Old 04-08-2008, 11:59 AM   #1
-=C=-
Member#: 7719
99 F-150 crew cab
with illegals in bed
Default Can I run 208/240v in one room of my house easily?
I have a computer room that also has a LCD TV and surround sound system. Everything plugged into a wall outlet can operate on 240v.
Would it be expensive for an electrician to setup a single 208 or 240v circuit just for that room?
I'm thinking I could end up with less power usage overall and longer equipment life.
-=C=- is offline   Reply With Quote
Old 04-08-2008, 12:08 PM   #2
Wires
Member#: 36677
2003 WRX Wagon
Sedona Red
Uh, your device will use the same amount of power, regardless of the supply voltage.
No, it wouldn't be very expensive for an electrician to run one 240 circuit to your room, but, you really don't need one.
Wires is offline   Reply With Quote
Old 04-08-2008, 12:10 PM   #3
Akirasoft
Member#: 2973
2015 X3 35i M-Sport
would be less amperage, but wattage would be the same. no point.
Akirasoft is offline   Reply With Quote
Old 04-08-2008, 12:25 PM   #4
vapore0n
Member#: 21356
2010 BMW 335i
2017 STI Limited LBP
unless your amp requires 240V, it is unnecessary
Oh and running a line like that costed me 500$
Install new breaker, run line, make connections
vapore0n is online now   Reply With Quote
Old 04-08-2008, 12:28 PM   #5
beethoven
Member#: 6654
2006 Odyssey
2006 Prius
About the only reason to do that is if your equipment is going to pull > 15A at 110, otherwise there isn't much benefit.
beethoven is offline   Reply With Quote
Old 06-03-2010, 08:37 AM   #6
WRteXan
Member#: 223894
I'm glad people seem to have some common sense here. High voltage is more efficient over long runs (transmission lines), or in cases where the current draw to cable size ratio is high (A/C, heater, air compressor). In the second case, it is typically not cost effective to go with any larger wire than already in use.
The efficiency increase you would see in this situation wouldn't pay for the install over the life of a home... heck, it might not even pay for the breaker.
Sources: BSEE 2001, specialized in power generation and transmission since.
WRteXan is offline   Reply With Quote
Old 06-03-2010, 08:56 AM   #7
chapstien
Member#: 68284
1988 Corolla SR5
0-points
You bumped a 2 year old thread for that?
chapstien is online now   Reply With Quote
Old 06-03-2010, 08:59 AM   #8
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Well, nobody gave a correct answer other than WRteXan. <shrug>. The main problem is the OP didn't know what he's talking about. 208v is 3-phase derived from 3 120v phases whereas 240v is a single phase standard (120v is a half-tap of a 240 transformer so a 240v supply would need to be provided unless he already has it). No consumer electronics give you the option of using single-phase or 3-phase.
nhluhr is offline   Reply With Quote
Old 06-03-2010, 08:59 AM   #9
CrashTestRacer
Member#: 66394
2004 WRX Wagon
You're trying to confuse us with your "208" volts, aren't you? 208V is a 3 phase voltage in the US. I'm going to doubt you have 3 phase power to your house.
ahh crap, it is 2 years old
CrashTestRacer is offline   Reply With Quote
Old 06-03-2010, 09:26 AM   #10
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
To be fair, he complimented us.
Kiel is offline   Reply With Quote
Comcast can GTFO of my house RallyGuy2k Texas Impreza Club Forum -- TXIC 81 07-04-2010 03:43 PM
Did you see a sign in the front of my house that said dead ****** storage? hitman912 Off-Topic 65 12-26-2006 12:13 AM
Sighting: WRB WRX w/spoiler parked practically in front of my house... thebusiness999 Southern California Impreza Club Forum -- SCIC 0 07-05-2002 02:47 PM
Sighting in front of my house :] Mazoku Mid West Subaru Owners Club Forum -- MWSOC 3 10-05-2001 01:43 AM
Spotted: Right In Front of My House!!! North Ursalia New England Impreza Club Forum -- NESIC 5 10-16-2000 03:29 AM
