Old 04-08-2008, 09:42 AM   #1
ScoobKing
Member#: 151420
93 Version 4-3 7/8
Quartz metallic grey son!
Default Axle grease everywhere!
My passenger side axle is throwing grease everywhere. It's the second new axle put on that side. Should I get another new one or put a new boot and clamp on there?
Does anyone else have this problem?
ScoobKing is offline   Reply With Quote
Old 04-08-2008, 03:50 PM   #2
leecea
Member#: 37359
2003 WRX
There is a lot of info in the Transmission forum. For example, I found this quote that might apply...
Originally Posted by HighSpeedRacerX View Post
It's probably the passenger side front CV and you have an aftermarket DP. The boot usually looks fine, it's the excess heat from the unshielded DP that causes the CV Joint grease to liquify and leak out from the boot. This is a common problem.
After you fix the grease issue, you should make a heat shield for the RH CV joint to keep this from happening again.
I just had grease leakage on my driver's side and it was repacked and rebanded by the dealer last week. Only time will tell if it lasts.
leecea is offline   Reply With Quote
Old 04-08-2008, 04:11 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
If you redo it yourself dont use the grease that the boot comes with. Use High Temp Synthetic Wheel Barring Grease. It will remaing thick longer under the heat. Just be sure to use the same amount as in the bag that comes with the new CV joint
dangerousatom is offline   Reply With Quote
Old 04-08-2008, 04:50 PM   #4
ScoobKing
Member#: 151420
93 Version 4-3 7/8
Did you go with a new boot too or just reuse the old one?
Neeed help axle grease k04sti Brakes, Steering & Suspension 2 04-06-2008 05:12 PM
Axle Grease Caps? proletariandan Newbies & FAQs 6 07-22-2005 08:24 AM
Is this normal? Grease looking stuff around my axle & tranny cky211 Transmission (AT/MT) & Driveline 25 10-09-2003 10:05 AM
Update: Leaking Grease From Axles and Souther States Subaru SPeeDSiN South East Region Forum 8 03-06-2003 03:01 PM
Axle Grease? Sauceboy01 Transmission (AT/MT) & Driveline 4 01-13-2003 11:43 AM
