 rear
Swift Spec-R springs
14 3/8" front; 13 1/2" rear (1/4" saggy butt spacer in rear)
GTWorx front camber plates, Group N rears
24mm front/22mm rear sway bars
17x7 Prodrive P1 wheels, Dunlop star spec tires (225/45/17)
-2.5 camber front, stock rear...0 toe
This is my DD setting. For autocross I've cranked the struts up to as much as 2.5 TFFS and it performs very well. It is unbearable to drive that stiff on regular roads however so thank goodness for the rear adjustment extenders.
4.75 out back seems to be the right setting to eliminate most of the rear strut clunk, at least on my car.
viper74656 is offline   Reply With Quote
Old 03-22-2010, 07:27 PM   #185
genkidama20
Member#: 73635
04 WRX
WRB Wingless
2004 WRX Sedan
RCE Black "Regular Guy" Springs
GroupN Front/Rear mounts
1/4" Saggy butt spacer
22mm Cusco Adjustable
Stock wheels, Pirelli Nero Pzero M+S tires
Approx: -1.0 camber front, -.25 rear (closest I could get to zero), 0 toe
DD: 4.25 TFFS front, 4.75 TFFS rear
genkidama20 is offline   Reply With Quote
Old 03-29-2010, 06:25 PM   #186
miyagi
Member#: 162476
2016 WRX Limited
2004 wrx wagon
F: 5.5 TFFS
R: 5.5 TFFS
USDM STi take-offs
Stock wheels w/ potenza re960 all weather tires
Just put these on yesterday and am loving the ride so far, huuuuge improvement over the stock struts (especially w/ one of em blown). Thanks again TIC!
miyagi is offline   Reply With Quote
Old 04-01-2010, 01:24 AM   #187
gooder77
Member#: 32922
2002 WRX sedan
2002 Subaru WRX (sedan)
5.0 TFFS Front / 5.0 TFFS Rear *Break in only*
sti takeoff springs
Group N Front top / Sti rear top
TIC spacer
22mm FSB/ 20-22-24 RSB
Falken Ziex 912 tires
-1.4 camber front / -1.0 camber rear / 0 toe
"downgraded" from Whiteline G4, but I actually like this setup a lot better. No more being tossed around when driving in downtown and on the many bad roads in Baltimore. Wife actually liked riding in the car for the first time in 5 years
gooder77 is offline   Reply With Quote
Old 04-14-2010, 08:02 AM   #188
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Originally Posted by SubySal View Post
I think I found my sweet spot...
I've had my struts in a while now. To refresh...
Dspecs/RCE black springs, Whiteline bars: 22mmFSB, 22-24-26mmRSB.
I have different settings for street and autocross, but the car seems great both ways as well as extremely consistent and forgiving. I use 5.5TFFS F&R for street and 3.5 TFFS FR, 4-4.5 TFFS RR for autocross. The car had been awesome. Last event I had my best finish ever. It was cold and the lot was uneven so the stiff suspended R comp cars were having issues, but I pulled off my best run ever finishing first in STX and 7th overall out of 80 drivers, not to mention a girl I had co-driving with me finished first in her class and she had never driven or even rode in the car before. BTW the rest of STX was on coilovers.
I really love these struts! After I got them I was able to install the stiffer RCE Blacks. A phenomenal upgrade from the Prodrives I was using before and almost magically the whole suspension, the whole car just came together! My points jumped from high 800's very low 900's to well into the 900's and my last points score was 974! Plus the car is just way easier to drive... no more bouncing off bumpstops during high-G turns with sticky tires. HOORAY!!
That sounds like a good setting, I have a similar setup. Going to give it a try today.
nightcrawler60 is offline   Reply With Quote
Old 04-14-2010, 11:48 AM   #189
cstyker1111
Member#: 69521
2004 WRX
JBP
What about some settings with JDM pinks (the 252/217 rates)? What settings for those for typical 04 WRX DD?
cstyker1111 is offline   Reply With Quote
Old 04-14-2010, 12:17 PM   #190
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
First off, I would like to educate some about these settings.
There is no TYPICAL setting for DD or AutoX/Track. There is really only one setting. That setting is called optimal. Notice how Tony never really said two settings? That's because there really isn't two. I just wanted to get that clear.
A set of springs with a set spring rate only has 1 proper dampening rate. It can work with many dampening rates, but at any other dampening rate, you will be either losing too much feel, grip or both.
The reason why people go stiffer for autocross is because it does actually improve the reaction of the car and reduce roll. However, at the end of the day, you're ultimately losing too much grip, and making the dampers do work that a spring and swaybar is supposed to do. I used to have higher settings for autocross thinking that with some doodling I could decrease the understeer a little. Then I got a bigger front swaybar, dialed down the rears and fronts. Man, what a difference... Point is, use the proper parts for the proper purpose.
Now, for the actual answer. 5-6 FR should be your optimal range. Whether you want to make it stiffer or softer than it's supposed to be, that's your call. Keep in mind that even with the best manufactured struts, there will always be some sort of variance. I imagine with cheaper struts such as these they manufacture tolerance is a bit higher, so your settings will vary.
formula91 is offline   Reply With Quote
Old 04-14-2010, 03:37 PM   #191
cstyker1111
Member#: 69521
2004 WRX
JBP
Cool, is there a chart or something that shows dspec settings compared to spring rates? Like I thought that there would be a bigger difference between dspec settings with JDM pinks compared to blue Prodrives for example...
Old 04-14-2010, 07:51 PM   #192
SubySal
Member#: 43011
2004 Impreza RS
Yup this is all true. There is really only one optimal setting for a given spring rate to properly dampen a spring. I however knowingly stray from that setting for the exact reason stated. In autocross when trying to set up a dual role car it's nothing but compromises.
So to make the car a bit more bearable over the road I slightly under-dampen the springs. Not enough to bounce up and down three times, but just enough to take out a bit more harshness.
The same goes for autocross, but in an inverse way. I over-dampen the springs a bit there to give me a quasi-stiffer spring rate.
It's a compromise I'm willing to make with the springs and dampers and even though they may not be optimal for the springs these settings work very well for me.
Old 04-14-2010, 07:55 PM   #193
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yeah, I've been sitting back, watching this thread for, what, 2 years now, shaking my head the whole time going "why on earth are people choosing the wrong damping?" the whole time.
Old 04-18-2010, 05:01 PM   #194
trick3d
Member#: 202146
2010 evoru
GG
Old 05-06-2010, 03:11 PM   #195
trini_suby
Member#: 174931
2005 Impreza WRX
CGM
can someone suggest what setting i should use with the tanabe GFs
325 lbs/in front
246 lbs/in rear
previously had it too stiff (2 turns and 2.5), now at 4 turns front, 4.5 rear. Feels much better. But would like advice from someone with more experience with them.
I dont care about daily driving or comfortable. I use this car at the track and autocross.
Old 05-06-2010, 06:30 PM   #196
JohnSellers
Member#: 182253
2002 Impreza OBS
Newton - not just a good idea; it's the law!
JohnSellers is offline   Reply With Quote
Old 05-15-2010, 03:53 PM   #197
mikedsilva
Member#: 230453
2007 WRX-tuned bysti
Originally Posted by jay3737 View Post
'06 WRX sedan, 38k miles
- daily driving: 4.5 TFFS F&R
- hpde: 2.5 TFFS
- TiC rear strut top spacer
- springs: swift spec R
- RCE camber lowering plates
- strut bars : whiteline 24mm F / 22mm R
- kartboy endlinks
- summer wheels & tires: rota torque 17x8 / falken azeni st115 235/45/17
- track wheels & tires: rota g-force 17x8 / yokohama s. drives 225/45/17
- alignment: -2.5 F / -1.7 R / 0 toe all around
very pleased w/ride for DD setup, and even more pleased with HPDE setup. after 2 events this year, starting to get clunking from the rear, but plan to get under the car this weekend and make sure the noise source is not something else (loose endlink, sway, etc).
i am now looking at getting this same setup for my my06 wrx sedan.Tokico dspecs and swift spec r springs.
It will be a daily driver and i want to make sure i dont get something that is too stiff and bouncy.
When you say you are happy with ride, how would you describe it?
mikedsilva is offline   Reply With Quote
Old 05-15-2010, 05:18 PM   #198
trick3d
Member#: 202146
2010 evoru
GG
Default Compiling Tokico D-Specs settings
Well have you started comparing spring rates of different models? The tokicos and rce blacks I have, are not bouncy but they are stiff so i would think you would want to stay closer to oem rates.
Old 05-15-2010, 10:10 PM   #199
RiceRooster
Member#: 127550
2004 WRB STi
2004 ZX10R
2004 STi 135,000 miles
Espiler GT springs 280f/230r
4f TFFS/5r TFFS
stock top hats
Whiteline 22mm rear sway
Whiteline 27mm front sway
Karboy f/r kartboy endlinks
Kartboy, Whiteline bushings upgrade
Kartboy subframe lock bolt
F/R strut brace
H-Brace
Fender brace
Oswald Performance light weight bumper beam
-1.6 camber front/-0.5 rear camber. 0 toe all around
Still playing with the settings, but I'm pretty much done with buying suspension mods.
RiceRooster is offline   Reply With Quote
Old 05-17-2010, 03:12 AM   #200
wrxSIN
Member#: 157818
did you do your
kegels today?
Originally Posted by wrxSIN View Post
07 WRX ~16k
4 turns from stiff (FRONT) 4.5 TFFStiff (REAR) - DD
Full stiff F/R for auto-x
RCE blacks
Ride height from center of hub to metal edge of fender - UNKOWN
Group-n fronts, stock rears
none
sti bbs - re01rs
-1.4f/-1r
Comments - First auto-x season with dspecs. will be playing around with settings.
slowly been dialing it softer.
was 4.5 tffs front and 4.75 tffs Rear for about 6-8 months
felt pretty good there.
currently at 4.75tffs front and 5 tffs rear
feels a bit too bouncy, but this is supposed to be the magic spot
wrxSIN is offline   Reply With Quote
Gauging interest: Tokico D-spec + new Swift R-spec springs Turn in Concepts Vendor 'Group Buy' Classifieds 45 03-09-2008 10:55 PM
ONE SET Tokico D Spec IN STOCK ON SALE. + Koni inserts & Crucial Springs in stock! Crucial Racing Suspension/Brakes/Handling 7 10-26-2007 02:07 PM
what are your tokico d-spec settings? ASpec818 Brakes, Steering & Suspension 7 07-30-2006 06:26 PM
Tokico D-Specs? BAC5.2 Brakes, Steering & Suspension 2 11-02-2004 06:28 PM
Tokico d-spec struts pyropretz Brakes, Steering & Suspension 12 09-22-2004 03:32 PM
