#1 |
Member#: 39562
Vehicle:My02 WRX Sedan 5MT WR blue |
I removed the wrx oil plug during a routine oil change. I replaced the crush washer and waited 10mins for the oil to drain out.
The plug screwed in 3/4 of the way fine by hand and looked straight on, but it would not tighten and further. Threads were clean and lubed. Is this normal? Do you have to use a wrench therafter(for the last 1/3)?
#2 |
Member#: 102895
Vehicle:'12 Forester '08 Legacy |
It sounds like you may have cross-threaded the plug/pan. Tightening it in the rest of the way could mean a new oil pan, because you can't get the thing out again or the threads are mangled.
Happened to a friend of mine with his Camry, who sometimes took it to oil change places. Sometimes overtorqued oil plugs can ruin threads. If you didn't put oil in, take the plug out and inspect the threads (on the pan too). On all Subarus I've ever changed I could hand tighten easily until it hit the crush washer. |
#3 |
Member#: 158586
Vehicle:2009 WRX Pearl White |
It should be loose all the way to the crush washer and then there should be resistance, not before.
#4 |
Member#: 39562
Yeah thought so. Bugger. Thanks guys.
#5 |
Member#: 39562
Okay there is currently no leaks.
What should I do at the next oil change. Do I need to plan for a new sump? |
#6 |
Member#: 39562
bump
#7 |
Member#: 158586
I would have a reputable service shop (preferably dealer) check the threads on the next oil change, and order parts if need be.
Something so cheap and simple to fix isn't worth the expensive, new engine route. |
#8 |
Member#: 131996
SCIC
Vehicle:2006 CGM WRX Wagon Yimi Tuned 296AWP/322TQ |
....fumoto valve would save one from something like this, assuming you don't cross thread the valve!
| Thread Tools | |
| Display Modes | |
| Advice needed-Oil Can Henry's oil change problem | Mike7 | Factory 2.5L Turbo Powertrain | 51 | 03-17-2009 01:40 AM |
| Turbo Oil Inlet line > block, oil leak problems? | RSblood | Service & Maintenance | 5 | 11-04-2008 01:12 PM |
| FS: oil plug for oil temp or pressure gauge from subaru | jimtweet | Private 'For Sale' Classifieds | 2 | 03-14-2005 09:01 AM |
| Oil line problem fix....now a BIG BIG problem | the spacecowboy | Normally Aspirated with bolt-on Forced Induction Powertrain | 11 | 11-26-2002 02:17 AM |
| Oil plug crush washers? | yakker | Technical Forum Archive | 18 | 06-09-2000 06:39 PM |
