Old 04-09-2008, 03:16 AM   #1
Mikeye
Member#: 100098
'99 LGT
Default Can't remove transmission fluid bolt...any tips?
Hi there,
I was going to drain the transmission fluid today but I couldn't loosen the bolt. I have the car up on two stands so there isn't too much room beneath the car but it's not that bad.
I'm using a 7" 17mm wrench. Feels like I have enough leverage to remove the bolt but it just doesn't give...
Any tips?
Thanks!
Mikeye is offline   Reply With Quote
Old 04-09-2008, 04:39 AM   #2
rougeben83
Member#: 115154
2005 Outback XT
White on grey
socket and breaker bar with extension. I used a 1/2" drive 12" long breaker when I changed the fluid on mine.
I thought it was a 19mm?
rougeben83 is offline   Reply With Quote
Old 04-09-2008, 07:43 AM   #3
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
yup just get a big ass breaker bar
legacy1907 is offline   Reply With Quote
Old 04-09-2008, 08:53 AM   #4
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
put a pipe on the wrench if you dont have a breaker bar.
Kawikid20o2 is offline   Reply With Quote
Old 04-09-2008, 10:30 AM   #5
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
works as well, however, a breaker bar is one of the best investments you will ever make if you plan to do any work on a car, especially one thats 10 years old like mine. That and they are pretty cheap
Old 04-09-2008, 12:14 PM   #6
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
You can also just use the hollow end of a jack handle.
Try tightening the bolt up first, then try to loosen it. Do that a few times, usually it'll unstick itself.
And for future changes, I suggest a Fumoto Valve.
Huffer is offline   Reply With Quote
Old 04-09-2008, 03:22 PM   #7
Mikeye
Member#: 100098
'99 LGT
Fumoto valve for the transmission? I thought people only use that for the engine?
Old 04-09-2008, 04:00 PM   #8
Huffer
Member#: 36735
99 GF8 Impreza 2.0
You can use a Fumoto valve for any threaded bolt hole that fits.
Shoot, I've considered trying to find one for the rear diff.
Old 04-10-2008, 03:06 AM   #9
rougeben83
Member#: 115154
2005 Outback XT
White on grey
just be sure it clears your stock manifold/header.
I can't use one with my TWE headers, for example.
Old 04-10-2008, 03:49 AM   #10
Mikeye
Member#: 100098
'99 LGT
I have a 99 LGT and it's 17mm for me, same as the engine drain bolt.
Old 04-11-2008, 12:19 AM   #11
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
1/2'' breaker bar is a very good investment, make sure it is at least 18'' long.
~Josh~
Old 04-11-2008, 12:47 PM   #12
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
I used a torque wrench to get the tranny bolt out of a 1987 Nissan Frontier I had to drop the tranny on. And, yeah, get something that's 1/2" drive and don't use a socket, the drive will fit right into the square on the bottom of the bolt.
Chi_San is offline   Reply With Quote
Old 04-11-2008, 03:35 PM   #13
Mikeye
Member#: 100098
'99 LGT
Wow, I didn't know the 1/2" drive fits into the transmission bolt...I'm gonna check it out.
BTW, any of you guys change the transmission filter? Seems easy for me since my is an external spin on/off type.
Old 04-11-2008, 04:56 PM   #14
Huffer
Member#: 36735
99 GF8 Impreza 2.0
Cheap insurance is to change the filter. The later Legacies had the spin-on filters. Earlier ones have in-pan types, so much harder to change.
Removing Transmission, CAN'T remove front drive axles. Hotrodguru Transmission (AT/MT) & Driveline 14 08-08-2007 03:58 PM
Can't remove cam gear bolts ForceFedDSM Service & Maintenance 5 10-08-2006 08:35 PM
transmission fluid change bolt DJ_STI Service & Maintenance 4 05-28-2005 11:35 AM
I can't find my transmission fluid dipstick!!! LeXisHfLiP Service & Maintenance 3 08-22-2003 08:16 AM
('93-'01) HELP- Can't remove crank bolt ! Greg Sharpe Impreza Forum 5 06-23-2001 06:19 PM
