Old 04-08-2008, 10:49 AM   #1
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Default Dipstick impossible to read?
I know I am not the only one to think about this, but on my 07 STI the dipstick is impossible to read. I will let the engine get hot, wait a couple hours, or sometimes check it after it sat overnight. It just doesn't have a very solid line like every car I have owned before. Then one side of the dipstick always reads way higher than the other side? I know it isn't me here guys, any tips?
pinkertonpunk is offline   Reply With Quote
Old 04-08-2008, 10:52 AM   #2
rxer311
Member#: 107099
'07 STI
Satin White Pearl
Same Problem Here
rxer311 is offline   Reply With Quote
Old 04-08-2008, 11:05 AM   #3
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
That pisses me off as well...
Dirtyhobo010 is offline   Reply With Quote
Old 04-08-2008, 11:41 AM   #4
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Same here this is a common gripe with many Suby owners from what I've seen.
jordanretro1223 is offline   Reply With Quote
Old 04-08-2008, 11:49 AM   #5
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
there is a way of doing it..
After it has been sitting for long enough, remove the dipstick and clean it off..
When reinserting the dipstick, stick it in slowly about 85% of the way in , then for the last 15%, jam it in quickly and pull it out just as fast....
Now you should have a clealy visible indication of your oil level..
Seems a little brutal, but it works everytime..
jigga is offline   Reply With Quote
Old 04-08-2008, 11:50 AM   #6
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
I will try that then, see how it works.
Old 04-08-2008, 11:52 AM   #7
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
426whp aspen / 340whp psm
Default Dipstick Reding
I have tried that and this works for me as well
Ireneusz is offline   Reply With Quote
Old 04-08-2008, 03:30 PM   #8
phlegmon
Member#: 26223
2016 Focus RS
1992 NSX twin turbo
Here's another trick: take some fine grit sandpaper and score the lower end of the dipstick (up to the hot-high level mark). You don't need to shave it down, just make sure it's a rough surface for the oil to adhere to. Make sure you clean off the shavings before you reinsert .
I did this on my STi and it actually made a line at the oil level, rather than the smear that the unmodified dipstick showed. Voila, an accurate dipstick!
phlegmon is offline   Reply With Quote
Old 04-08-2008, 04:08 PM   #9
mjjantz
Member#: 82385
2007 07sti ptunestg2
pearl WHITe
you can always take out the dip stick and paint it with caliper paint or engine paint let it dry and take white or some other color make some lines ..but right under the little hole punch is the filled mark...
mjjantz is offline   Reply With Quote
Old 04-08-2008, 07:32 PM   #10
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
The dipstick sucks!
tux121 is offline   Reply With Quote
Old 04-08-2008, 07:44 PM   #11
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
I took a file and made hash marks on one side of the dipstick. It is VERY easy to read now.
T-WRX is offline   Reply With Quote
Old 04-08-2008, 08:43 PM   #12
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
i filed some hash marks in mine too....and basically do a best of three dips with the technique stated above
AllWheelsDriven is offline   Reply With Quote
Old 04-09-2008, 06:49 AM   #13
Darryn
Member#: 69370
2007 Legacy GT
I am not running the 2.5L engine, but I do have the 2.0L with twinscroll which shares the same oil pan. I have the same problem, and sometimes I have to pull the stick after wiping off up to 3 times before getting a reliable reading.
Darryn is offline   Reply With Quote
Old 04-09-2008, 09:27 AM   #14
foch
Member#: 163152
Default What works for me...
After engine is good and hot, shut the engine off and immeadiatley remove dip stick, let sit for a couple of minutes, than reinsert the dip stick and check the oil level.
Works every time perfectly. I usually check whille I'm filling tge gas tank.
Rich
95 Legacy, 173,000+ miles
ps.I found this technique somewhere in an old post in this forum.
foch is offline   Reply With Quote
Old 04-09-2008, 05:56 PM   #15
Rayme
Member#: 157510
2002 impreza WRX
World rally blue
what foch said, remove dipstick and wait 4-5 minute for the oil to come down the dipstick tube, then insert and remove quickly, it should show a nice line.
Rayme is offline   Reply With Quote
Old 04-09-2008, 07:08 PM   #16
Rallyroo
Member#: 67994
Think postive, at least Subarus come with oil dip sticks. Most bimmers don't have oil dip sticks anymore, except for the M series. Say hi to the BMW stealerships for oil changes and top offs.
Rallyroo is offline   Reply With Quote
Old 04-09-2008, 07:29 PM   #17
rxer311
Member#: 107099
'07 STI
Satin White Pearl
^^^yeah but the changes and top offs are free for 50000 miles. Also they will pick you up wherever you are and give you a loaner to do an oil change. My buddy just bought a 335xi and he loves it! He went to that from and evo. Sorry to hijack the thread.
Let's make a thread that's impossible to read without it b0rking your computer! St3fan Off-Topic 31 12-12-2007 05:37 AM
2006 WRX: Dipstick difficult to read Heavy Fuji Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-31-2006 04:01 AM
Newbie Question: How to read a dipstick? kdawg Newbies & FAQs 17 12-07-2002 05:57 PM
How to read dipstick? Glockperfection Service & Maintenance 4 11-15-2002 03:49 AM
