Welcome to the North American Subaru Impreza Owners Club Saturday April 25, 2015
Old 04-09-2008, 03:37 AM   #1
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
Default OEM 02 RS Subwoofer installed in a 08 WRX Hatch possible?
I have an OEM rear under'seat subwoofer that I took off of my 2002 RS. I just purchased an 02 WRX Hatch with the Premium kit.
My simple question is: Can my OEM subwoofer work in my 08 WRX? Do the stereo systems share the same connection type? If not, what kind of modifications will be needed? Thanks
-Ellz
ejicon is offline   Reply With Quote
Old 04-10-2008, 01:09 AM   #2
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
anyone?
Old 04-10-2008, 11:18 PM   #3
themustafa
Member#: 176523
2008 Impreza WRX
Satin White Pearl
Since your other thread got closed, I ventured over here to try to help you out.
I'm assuming that the underseat sub from your 02 RS is like that from the 08, in that it has a built-in amp. Therefore, all it needs to work is a line-level (preamp) output from the head unit. I'm pretty sure that the 08 premium head unit has one as the 08 sub is plug-and-play, so you shouldnt have a problem. The physical jacks may not be the same, so you might have to rig some wiring.
Even if the head unit doesnt have a preamp output, you can get a line-level converter that taps into the regular speaker wires to convert the signal going to the speakers into a preamp output the sub can use.
themustafa is offline   Reply With Quote
Old 04-10-2008, 11:24 PM   #4
themustafa
Member#: 176523
2008 Impreza WRX
Satin White Pearl
This thread has way more real info aside from my speculation, and it looks like the situation may be a little more complex, ie the sub may need a speaker-level amplified signal from the head unit and/or might not have a built-in amp, plus i forgot all about powering the freaking thing. check it out, see what you can figure out, and maybe a few people here that know more about subaru audio will have better answers for you.
http://forums.nasioc.com/forums/showthread.php?t=749402
Old 04-11-2008, 02:49 AM   #5
ejicon
Member#: 2452
08 2.5 WRX
WRB Mica
thanks a lot. I appreciate it.
Anyone with an 08+ WRX Hatch in the Seattle area? syphon North West Impreza Club Forum -- NWIC 29 09-12-2009 12:49 AM
FREE 08 WRX Hatch OEM Rear Sway bar!!! beedee SCIC Private Classifieds 0 06-02-2009 04:15 PM
OEM RS Subwoofer installed in 08 WRX Hatch possible? ejicon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-10-2008 06:26 PM
Super stealth subwoofer install in WRX <Caution 56k> JjSwee Car Audio, Video & Security 12 03-08-2005 04:28 AM
