Mid Atlantic Impreza Club
Old 04-08-2008, 11:35 AM   #1
Oodles-of-Noodles
Member#: 161146
2005 Saabaru
Default Does anyone in the area have a brake bleeder?
I really need to do the brakes on my car. Does anyone in the area have a brake bleeder I can borrow? Willing to trade beer for its usage.
Oodles-of-Noodles is offline   Reply With Quote
Old 04-08-2008, 11:56 AM   #2
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
Do you mean a speed bleeder?
Noah is offline   Reply With Quote
Old 04-08-2008, 01:17 PM   #3
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Every car has a bleeder valve. You just need a wrench or socket and a friend to pump the brakes.
TAPOUT is offline   Reply With Quote
Old 04-08-2008, 01:20 PM   #4
SpeedTheory
Member#: 152510
^Correct. Or do you mean a pressure bleeder (bad idea)?
SpeedTheory is offline   Reply With Quote
Old 04-08-2008, 01:32 PM   #5
richy_21
Member#: 58670
2005 got muuuuu?
http://www.fastwrx.com/mopobl.html
this is what hes asking prob.
richy_21 is offline   Reply With Quote
Old 04-08-2008, 01:34 PM   #6
SpeedTheory
Member#: 152510
A friend of mine has one in Springfield. PM me if you need to borrow it.
Old 04-08-2008, 01:39 PM   #7
AllAWD
Member#: 17079
You can get a mitivac at Autozone for $30. Gas+beer to go pick up something is going to run you almost the same.
Or, you could also ask someone with a working leg to help you bleed your brakes the old way.
AllAWD is offline   Reply With Quote
Old 04-08-2008, 02:35 PM   #8
dunk
Member#: 15359
Why do you think a pressure bleeder is a bad idea?
Duncan
dunk is offline   Reply With Quote
Old 04-08-2008, 02:40 PM   #9
BryanH
Member#: 993
He probably read the BS on Stoptechs web site about pushing air into the brake fluid using one of these....with a whole 8 psi.
If not I dunno what....but that has been the controversy.
EDIT...http://forums.nasioc.com/forums/show...ghlight=motive
there was a thread about it.....
BryanH is offline   Reply With Quote
Old 04-08-2008, 11:19 PM   #10
SpeedTheory
Member#: 152510
No, its possible to overpressurize the system and put stress on the brake lines, etc. I don't understand why you wouldn't just traditionally bleed.
Old 04-09-2008, 12:29 AM   #11
matt84
Member#: 43764
'04 Missing my Suby
LOL operating pressure on the lines coming right off the master cylinder are 1300psi Max around twice that for safety reasons might even be three fold
matt84 is offline   Reply With Quote
Old 04-09-2008, 09:41 AM   #12
BryanH
Member#: 993
at 8 to 12 psi?
How much pressure do you think the brake system gets put on it when you apply the pedal for a "normal" stop...much less something required to activate ABS?
Old 04-09-2008, 01:46 PM   #13
MasterKwan
Member#: 98961
2003 WRX
I have a pressure bleeder but, don't use it on my WRX. Last time I did, I just didn't get as good a bleed as I can with a single man bottle and hose type bleed. I have speed bleeders now which make it even easier.
Hooking a pressure bleeder up is a HUGE pain on the WRX unless you have the special cap that matches the subaru cap.
Old 04-09-2008, 01:53 PM   #14
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
I started trying to bleed with a little vacuum bleeder last time I did my brakes. I got halfway through the first corner and threw it away.
I then called my wife to come down and push on the brake pedal for me.
Jard is online now   Reply With Quote
Old 04-09-2008, 02:58 PM   #15
MasterKwan
Member#: 98961
2003 WRX
The problem with a vacuum bleed is you suck air around the threads of the bleeder screw. I've thrown a turn of teflon tape around the bleeder screws sometimes to prevent that. Speed Bleeders have thread sealer painted on so, they won't bleed air though the threads.
Old 04-12-2008, 01:13 AM   #16
matt84
Member#: 43764
'04 Missing my Suby
I just did my brakes on my sti this go around, I used the BG brake flush machine it's impressive! Pressure adj. 3-35 psi. and switchable vacuum pump. It makes it easy. Everyone knows they should activate the ABS system solenoid self check right??? It's pins 1 and 6 on the black free connector under the driver side knee panel next to the green d check connector. You have to use a paper clip to jump terminal 1 and 6, its gets air out of the hydraulic pump.
Does anyone in LA area have any spare 3" exhaust gaskets? (Help a desperate man!) tjhksig Southern California Impreza Club Forum -- SCIC 9 08-02-2005 02:12 PM
Does anyone in the SE have a spare 17" Rota or other brand wheel? trhoppe South East Region Forum 2 03-10-2003 01:52 PM
Anyone in the area have a Level10/protorque TC Daios Bay Area Impreza Club Forum -- BAIC 5 03-05-2002 07:41 PM
does anyone in seattle area have... True06 North West Impreza Club Forum -- NWIC 6 03-02-2002 06:59 AM
Anyone in the area have syncro problems with their WRX? Cjchaps Mid West Subaru Owners Club Forum -- MWSOC 8 10-05-2001 09:21 AM
