Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 04-08-2008, 10:22 AM   #1
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
Default Can somsone please help me clear a code so I can get an inspection :)
I have an EGR code that randomly keeps popping up after a few hundred miles or so...
And I need an inspection NOW ! .....my sticker is from 06
Is there anyone who might be able to hook a brother up ???
I live in Winchester Ma
lemme know !
-Lewis
781 879 9089
IllNastyImpreza is offline   Reply With Quote
Old 04-08-2008, 11:27 AM   #2
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
don't-pull-me-over Silver
You can't just clear the code and get inspected. You must drive ~400 miles without any CEL's popping up to pass.
Danny Boy is offline   Reply With Quote
Old 04-08-2008, 12:06 PM   #3
wit2003
Member#: 104395
2007 Element/99 GMC
1500/87MC-SS/00 Mirage
Your more than welcome to use my code reader again....but it might not allow the station to test your car....the ECU will read back a "not ready" status.
wit2003 is offline   Reply With Quote
Old 04-08-2008, 12:18 PM   #4
vokalize770
Member#: 160735
02 WRX wagon, WRB
XPT Stg 2 w/GMBCS
if you have a tactrix cable, you can download an opensource program and disable the CEL - then drive for a couple hundred miles and you'll be ok
vokalize770 is offline   Reply With Quote
Old 04-08-2008, 12:23 PM   #5
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
If you want to come down to Framingham I can do it. I'm here until 11pm weekdays.
Old 04-08-2008, 05:50 PM   #6
Bimmubishi
Member#: 48713
1888 Bellipotent
Wooden
Provided that you keep your gas cap tight you could have a leak in the Evap system. I'm of course guessing at the problem here but there is a conditional code that comes up a lot on Subarus that is only tested with under approximately half a tank of gas. The ECU probes the EVAP system for pressure to ensure that emissions gasses aren't leaking into the atmosphere. It's worth a try but you can clear the code, keep the tank full (frequent gas stops) Certain EVAP situations will never be tested if you keep the gas above approximately half a tank. Try to keep the car over half a tank or so for 100miles to get the ecu to show readyness.
Bimmubishi is offline   Reply With Quote
Old 04-08-2008, 05:55 PM   #7
Danny Boy
Member#: 94938
'99 Hybrid RS Coupe
What is the code specifically that pops up? We might be able to help with that info.
Old 04-13-2008, 11:09 AM   #8
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
thanks for the replies guys...
Frenchie came over and cleared the codes for me... I guess she has the same codes on her Impreza
Anyway... The code came back on JUST as I pulled into the gass station
He passed me for everything else, (including my NOT so stock exhaust ) just got a black R(better than a red one from 06)... ...awesome place if you ask me.
I then removed my EGR valve, cleaned the CRAP out of it, and reinstalled.... drove 110 miles with no problems. So I drove back and got it inspected. passed with flying colors
BUT...I got no more than 1/2 a mile from the gass station and the CEL came back !
stupid ass EGR
Old 04-14-2008, 01:30 AM   #9
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
there is a good chance you always have an EVAP problem, and your evap readiness test just hasnt been performed yet, and when it does your light comes on. You can pass with either one or two (varying from state to state, last time i checked MA is 2) ECU tests reporting 'not ready' so its likely you just got lucky and had enough of them ready and passed without meeting the conditions for your EVAP readiness test to be performed.
what's the code your getting? autozone can read codes for free.
ProdriveDreams is offline   Reply With Quote
Old 04-14-2008, 09:11 AM   #10
IllNastyImpreza
Member#: 36333
DIY project: life
I need more TIME!
the original 2 codes where EGR and idle ... forget exactly...
The code has since came and left once again (without resetting ECU) and has been gone for the last 100 miles or so
I am waiting for my USB scan tool to arive from japan... if it comes back I will check it again
I need help. can someone please help me? God Normally Aspirated Powertrain 5 01-07-2008 01:13 PM
Please help me fix these codes... jhull Factory 2.0L Turbo Powertrain 10 01-02-2007 09:04 PM
can somebody experienced help me clear my 05 headlights? DieselClown Tri-State Area Forum 4 08-19-2004 08:21 AM
can somebody PLEASE help me with this part? nhluhr Interior & Exterior Modification 3 01-01-2003 07:08 PM
Can someone please help me out...... subywan-kenobi Bay Area Impreza Club Forum -- BAIC 8 01-25-2002 04:38 PM
Message Board Statistics All times are GMT -4. The time now is 04:54 PM.
