Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 04-09-2008, 11:28 AM   #1
skubydew16
Member#: 121161
2006 Subie STI
Obsidian Black Pearl
Default HELP!!!!rear diff. temp light with wide open throttle!
hey guys. I was wondering if you can help me out..1st of all, a list of my mods:
hks downpipe, hks cat back, stage 2 tune..thats about it...
whenever i all in the throttle I start seeing my rear diff temp light faintly blinking. Sometimes it gets darker and more solid like its gonna stay on but then as soon as i let off the throttle and drive less aggressive it goes off! I was just wondering if anyone has this same problem? what should i do and what is causing this? any help would be greatly appreciated.
Thanks.
skubydew16 is offline   Reply With Quote
Old 04-10-2008, 01:47 AM   #2
skubydew16
Member#: 121161
2006 Subie STI
bump!!
Old 04-10-2008, 02:42 AM   #3
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
If you have access to an IR temperature gun, you can check what your temp is off of the back cover immediately after a hard pull versus just steady easy driving. Your temps are probably higher under heavy load (hence the light illumination), but you can get a general idea if you are truly running hotter than normal. What is the temperature spec for the light to come on?
Might be a good time just to check the diff oil level to ensure that you have enough in there (mystery leaks, underfilled from the factory/last change). Or you can just spend the couple of bucks for the Subaru 90 LSD oil and do a change.
Just my $0.02 since noone has posted
JamesWilson is offline   Reply With Quote
Old 04-10-2008, 02:18 PM   #4
skubydew16
Member#: 121161
2006 Subie STI
i appreciate all the advice!!!
Old 04-10-2008, 02:20 PM   #5
skubydew16
Member#: 121161
2006 Subie STI
has anybody else ever had an issue of this kind?
Old 04-10-2008, 03:02 PM   #6
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
You can have.
intermittent light?
I'd check the level first.
udelslayer is offline   Reply With Quote
Old 04-10-2008, 03:54 PM   #7
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
Agreed. Check oil level and verify temp w/thermometer (IR thermo as suggested is easiest). If temp is truly high (must compare to spec in manual) and oil level is OK, suggest pull a sample and send to Dyson Analysis ($60).
bulwnkl is offline   Reply With Quote
Old 04-10-2008, 04:56 PM   #8
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
check the connector at the rear diff plug for corrosion and fit.
Old 04-12-2008, 10:32 PM   #9
skubydew16
Member#: 121161
2006 Subie STI
Nice thanks!!!
Old 03-19-2010, 08:31 PM   #10
soon2beboostin
Member#: 184186
2005 sti
i also have this right now. i clean it then it goes away but keeps comming back on
soon2beboostin is offline   Reply With Quote
Old 03-19-2010, 08:46 PM   #11
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
change the terminal.
tramix is offline   Reply With Quote
Old 03-21-2010, 06:10 PM   #12
soon2beboostin
Member#: 184186
2005 sti
terminal as in the metal ground piece?
HELP!!!!rear diff. temp light with wide open throttle! skubydew16 Southern California Impreza Club Forum -- SCIC 8 04-10-2008 02:56 PM
Help! Rear Diff. Temp. Light manDown Service & Maintenance 2 05-25-2007 02:56 AM
rear diff temp light boostedsti06 Newbies & FAQs 9 10-18-2006 04:28 PM
Rear diff temp light and CEL Ryan Smith Transmission (AT/MT) & Driveline 1 01-22-2006 09:51 PM
V8 Cluster Rear Diff Temp light... ScreaminFast Electrical & Lighting 2 08-08-2005 03:50 AM
